> usart AVR mega 16, Даж незнаю на что подумать
*SERG
сообщение Jan 12 2006, 17:02
Из: Екатеринбург
Пользователь №: 7 517
Вот прога:
This program was produced by the
CodeWizardAVR V1.24.6 Standard
Automatic Program Generator
© Copyright 1998-2005 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
e-mail:office@hpinfotech.com
Project :
Version :
Date : 12.01.2006
Author : TeleSys Embedded
Company : FastmanSoft Inc.
Comments:
Chip type : ATmega16
Program type : Application
Clock frequency : 16,000000 MHz
Memory model : Small
External SRAM size : 0
Data Stack size : 256
#include <mega16.h>
#include <delay.h>
unsigned char data,peredacha;
// USART Receiver interrupt service routine
interrupt [USART_RXC] void usart_rx_isr(void)
data=UDR;
// USART Transmitter interrupt service routine
interrupt [USART_TXC] void usart_tx_isr(void)
void main(void)
// Declare your local variables here
// Input/Output Ports initialization
// Port A initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTA=0x00;
DDRA=0x00;
// Port B initialization
PORTB=0x00;
DDRB=0x00;
// Port C initialization
PORTC=0x00;
DDRC=0x00;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Normal top=FFh
// OC0 output: Disconnected
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer 1 Stopped
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer 1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer 2 Stopped
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
// INT2: Off
MCUCR=0x00;
MCUCSR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x00;
// USART initialization
// Communication Parameters: 8 Data, 1 Stop, No Parity
// USART Receiver: On
// USART Transmitter: On
// USART Mode: Asynchronous
// USART Baud rate: 9600
UCSRA=0x00;
UCSRB=0xD8;
UCSRC=0x86;
UBRRH=0x00;
UBRRL=0x65;//менять здесь
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
SFIOR=0x00;
OSCCAL=0XFF;
// Global enable interrupts
#asm("sei")
UCSRA=0b00000000;
UCSRB=0b01001000;
while (1)
UDR=peredacha;
peredacha++;
while (UCSRA.5==0)
// Place your code here
[size=1]
[size=1]
Т.е. в порт выдаётся последовательно 00 до FF, даг вот такая проблемма после 0X0D в порт выдаёт 0X0A, а потом уже 0X0E, далее всё идёт как надо, до следущего 0X0D, в чём здесь дело??? blink.gif
Смотрю терминалом CVAVR
Сообщение отредактировал *SERG - Jan 12 2006, 17:04
zltigo
сообщение Jan 12 2006, 17:07
Из: Riga, Latvia
Пользователь №: 1 244
Вот в нем и дело. СR -> CRLF
*SERG
сообщение Jan 12 2006, 17:29
Из: Екатеринбург
Ну вот блин, понятно, спасибо
А зачем это зделали???
zltigo
сообщение Jan 12 2006, 17:45
Из: Riga, Latvia
Для текстового режима опционально включаемая трансляция удобно - незачем гонять два байта.
А в режиме HEX-Dump не отключилось - ошибочка в терминале.
*SERG
сообщение Jan 13 2006, 03:06
Из: Екатеринбург
BVU
сообщение Jan 13 2006, 07:41
Из: Россия, Н.Новгород
Пользователь №: 1 264
Это не ошибка, а соглашение принятого формата для текстового файла: после конца строки на следующую - 0X0D, 0X0A для DOS и Windows. В Unix - 0X0A. Терминал тоже надо настраивать соответственно с наблюдаемыми данными (если таковые настройки предусмотрены). smile.gif
Не корысти ради, не в целях наживы, а во исполнение велений души!
zltigo
сообщение Jan 13 2006, 09:43
Из: Riga, Latvia
Ну если быть занудой....
1. Текстовый/не текстовый _файл_ UNIX/MS здесь ни причем на данном этапе, ибо с файлом мы не работаем, мы работаем с терминалом.
Все проще - сервис предусмотрен для завершения ввода строки одной клавишей
<enter> (^M) а не сочетанием не ^M ^J.
2. И это ошибка, ибо насколько можно понять, терминал попросили распечатывать не смотрибельный текст а сырой поток байтов тем не менн он продолжил преобразовывать CR в CRLF.
WHALE
сообщение Jan 13 2006, 10:53
Из: Краснодар
Пользователь №: 12 768
А че за терминал CVAVR?
"Hello, word!" - 17 errors 56 warnings
RSS Текстовая версия Сейчас: 29th August 2025 - 17:22
Страница сгенерированна за 0.0142 секунд с 7
