> Цены на отладочные платы для коммуникационных процессоров Samsung от китайцев, Довольно интересно!
Evgeny_CD
сообщение Dec 15 2005, 07:21
Группа: СуперМодераторы
Пользователь №: 1 892
(1) S3C2510-DevPlatform price is US$800.
(2) IXP425-DevPlatform price is US$1000.
(3) FD44BOX-Platform price is US$450.
Price includes shipping cost.
Platform Kits includes:
1. Hardware:
(1) one Hardware Development Platform.
(2) Other accessories:
+5V Power and adapter, network cable and RS232 cable, USB Cables.
2. Software:
(1) All hardware schematics.
(2) Embedded Linux source code.
(3) Embedded file system source code.
(4) Many Application Demos source code based Embedded Linux.
(5) Embedded Linux development Tools.
(6) Application development package.
3. Documents:
(2) User Guide manual.
(3) All ICs datasheets.
FD44BOX-Platform - это плата на S3C44BOX
http://www.fudantech.com/cp2.asp
По цене, конечно, перебор. Тут 250
http://www.embedinfo.com/english/Product/s3cev40.asp
S3C2510-DevPlatform - вот это куда интереснее. PCI!
http://www.fudantech.com/cp10.asp
Вообще S3C2510 выглядит очень заманчиво:
The following integrated on-chip functions are described in detail in this user’s manual:
• 16/32-bit ARM940T RISC Embedded
• 4K-byte I-Cache and 4K-byte D-Cache
• Memory Controller with 24-bit External Address
Pins
. 2 Banks of SDRAM for 16/32-bit Bus
. 8 Banks of Flash/ROM/SRAM/External
I/O for 8/16/32-bit Bus
. One External Bus Master with Bus
Request/Acknowledge Pins
• Two 10/100 Mbps Ethernet Controllers
• PCI Host/Agent Controller or CardBus (PCMCIA)
. PCI Host mode: 5 (or more) PCI Slots
Interface for PCI Cards
. PC Card Host mode: 1 PC Card Socket
Interface for 16-bit PC Card or CardBus
PC Card
• AAL5 SAR and UTOPIA L1/L2
• 2 Port Full/Low Speed USB HOST with Root
Hub.
• 1 Port Full Speed USB Function with Transceiver
Spec. 1.1
• Six General-Purpose DMAs
• Two High-Speed UARTs
• One Console UART
• DES and 3DES for IP Security
• IIC Serial Interface
• Interrupt Controller
• Six 32-bit Programmable Timers
• 30-bit Watchdog Timer
• 64 Programmable I/O Ports
. 8 General-Purpose I/O
. 6 External Interrupt Request
. 6 Timer Output
. 4 External DMA Request
. 4 External DMA Acknowledge
. 21 SAR Signals
. 15 UART Signals
• Four PLLs for each ARM940T (166MHz),
System (133MHz), PCI & PC Card Controller
Clock (33/66MHz), USB Host/Device Clock
(48MHz), and Ethernet PHY (20/25MHz).
• CPU Operating Frequency: Up to 166MHz
• AHB Bus Operating Frequency: Up to 133MHz
• Package Type: 416 PBGA
• Core Operating at 1.8V ±5 %, -40~85 oC
• I/O Operating at 3.3V ±5 %, -40~85 oC
• 3.3V input/output levels, 5V tolerant only for PCI.
BGA 1.0 в 4 ряда - так что жить можно.
Интересно, S3C2510 пробовал ли кто в работе? Как оно?
VslavX
сообщение Dec 15 2005, 10:34
embarrassed systems engineer
Из: Осокорки
Пользователь №: 10 038
От Самсунга - проектировал на 44BOX и 2410.
От Интеля - имел дело с IXP42x.
Корейские камни очень неплохи - все продумано и максимально интегрировано. Вот хотя бы отдельный PLL для PHY. Потребляют мало. Довольно быстродействующие - тестировал контроллеры SDRAM на PC-133, интеловскому варианту почти не уступают. По ядрам - стандартный ARM (у интела - переработанный XScale, ИМХО ненамного эффективней).
Насчет Интеля - это классический академический подход. Все раздельно и отдельно. Шины все отдельные, тактирование везде отдельное, куча взаимосвязанных отдельных входов сброса, куча раздельных кешей и их режимов работы, все выводы имеют единственную функцию и никакого мультиплексирования. Выручает только документация - у Интела традиционно на высочайшем уровне.
PCI - хост/мастер/DMA очень рулит, на него легко вешается FPGA в котором можно сделать свой любой интерфейс, связанный с ЦПУ довольно быстрой шиной и незагружающий его при массированной передаче данных.
Dainis
сообщение Dec 15 2005, 21:53
Пользователь №: 154
http://topmicrosystems.com/html/snds300.phtml
http://topmicrosystems.com/html/eboard_price.phtml
http://topmicrosystems.com/kimstek/SNDS300...C4530A_rev1.zip
TEB-4530 evaluation board shows the basic system-based hardware design which uses S3C4530A.
It can evaluate the basic operations of S3C4530A and develop codes for it as well. This allows you to test and debug a system design at the processor level.
Evgeny_CD
сообщение Dec 15 2005, 22:28
http://www.embedinfo.com/english/Product/ax4510.asp
Embest AX4510 Evaluation Board
ARM - Samsung S3C4510B EVB 10/100M Ethernet, USB, 2x RS232, LCD, PS2, Boot Code, ucLinux ...
US $150(including shipping charges)
Или сюда EVM50100 180$
http://www.ucrouter.ru/hardware.html
За разницу в цене проще перепаять S3C4510B-> S3C4530A (цоколевка полностью одинаковая)!
gcc-user
сообщение Dec 16 2005, 13:18
Пользователь №: 691
Насколько я знаю, в EVM50100 уже ставится S3C4530A.
RSS Текстовая версия Сейчас: 31st August 2025 - 07:40
Страница сгенерированна за 0.06277 секунд с 7
