3 страниц V   1 2 3 >
> Samsung S3C2440 ARM9 Board + 3.5" TFT LCD Touch Screen
SL555
сообщение Oct 12 2009, 08:16
Пользователь №: 5 580
нашел на ebay такой кид:
CPU
- Samsung S3C2440A 400MHz, Max freq. 533Mhz
SDRAM
- 64MB SDRAM
- 32bits Data Bus width
- 100MHz Clock
Flash
- 64MB Nand Flash,
- 2MB Nor Flash, BIOS installed
LCD
- 4 wire resistive touch screen interface
- Up to 4096 color STN, 3.5 inches to12.1 inches, up to 1024x768 pixels
- Up to 64K color TFT, 3.5 inches to 12.1 inches, up to1024x768 pixels
- In box NEC 256K color 240x320/3.5 inches TFT screen, with touch screen
Interface and Resource
- 1 10/100M Ethernet RJ-45(DM9000)
- 3 Serial Ports(1 RS232 with CTS and RTS)
- 1 USB Host
- 1 USB Slave Type B
- 1 SD Card Interface
- 1 Stereo audio out, 1 Micro In
- 1 10-Pin JTAG
- 4 USER LEDs
- 6 USER buttons
- 1 PWM Beeper
- 1 POT can be used for A/D converter adjust
- 1 AT24C08 for I2C test
- 1 20-Pin Camera Interface
- 1 Battery for RTC
- Power In(5V), with switch and lamp
Oscillator Freq.
- 12MHz
RTC
- Internal
Expand Interface
- 1 34-Pin 2.0mm GPIO
- 1 40-Pin 2.0mm System Bus
Dimension
- 100 x 100(mm)
OS Support
- Linux 2.6.13
- Windows CE.Net 5.0
2. Content List:
(1) 1 S3C2440 board (Preload with Linux)
(2) 1 Serial cable
(3) 1 Net cable
(4) 1 USB cable
(5) 5V power adapter
(6) 1 JTAG board(for H-JTAG)
(7) 1 DVD-ROM with product reference
(8) 1 NEC LCD: 3.5", 240x320, with touch panel
3. Material list on DVD-ROM
(1) H-JTAG Debugger
(2) Windows Flash Programmer SJF2440
(3) Linux Nand Flash Programmer Jflash-2440(source code included)
(4) Serial tool CRT, dnw
(5) Bitmap to C Language transfer tool
(6) USB Driver(WindowXP/2000)
(7) vivi source code(linux bootloader)
(8) LED test program(ADS1.20 project)
(9) 2440test program(ADS1.20 project), include :
key test, RTC test, ADC test, IIS Audio play(wav), IIS Audio record,
touch screen test, I2C test, Samsung 3.5"LCD, 640x480 TFT test
(10) WindowsCE BSP and sample project files.
(11) Pre-compiled Win CE image for evaluation
(12) Linux tool and kernel source codes
- arm-linux-gcc-3.3.2 to compile Qtopia
- arm-linux-gcc-3.4.1 to compile kernel
- arm-linux-gcc-2.95.3 to compile vivi
- yaffs file system image maker -mkyaffsimage
- linux-2.6.13 for S3C2440 kernel source code(include DM9000, LCD driver, Audio,
Touch screen, YAFFS Source code, SD Card, RTC, Expand serial driver,
USB Camera,USB Mouse and Keyboard, U-Disk)
(13) Pre-compiled Linux image for evaluation
(14) Qtopia source codes, web browser source codes
(15) Schematics(Protel99SE/PDF)
http://cgi.ebay.com/Samsung-S3C2440-ARM9-B...=item27aa521a12
за 88 $,
Кто ни будь побывал данный девайс ?
Что то слишком дешево они стоят :
http://shop.ebay.com/i.html?_trkparms=65%2...br=1&_pgn=1
Сообщение отредактировал SL555 - Oct 12 2009, 08:25
HARMHARM
сообщение Oct 12 2009, 11:16
читатель даташитов
Из: Днепропетровск
Пользователь №: 21 999
Может быть дешево, но не слишком. Я брал какой-то кит на S3C2440 или 2442 у esky-sh. Доставка EMS без проблем за неделю.
Dron_Gus
сообщение Oct 16 2009, 10:25
Пользователь №: 1 861
Если сверху смотреть, то сбоку кажется, что снизу ничего не видно.
DRUID3
сообщение Oct 16 2009, 10:34
山伏
Из: Kyyiv
Пользователь №: 19 294
Нифига себе! За ~90$ это просто мечта. Берите и не задумывайтесь!
Нас помнят пока мы мешаем другим...
Хороший блатной - мертвый...
Нет старик, это те дроиды которых я ищу...
