> WinAVR-20090313. Непонятная бага
_Pasha
сообщение Sep 30 2009, 16:05
Пользователь №: 29 509
Всем привет!
Исходничег:
int main(void) __attribute__ ((OS_main));
static inline uint8_t bit_swp(const uint8_t reg)__attribute__ ((always_inline));
volatile uint8_t a;
int main(void)
uint8_t b = a;
b =  bit_swp(b);
a=b;
return 0;
uint8_t www=0;
if(reg & 0x80) www |= 0x20;
if(reg & 0x40) www |= 0x80;
if(reg & 0x20) www |= 0x02;
if(reg & 0x10) www |= 0x01;
return www;
Листинг вызова bit_swp() начинается с непонятного действия
  86:    28 2f           mov    r18, r24
  88:    22 1f           adc    r18, r18
  8a:    22 27           eor    r18, r18
  8c:    22 1f           adc    r18, r18
  8e:    22 95           swap    r18
  90:    22 0f           add    r18, r18
  92:    20 7e           andi    r18, 0xE0; 224
А далее - все как должно быть
CODE
94: 86 fd sbrc r24, 6
96: 20 68 ori r18, 0x80 ; 128
98: 85 fd sbrc r24, 5
9a: 22 60 ori r18, 0x02 ; 2
9c: 84 fd sbrc r24, 4
9e: 21 60 ori r18, 0x01 ; 1
int main(void)
uint8_t b = a;
b = bit_swp(cool.gif;
a=b;
a0: 20 93 02 01 sts 0x0102, r18
return 0;
a4: 80 e0 ldi r24, 0x00 ; 0
a6: 90 e0 ldi r25, 0x00 ; 0
a8: 08 95 ret
-------- begin --------
avr-gcc (WinAVR 20090313) 4.3.2
Copyright © 2008 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Compiling C: test.c
C:/WinAVR-20090313/bin/avr-gcc -c -mmcu=atmega48 -I. -gdwarf-2 -DF_CPU=8000000UL
-Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wst
rict-prototypes -Wa,-adhlns=./test.lst -std=gnu99 -fno-split-wide-types -mcall-
prologues --param inline-call-cost=3 -fno-unroll-loops -MMD -MP -MF .dep/test.o.
d test.c -o test.o
Linking: test.elf
C:/WinAVR-20090313/bin/avr-gcc -mmcu=atmega48 -I. -gdwarf-2 -DF_CPU=8000000UL -O
s -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstric
t-prototypes -Wa,-adhlns=test.o -std=gnu99 -fno-split-wide-types -mcall-prologu
es --param inline-call-cost=3 -fno-unroll-loops -MMD -MP -MF .dep/test.elf.d tes
t.o led7s.o --output test.elf -Wl,-Map=test.map,--cref -lm
Creating load file for Flash: test.hex
C:/WinAVR-20090313/bin/avr-objcopy -O ihex -R .eeprom -R .fuse -R .lock test.elf
test.hex
Бага или нет?
singlskv
сообщение Sep 30 2009, 17:36
дятел
Из: Питер
Пользователь №: 17 065
Цитата(_Pasha @ Sep 30 2009, 20:05) *
Бага или нет?
Ну вроде как не бага, но оптимизатор там сильно переклинило
Кстати, а какой уровень оптимизации ?
  86:    28 2f           mov    r18, r24  <- типа передаем параметр в временную переменную
  88:    22 1f           adc    r18, r18  <- ставим флаг С если (www&0x80)
  8a:    22 27           eor    r18, r18  <- обнуляем www
  8c:    22 1f           adc    r18, r18  <- пишем С в младший бит www
  8e:    22 95           swap    r18  <- переносим бит С в 4 бит(0x10) www
  90:    22 0f           add    r18, r18  <- переносим его в 5 бит(0x20) www
  92:    20 7e           andi    r18, 0xE0; 224  <- ну и еще маску зачем-то
_Pasha
сообщение Sep 30 2009, 18:02
-Os
Самое интересное: попытался поменять if(reg & 0x80) www |= 0x20; на что-нить, не связанное с инструкцией rol (т.е. не крайние биты проверять вначале) - результат тоже такой сумбурный smile.gif Именно при входе.
singlskv
сообщение Sep 30 2009, 18:34
дятел
Из: Питер
попробуйте как-нить так:
uint8_t bit_swp(uint8_t reg)
  reg >>= 4;
  if (reg & 0x08) reg |= 0x20;
  if (reg & 0x04) reg |= 0x80;
  reg &= 0xF3;
  return reg;
Должно быть кратко и без глюков оптимизации.
