> внешние прерывания. помогите плз
123kill12
сообщение Jul 10 2010, 18:19
Пользователь №: 57 217
CODE
#include <intrinsics.h>
#include <stdio.h>
#include <nxp/iolpc1766.h>
#include "board.h"
#pragma section=".intvec"
#define FCCO_FREQ (300UL MHZ)
#define CCKL_DIV (3UL)
#define FCCLK_FREQ (FCCO_FREQ/CCKL_DIV)
#define FPCLK_FREQ (FCCLK_FREQ/4)
#define PCLK FPCLK_FREQ
volatile Int8U LedsState;
Int32U Reg;
void InitClock(void)
// 1. Init OSC
SCS_bit.OSCRANGE = 0;
SCS_bit.OSCEN = 1;
// 2. Wait for OSC ready
while(!SCS_bit.OSCSTAT);
// 3. Disconnect PLL
PLL0CON_bit.PLLC = 0;
PLL0FEED = 0xAA;
PLL0FEED = 0x55;
// 4. Disable PLL
PLL0CON_bit.PLLE = 0;
PLL0FEED = 0xAA;
PLL0FEED = 0x55;
// 5. Select source clock for PLL
CLKSRCSEL_bit.CLKSRC = 1; // Selects the main oscillator as a PLL clock source.
PCLKSEL0 = PCLKSEL1 = 0; // other peripherals 100/4 = 25MHz
// 6. Set PLL settings 300 MHz
PLL0CFG_bit.MSEL = 25-1;
PLL0CFG_bit.NSEL = 2-1;
PLL0FEED = 0xAA;
PLL0FEED = 0x55;
// 7. Enable PLL
PLL0CON_bit.PLLE = 1;
PLL0FEED = 0xAA;
PLL0FEED = 0x55;
// 8. Wait for the PLL to achieve lock
while(!PLL0STAT_bit.PLOCK);
// 9. Set clk divider settings
CCLKCFG = 3-1; // 1/3 Fpll
// 10. Connect the PLL
PLL0CON_bit.PLLC = 1;
PLL0FEED = 0xAA;
PLL0FEED = 0x55;
void GpioInit(void)
// Set to inputs
FIO0DIR = \
FIO1DIR = \
FIO2DIR = \
FIO3DIR = \
FIO4DIR = 0;
// clear mask registers
FIO0MASK =\
FIO1MASK =\
FIO2MASK =\
FIO3MASK =\
FIO4MASK = 0;
// Reset all GPIO pins to default primary function
PINSEL0 =\
PINSEL1 =\
PINSEL2 =\
PINSEL3 =\
PINSEL4 =\
PINSEL7 =\
PINSEL8 =\
PINSEL9 = 0;
Int32U cnt;
void TR0int(void)
cnt=0;
T0MR0=FCCLK_FREQ/200;
T0MCR=3;
SETENA0 |= (1<<1);
IP0=0;
T0TCR=1;
void ExInt(void)
IO2INTENF |= (1<<10);
SETENA0 |= (1<<18);
void TMR0_IRQHandler (void)
T0IR=1;
__enable_interrupt();
cnt++;
if ( cnt >= 0x20)
FIO2PIN = Reg;
Reg=Reg<<1;
if(Reg>128)
FIO2PIN=0;
Reg=4;
cnt = 0;
CLRPEND0 |= ~(1<<1);
void EINT0_IRQHandler (void)
IO2INTCLR |= (1<<10);
__enable_interrupt(); /* handles nested interrupt */
FIO1PIN=0x80000000;
CLRPEND0 |= ~(1<<18);
int main(void)
// Flash accelerator init
FLASHCFG = (0x5UL<<12) | 0x3AUL;
// Init clock
InitClock();
#if FCCLK_FREQ < 20000000
FLASHCFG = (0x0UL<<12) | 0x3AUL;
#elif FCCLK_FREQ < 40000000
FLASHCFG = (0x1UL<<12) | 0x3AUL;
#elif FCCLK_FREQ < 60000000
FLASHCFG = (0x2UL<<12) | 0x3AUL;
#elif FCCLK_FREQ < 80000000
FLASHCFG = (0x3UL<<12) | 0x3AUL;
#elif FCCLK_FREQ < 100000000
FLASHCFG = (0x4UL<<12) | 0x3AUL;
#endif
Reg=4;
// Init GPIO
GpioInit();
ExInt();
TR0int();
// Init LEDs
FIO2DIR = 0x000000ff;
FIO1DIR = 0xF0000000;
while (1)
{ /* Loop forever */
пограмма написана на подобие примеров IAR. работает все кроме внешнего прерывания.
вроде бы все сделал правильно. EINT0 приходится на 10 ножку P2 и флаг разрешения внешнего прерывания 0 находиться на 18 бите регистра разрешений прерываний.
в обработчике прерыванию ставлю брейк поинт и нечего нет(((
(у меня MT-link)
Сообщение отредактировал aaarrr - Jul 10 2010, 18:24
Причина редактирования: Оформление цитаты исходника
zltigo
сообщение Jul 10 2010, 19:03
Из: Riga, Latvia
Пользователь №: 1 244
Программы нужно начинать писать с пяти, максимум с 10 строчек. Причем писать самому, а не копипастить какие-то примеры. И все получится.
