> AVR и AT45DB642D-SU, Не пишется инфа во flash
kostik2
сообщение May 18 2009, 03:24
Пользователь №: 14 375
Вот пытаюсь писать данные во flash.
вот процедуры:
void AT45_write_buffer_begin(unsigned int addr)
AT45_CS_ON;
AT45Ready();
SPI_Write_Byte(BUFFER_1_WRITE); // ok
SPI_Write_Byte(0x00);
SPI_Write_Byte((char)(addr>>13));
SPI_Write_Byte((char)addr);
void AT45_buf_to_mem(unsigned int addr)
AT45_CS_ON;
AT45Ready();
SPI_Write_Byte(BUFFER_1_TO_PAGE_WITH_ERASE); // ok
SPI_Write_Byte((char)(addr>>8));
SPI_Write_Byte((char)(addr<<3));
AT45Ready();
AT45_CS_OFF;
void WRITE_BUFFER1_TO_MEM(unsigned char *m, unsigned int page)
unsigned int i;
AT45_write_buffer_begin(0);
for (i=0;i<PAGE_BYTES;i++)
SPI_Write_Byte(m[i]);
AT45_CS_OFF;
AT45_buf_to_mem(page);
void AT45_read_buffer_begin(unsigned int addr)
AT45_CS_ON;
AT45Ready();
SPI_Write_Byte(BUFFER_1_READ); // ok
SPI_Write_Byte(0);
void AT45_mem_to_buf(unsigned int addr)
AT45_CS_ON;
AT45Ready();
SPI_Write_Byte(MAINPAGE_TO_BUFFER_1); // ok
AT45Ready();
AT45_CS_OFF;
void READ_BUFFER1_FROM_MEM(unsigned char *m,unsigned int index,unsigned char count, unsigned int page)
unsigned int i;
AT45_mem_to_buf(page);
AT45_read_buffer_begin(0);
for (i=index;i<PAGE_BYTES;i++)
if(i<(index+count))
m[i-index]=SPI_Read_Byte();
else SPI_Read_Byte();
AT45_CS_OFF;
#define PAGE_COUNT 8192
#define BLOCK_COUNT 1024
#define PAGE_BYTES 1056
#define BUFFER_1 0x00
#define BUFFER_2 0x01
#define BUFFER_1_WRITE 0x84
#define BUFFER_2_WRITE 0x87
#define BUFFER_1_READ 0xD1
#define BUFFER_2_READ 0xD3
#define BUFFER_1_TO_PAGE_WITH_ERASE 0x83
#define BUFFER_2_TO_PAGE_WITH_ERASE 0x86
#define MAINPAGE_TO_BUFFER_1 0x53
#define MAINPAGE_TO_BUFFER_2 0x55
#define PAGE_ERASE 0x81
#define BLOCK_ERASE 0x50
#define SECTOR_ERASE 0x7C
вот текст программы:
spi_init();
while(1)
TxData1(at45ReadVID());
TxData1(at45ReadStReG());
Del(1000);
if(g==0)
g=1;
AT45Mass[1]=0x0a;
AT45Mass[200]=0x0b;
WRITE_BUFFER1_TO_MEM(AT45Mass,10);
Del(1000);
AT45Mass[1]=0;
AT45Mass[200]=0;
READ_BUFFER1_FROM_MEM(AT45Mass,0,220,10);
TxData1(AT45Mass[1]);
TxData1(AT45Mass[200]);
выводятся нули. регистр статуса и id считываются. я такж епробовал записать в буфур 0 и потом считать оттуда - работало. а вот через память не получаеся. подскажите что не так ?
Григорий2000
сообщение May 18 2009, 04:56
Пользователь №: 15 210
А это не опечатка, что в некоторых процедурах чипселект не отпускается?
SysRq
сообщение May 18 2009, 05:14
Чайник, 1 литр
Из: Moscow
Пользователь №: 17 168
Программные ошибки тут:
Чересчур много сдвигаете. Подумайте.
Но ошибка систематическая, при чтении и записи одинаковая, так что должно было записанное прочитаться все равно (только не туда куда надо). М.б. жело в железе, или security опциях.
UPD:
Похоже есть программная ошибка серьезнее: готовность надо проверять _после_ отпускания чипселекта, т.к. команда обращения к памяти выполняться начинает именно в этот момент.
Сообщение отредактировал SysRq - May 18 2009, 05:24
aaarrr
сообщение May 18 2009, 05:55
Пользователь №: 1 448
Тут их нет, обратите внимание на скобки.
UPD:
Хорошо бы знать, что именно делает AT45Ready().
kostik2
сообщение May 18 2009, 06:00
void AT45Ready(void)
while((PINC & BIT(3))){}; 3-бит - сигнал RDY
uriy
сообщение May 18 2009, 07:29
Из: Ижевск
Пользователь №: 11 606
Если мне не изменяет память у корпус -SU это SOIC-8. У него нет вывода READY, так что же вы читаете в функции AT45Ready
SysRq
сообщение May 18 2009, 09:17
Чайник, 1 литр
Из: Moscow
Адрес внутри буфера: XXXXXXXX|XXXXXBBB|BBBBBBBB
Собстно, это отправить по SPI (адрес - это uint16_t): ноль, старший от адреса, младший от адреса. Старший - это не 13 вправо, а всего 8.
Во втором случае почти аналогично.
aaarrr
сообщение May 18 2009, 09:45
Цитата(SysRq @ May 18 2009, 13:17) *
Не, это я не выспался smile.gif С адресами там все неправильно.
kostik2
сообщение May 18 2009, 10:44
AT45DB642D-SU - TSOP28
kostik2
сообщение May 21 2009, 02:24
да я пробовал в страницу с адресом 0 писать и читать. тут сдвиг не важен.
не пишет и не считывает. пытался просто считать из страницы - считывает тоже 0.
пипец какой-то. уже и местами менля AT45_ready и AT_DESELECT. ни фига.
kosyak©
сообщение May 21 2009, 05:23
Из: НЧ
Пользователь №: 30 966
Могу дать точно работающий исходник для работы с флэшами AT45DBXXXX...а там уже по образу и подобию
kostik2
сообщение May 21 2009, 06:49
буду очень благодарен. шлите на kostiapan@mail.ru
SysRq
сообщение May 21 2009, 11:24
Чайник, 1 литр
Из: Moscow
А линия RDY\BUSY к питанию подтянута? У м\с памяти это выход open drain. И не понятно почему у вас AT45Ready ждет появления лог. 0, а не 1, как должно быть.
RSS Текстовая версия Сейчас: 28th August 2025 - 03:47
Страница сгенерированна за 0.01428 секунд с 7
