> Работает CCS 3.3 в Vista?
Alexey_Sev
сообщение Feb 11 2008, 11:43
Пользователь №: 6 380
aaarrr
сообщение Feb 11 2008, 11:48
Пользователь №: 1 448
Degun
сообщение Feb 11 2008, 17:38
Пользователь №: 30 277
Цитата(aaarrr @ Feb 11 2008, 14:48) *
У меня при прямом запуске CCStudio тоже виснет. Но если запускать через "CCStudio v3.3 Setup", то запускается нормально.
Edmundo
сообщение Feb 14 2008, 08:54
Мастер
Пользователь №: 14 474
Взято отсюда:
Code Composer Studio v3.3: Windows Vista Known Issues
Code Composer Studio has some known issues when operating under Windows Vista. Read ahead for details.
Issue: You MUST turn off "User Account Control (UAC)" to operate CCS on Windows Vista.
User Account Control is a new setting in Windows Vista that controls the operation of applications. This prevents CCS from operating properly.
Workaround
The dialog below shows you how to disable user account control.
Issue: Windows Vista does not include WinHlp support.
Pressing F1 from within CCS will not launch the CCS help files. The help files also fail to launch if opened from the Start Menu. The Windows Help program that is required to launch and display 32-bit help files with a .hlp extension, such as those included in CCS, is no longer included in the Windows operating system's installer. This is captured under Microsoft Knowledge-Base Article KB917607..
Workaround
The required program, WinHlp32.exe, can be downloaded from Microsoft here. After downloading and installing the application all help files for CCS, and other applications, should be readily available.
Issue: Crashing on Exit.
If you use the Event Analysis or Sequencer tools on Vista CCS will crash when you exit the application.
Issue: Windows Reboot.
There have been limited cases of CCS causing a reboot of windows reported.
Workaround
Rename cTools.dll in the cc\bin folder to cTools.bak. This will resolve the issue but will disable advanced event triggering.
شامل
bgc
сообщение Feb 16 2008, 21:26
Пользователь №: 19 188
У меня не работает с SAU510 USB PLUS...
Иногда CCS3.3 запускается, особенно если отключена линия USB от эмулятора.
Но связь с эмулятором не устанавливается ни при каких условиях.
Проблема явно в драйвере, или в сопряжении драйвера с CCS 3.3.
User Account Control (UAC)" - отключено, конечно.
Может нужна особая версия драйвера, или что-то в виндах поправить.
При инстоляции драйвера установка прошла как то странно, процедура установки драйверы установила, но потом повисла.
Окружающий мир - не иссякающий источник сюрпризов!
Edmundo
сообщение Feb 18 2008, 12:48
Мастер
http://sauris.de/Equipment.htm
Compatible with Windows 2000, XP
Так что остается только ждать обновленный драйвер для SAU, дело скорее всего в этом.
شامل
rezident
сообщение Feb 18 2008, 13:32
Пользователь №: 3 882
Из общения с разработчиком: "Вопрос о совместимости с Windows Vista пока не стоит." Т.е. продавец SAU-510USB этой проблемой его (разработчика) еще не заморачивал. Так что тормошите продавцов CCS 3.x и эмулятора.
bgc
сообщение Feb 18 2008, 14:46
Итак! Есть ли хотябы один разработчик, у которого все работает под Vista?
Если да, то еще подумаем, если нет. Придется потратить время на переустановку XP.
Vista ничего нового мне лично не дает, просто новый комп. был с ней. Много мелких красивостей, за которые приходится платить огромным лишним потребляемым рессурсом (память, дисковое пространство). Хотя откатываться назад не всегда нравится...
Edmundo
сообщение Feb 19 2008, 09:49
Мастер
Немного off-topic, но я сделал downgrade на новом ноутбуке только из-за проблем совместимости в области специализированных программ. На себе проверять не стал и, почитав в интернете о проблемах, снес Висту сразу, как включил ноут.
شامل
ab1000
сообщение Oct 13 2008, 11:31
Из: г. Челябинск
Пользователь №: 5 387
А как вы Code Composer вообще на Vista поставили?? У меня при инсталяции ошибку выдает, не помню номер. По разному пробовал и с UAC и без
RSS Текстовая версия Сейчас: 29th August 2025 - 09:50
Страница сгенерированна за 0.01431 секунд с 7