DpInRock
сообщение Jul 10 2010, 21:39
Из: Moscow
Пользователь №: 27 515
Причина неработы - невнимательный копипаст.(Пару-тройку нужных процедур не хватат).
И по моему имху - вообще ничего не должно работать. По крайней мере прерывания - не должны.
123kill12
сообщение Jul 10 2010, 22:14
но они работают.
я раньше не работал с ARM вообще. поэтому и спрашиваю может что забыл какой нить флаг.
с прерываниями не сложно настроил и разрешил. таймер пашит, а int0 нет.
zltigo
сообщение Jul 10 2010, 22:30
Из: Riga, Latvia
QUOTE (123kill12 @ Jul 11 2010, 01:14) *
но они работают.
Только в Ваших грезах sad.gif. DpInRock прав - не могут работать прерывания, поскольку они, как минимум, запрещены. Остальную белиберду вообще читать не имеет смысла.
123kill12
сообщение Jul 10 2010, 23:23
да не наяву. я наблюдаю на плате как диодики моргают.
киньте примерный код как запустить внешнее прерывание.
toweroff
сообщение Jul 10 2010, 23:32
Пользователь №: 20 514
а как кинуть в мозг даташит и перевести в С, ASM или на чем там у Вас?
123kill12
сообщение Jul 10 2010, 23:38
я и делал по даташиту. брал пример через дебаг разбирал что куда и зачем пишется и потом свое писал. тока у меня на плате есть int0 кнопка, а пример у IAR для int2. а с таймерами все работало.
Сообщение отредактировал 123kill12 - Jul 10 2010, 23:38
toweroff
сообщение Jul 11 2010, 00:01
бегло так по коду
а чего это прерывания разрешаются в самих прерываниях?
  T0IR=1;
  cnt++;
  if ( cnt >= 0x20)
zltigo
сообщение Jul 11 2010, 00:12
Из: Riga, Latvia
QUOTE (123kill12 @ Jul 11 2010, 02:23) *
Тогда не постите исходники не имеющие отношения к реальности.
123kill12
сообщение Jul 11 2010, 08:20
void TR0int(void)
cnt=0;
T0MR0=FCCLK_FREQ/200; установливаем MR0
T0MCR=3; разрешение прерывания если MR0 и TC совпадают и сброс TC
SETENA0 |= (1<<1); ISER0 записываем 1 в 1 разряд что соответствует разрешению прерывания от timer0
IP0=0; тут не стал нечего придумывать. поставил ноль для всех прерываний
T0TCR=1; TCR нулевой бить ставил м в 1 чтоб запустить таймер на счет
T0IR=1; регистр прерываний. сбрасываем наше самое прерывание по сравнению
__enable_interrupt(); это единственное что я не понял, но сча закоментил и без него работало
cnt++;
CLRPEND0 |= ~(1<<1); записываем в ICPR0 1 в первый разряд
таймер так работает( __enable_interrupt(); и без этой строчки)
void ExInt(void)
IO2INTENF |= (1<<10); устанавливаем прерывание IntEnF
SETENA0 |= (1<<18); ISER0 записываем 1 в 18 разряд что соответствует разрешению прерывания от int0
IO2INTCLR |= (1<<10); очищаем 10 пин intClr
FIO1PIN=0x80000000;
CLRPEND0 |= ~(1<<18); записываем в ICPR0 1 в 18 разряд
нет.
но потом вспомнил что у lpc17xx есть прерывания на портах P0 и P2. которые настраиваются но обработка их в int3. может я как раз так настроил а обрабатывать пытаюсь в int0??
и переделал
void ExInt(void)
SETENA0 |= (1<<21);
void EINT3_IRQHandler (void)
// __enable_interrupt(); /* handles nested interrupt */
FIO1PIN=0x80000000;
CLRPEND0 |= ~(1<<21);
и заработало. алилуя
но возвращаемся в простым int0-int2. как из настроить?
demiurg_spb
сообщение Jul 11 2010, 10:24
неотягощённый злом
Пользователь №: 34 643
FIO1PIN=0x80000000;
Комментарии написаны там где не надо и их нет где надо.
Пока не привыкли стоит одуматься...
ПС оформляйте ваши посты в соответствии с общепринятыми здесь нормами -
выделяйте исходники в секции кода [ code ] ВАШИ ИСХОДНИКИ [ /code ] (пробелы внутри квадратных скобок не нужны)
DpInRock
сообщение Jul 11 2010, 11:47
Из: Moscow
Не поленился (хотя это и очень трудно - папка с иаром очень долго у меня открывается) посмотреть реальные исходники.
Общее и у ваших и оригинальных конечно есть. Но этого недостаточно.
Воин. Будь внимателен при контрол-с контрол-в.
Могу дать совет. берете первую строчку исходника и задаете себе вопрос - "а нафига она нужна". После ответа, переходите к следущей строчке. И так до конца файла. Гарантирую полный успех.
(Я лично языка Си не знаю и только такой подход помогает таки составлять работающие программы на этом языке).
sergeeff
сообщение Jul 12 2010, 06:29
Пользователь №: 4 007
Во, блин, до чего народ дошел!
Wano
сообщение Jul 12 2010, 07:45
Пользователь №: 17 737
Скажите,а в каком месте заносится указатель функции прерывания? Или в LPC17 всё не так как в LPC2?
RSS Текстовая версия Сейчас: 29th August 2025 - 04:14
Страница сгенерированна за 0.01511 секунд с 7