_Pasha
сообщение Sep 30 2009, 19:20
Дык стандартный же алгоритм перестановки бит! Чтоб этот момент не отягощал, можно вообще вставочку написать... я в ближайшее время покопаюсь - сдается мне, что этот глючок может выходить боком во многих ситуациях. Только я пока на уровне собачки - все понимаю, а сказать не могу. smile.gif
ReAl
сообщение Sep 30 2009, 19:59
Нечётный пользователь.
Из: Бровари, Україна
Пользователь №: 5 417
20071221 точно таким же хитрым образом выделяет бит 7 в младший бит и сдвигает его на 5 влево вместо w=0; if() w |= 0x20.
Перестановка проверки/переноса страшего бита в конец функции bist_swp()
uint8_t
    uint8_t www = 0;
    if (reg & 0x40)
        www |= 0x80;
    if (reg & 0x20)
        www |= 0x02;
    if (reg & 0x10)
        www |= 0x01;
    if (reg & 0x80)
        www |= 0x20;
    return www;
чудесным образом исцеляет кодогенератор от галлюцинаций на тему лёгкости выделения 7-го бита
    lds r18,a
    mov r25,r18
    ldi r24,lo8(0)
    sbrc r18,6
    ldi r24,lo8(-128); как видим, тут тоже не ori - "зачем орить, если там был 0"  *)
.L3:
    sbrc r25,5
    ori r24,lo8(2)
.L4:
    sbrc r25,4
    ori r24,lo8(1)
.L5:
    sbrc r18,7
    ori r24,lo8(32)
.L6:
    sts a,r24
*) я давно заметил какую-то странную "любовь" кодогенератора к старшему "знаковому" биту. Его легко проверить tst / brmi, его легко засунуть в перенос и оттуда высунуть. И почему-то часто вместо sbrc/sbrs используются навороты, сводящие задачу к имеющимся "лёгкостям". В данном случае, когда по первому сравнению в ранее занулённій регистр можно не "орить", а занести нужное, он решилд даже не занулять регистр, а сразу занести нужное (чё по ведру носиться, ща обкопает колодец и принесёт весь). Но даже сдвинуть на два бита вправо и замаскировать не догадался - больно "легко" старший бит получить в C
Да это глючок только в смысле растянутости во времени. Результат правильный :-)
_Pasha
сообщение Oct 6 2009, 12:01
CODE
#include <avr/io.h>
static struct Tpin_xrf
volatile void *port;
uint8_t mask;
} pin_xrf[5]={
{.port=&PORTB, .mask= 1},
{.port=&PORTB, .mask= 0x80},
{.port=&PORTB, .mask= 0x10},
{.port=&PORTB, .mask= 0x40},
{.port=&PORTB, .mask= 0x20},
int main(void)
for(uint8_t j=0;j<5;j++)
if(*((uint8_t*)pin_xrf[j].port) & pin_xrf[j].mask) PORTC |= 1; else PORTC &= ~1;
return 0;
CODE
int main(void)
5c: a0 e0 ldi r26, 0x00 ; 0
5e: b1 e0 ldi r27, 0x01 ; 1
60: ed 91 ld r30, X+
62: fc 91 ld r31, X
64: 11 97 sbiw r26, 0x01 ; 1
66: 80 81 ld r24, Z
68: 12 96 adiw r26, 0x02 ; 2
6a: 9c 91 ld r25, X
6c: 12 97 sbiw r26, 0x02 ; 2
6e: 89 23 and r24, r25
70: 11 f0 breq .+4 ; 0x76 <main+0x1a>
72: 40 9a sbi 0x08, 0 ; 8
74: 01 c0 rjmp .+2 ; 0x78 <main+0x1c>
76: 40 98 cbi 0x08, 0 ; 8
78: 13 96 adiw r26, 0x03 ; 3
int main(void)
7a: 81 e0 ldi r24, 0x01 ; 1
7c: af 30 cpi r26, 0x0F ; 15
7e: b8 07 cpc r27, r24
80: 79 f7 brne .-34 ; 0x60 <main+0x4>
return 0;
82: 80 e0 ldi r24, 0x00 ; 0
84: 90 e0 ldi r25, 0x00 ; 0
86: 08 95 ret
Что я хотел сказать: Доступ к полям структуры почему-то делается через Х а не через Z с использованием LDD/STD. Странноватое назначение регистровых пар. Можно ли как-то улучшить этот момент?
RSS Текстовая версия Сейчас: 28th August 2025 - 11:47
Страница сгенерированна за 0.01743 секунд с 7