Сергей Борщ
сообщение Jan 8 2010, 15:39
Из: Рига, Латвия
Пользователь №: 17 095
Цитата(Dron_Gus @ Oct 16 2009, 12:25) *
Набрел на производителя: http://www.friendlyarm.net/. Но нигде не могу найти информации о потреблении. Интересует в качестве "мозга" для необслуживаемой системы с удаленным доступом, т.е. интересует потребление без дисплея. Dron_Gus, у вас нет такой информации или возможности измерить?
RobFPGA
сообщение Jan 9 2010, 01:45
Пользователь №: 1 643
Приветствую!
А как такая плата (и аналогичная) могут вести себя в условиях ЭМ помех?
Хочется поставить такой модуль для контроля блока питания. Рюшечки менюшечки - красота. Но блок 15 KWt 5KV.
Чувствую будут проблемы. Как вообще резистивные тачскрины - чувствительны к наводкам и помехам.
Успехов! Rob.
Itch
сообщение Jan 10 2010, 14:59
Из: Новосибирск
Пользователь №: 18 410
Где-то на форуме esky-sh отвечал, что ~300мА
Плата 4 слойка, так что наверное будет сбоить.
Своей пока нету, на днях должны доставить.
Marat_MMX
сообщение Feb 11 2010, 14:16
Пользователь №: 52 564
Во сколько вышло вместе с доставкой, если не секрет?
Itch
сообщение Feb 12 2010, 05:23
Из: Новосибирск
Плата 3.5LCD + камера+WiFi в 139$ с доставкой. Покупал у esky-sh.
Шло правда долго, т.к. по непонятной причине посылка месяц лежала в Китае, потом пнул китайца, он пнул почту и через пару недель наконец-то получил ее smile.gif
Особо пока не разбирался. Удивило обилие деталей на плате дисплея LCD. По умолчанию прошит линукс + Qtopia, все работает очень быстро.
Ток пока не измерял.
Вобщем, думаю, очень неплохой стенд для погружения в Embedded.
З.Ы. У меня обновленная версия платы уже с 128МБ flash, так что ищите такую же.
Vasily_A
сообщение Feb 13 2010, 19:54
Из: Калуга, СССР
Пользователь №: 2 957
а qtopia некитайская под эту плату есть, так чтоб не собирать, а простото готовый имидж скачать?
плата куплена на ебае за примерно $110 с доставкой, шла больше месяца
еще прикол - постоянно используемый нульмодемный шнурок почему то непонравился связке плата-комп, тот что из коробочки - пошел...
общие впечатления - приятные, жаль с фпга и дисплеем одновременно за похожие деньги ничего нет...
еще вопрос - а ftp сложно на ней поднять? стартуем с SD, и правим ее файловую систему по фтп...
Itch
сообщение Feb 15 2010, 05:22
Из: Новосибирск
У меня Qtopia как раз английская, а вот образ CE5.0 на диске китайский.
ftp работает в линуксе сразу, без дополнительных телодвижений.
По поводу токов потребления, стоит WinCE 5.0, напряжение 5 вольт:
плата+LCD = 0.4-0.6А, во время простоя в винде 0.46А
плата без LCD = 0.2-0.35А, во время простоя примерно 0.25А
Vasily_A
сообщение Feb 16 2010, 13:06
Из: Калуга, СССР
скиньте образ английской Qtopia на почту a.vasily@gmail.com
заранее спасибо!
це5 у меня тоже на плате был китайский, но есть английский триальный (а может и полноценный, я не проверял) под эту плату.
могу послать (или ссылку отыскать откуда брал...)
BlackHead
сообщение May 4 2010, 06:25
Пользователь №: 40 058
Хочу узнать, нужен ли дополнительно программатор для этого чудного девайса?
MAXXXX
сообщение May 26 2010, 08:25
Пользователь №: 48 641
Я тоже купил подобный девайс. Установлена Windows 5.0 SE китайская. Диск на 70 процентов на китайском. Не могу понять как к этому киту подступиться. Подскажите где найти инструкцию по переустановке ПО на английском или русском. И вобще интересна любая информация по этому прибору.
kalipso
сообщение May 31 2010, 10:37
Пользователь №: 38 199
Тоже приобрел этот девайс. Покрутил в руках и попробовал установить Qtopia, Android & WinCE 5.0-6.0. Пока остановился на 5-ой винде. Попробовал собрать ядро 5 винды конечно же триал с помощью Платформ Билдера. Все ок. Немного с неточностями собрал, но как факт - получилось. Теперь задача стоит достучаться до портов и встроенных драйверов шины имеющихся на борту проца ну и попутно до всех вкусностей самого процессора. Пока все это пытаюсь сделать таким образом - сама форма приложения для винды пишется на Basic4ppc с подключением dll файла в котором описаны регистры всех вкусностей процессора. В свою очередь dll написана на VB .NET. Понимаю что очень выковыристо, но в линуксе пока не силен (возможно в нем проще).
3 страниц V   1 2 3 >
RSS Текстовая версия Сейчас: 29th August 2025 - 05:04
Страница сгенерированна за 0.01557 секунд с 7
