5 страниц V   1 2 3 > »
> Исправления которые войдут в 8 версию для 900-ки
CADiLO
сообщение Mar 10 2011, 07:25
Из: Днепр
Пользователь №: 7 988
Кстати по просьбе товарищей которые хотели переключаемый режим RI - обратите внимание на пункт 29 - команда CRIPULSE
Есть и не очень хорошая новость - в связи с обнаруженой критической ошибкой в приеме DTMF, будет выпущена дополнительная сборка 8 версии после устранения данной ошибки. SIMCOM извиняется и постарается сделать это как можно скорее.
Обновленые даташиты выложу на сайт сразу по получению.
НОВОЕ
1.
Added "AT+SLEDS" command to configure the flicker frequency of network lights in the status of unregistered, registered or PPP.
2.
Added the value "UR" to the parameter <exunsol> of "AT+EXUNSOL" command to support unsolicited result code.
ИСПРАВЛЕНИЯ
1.
Solved the problem of not reporting "NO ANSWER" in the case of calling the other side who was busy when user set ATS7=15.
2.
Solved the problem that voltage alarm urc was only reported in a logical serial port in MUX mode.
3.
Modified the format of returning information when setting "AT+CENG=3".
4.
Solved the reset problem when user input wrong value of parameter to change the frequency band.
5.
Added AT+CGAS command to increase the speed of GPRS attachment since it is not necessary to re-attach each time.
6.
Fixed the bug that executing ATA command can not pull RI to high level in MUX mode.
7.
Solved the problem that USSD information reported was incorrect found by Indian customer.
8.
Fixed the bug that the local time converted by the time NITZ reported was wrong and ”CI” of operator’s name was wrong.
9.
Optimized the SIDETONE function.
10.
Solved the problem that it would take a long time for network indicator light to flash for some SIM cards when user powered on the module in roaming status.
11.
Solved the problem that unrecognizable code would be reported when user executed the CLCC or CLIP command to get information of an incoming call whose name was saved in the phonebook in UCS2 mode previously.
12.
Solved the problem that there is no response returned from serial port if user executes the following steps: 1. Plug out the SIM card and then dial emergency number. 2. Plug in the SIM card then execute "AT+CFUN=0" command.
13.
Limited the scope of input parameters of "AT+CRLP" command.
14.
Fixed the bug of CLCC, CLIP, CMGR command that Chinese name and English name could not display in UCS2 mode if user sets CSCS to UCS2 mode.
15.
Modified the CPBW command when CSCS was set to HEX mode, the name could be written up to 28 characters.
16.
Limited the scope of input parameters of AT+CALD command.
17.
Modified the error response of AT command "AT+CSTA=", the error response should be "ERROR" instead of "OK".
18.
Solved the problem that the responses of reading empty record in phone book via CPBR command were not consistent.
19.
Modified the response of test command of EXUNSOL by adding the parameter value "UR".
20.
Solved the problem that the module can not register to the network successfully with SIM card of Orange operator when user sets "AT+CBAND="ALL_BAND""
21.
Added the content "resource limitation" of error code 99.
22.
Solved the problem that the calling record of some special number can not be saved in recent call lists.
23.
Solved the problem that the CSD connection can not be established successfully anymore after user dials a number in call record list in CSD mode.
24.
Solved the problem that "CALL READY" will not report in some special conditions when URC presentation was enabled by executing CIURC command.
25.
Исправления касаются служебной команды - информация NDA
26.
Solved the problem that CTS varied when user sent or received AT command with no flow control.
27.
Limited the scope of inputting parameter when executing HTTPREAD and HTTPDATA command in writing mode.
28.
Solved the problem that Shenzhen customer can not originate a phone call or send SMS after a successful call.
29.
Altered the RI pin status when the module reported "RING" of incoming CSD call. If CRIPULSE is set to 1, it presents RI pulse otherwise it is continuously in high level.
30.
Solved the problem that there was no ring back tone if user dialed a number of MAXIS sim card through the CELECOM sim card in Malaysia.
31.
Solved the problem which happened after user sent a sms via AT command accidentally that the module would "freeze" for about 50 seconds before it replied, during that time, the module did not respond to any commands.
32.
Supported GPRS multislot class 2, user is allowed to set class 2 by executing CGMSCLASS command.
33.
Solved the problem that SIM PIN2 couldn’t be modified.
34.
Solved the problem that the module couldn’t attach to the GPRS network if it had activated GPRS previously and then restarted manually.
35.
Solved the problem raised by Shenzhen customer that some special SIM card could not be recognized by the module.
36.
Improved the CENG function to show more neighbor cells.
ssokol
сообщение Mar 10 2011, 08:38
Из: г. Рыбинск, Ярославская область
Пользователь №: 35 028
Наверное еще два месяца ожиданий...
CADiLO
сообщение Mar 10 2011, 09:12
Из: Днепр
Нет, я сейчас с ними активно общаюсь на эту тему и тестирую то что они просят. Думаю это будет гораздо быстрее.
вот еще информация кому интересно
1. Jamming detection won't be standard version, but special version. You have test JD version, if you say ok, we can make a special version bansed on B08 for you.
2. DTMF version will be STANDART version for east europe.
1137B08SIM900M64_ST доступна, получение как обычно
Выложил обновленную RC1 с DTMF - тестируем.
http://microchip.ua/temp/TEST_DTMF_0310V2.RAR
Aurochs
сообщение Mar 10 2011, 09:59
Ортодокс
Из: Смела, Украина
Пользователь №: 31 775
29.
При этом, для сохранения совместимости с существующим ПО, должны обязательно быть выполнены 2 условия:
1. Для CRIPULSE значением по умолчанию д.б. 1
2. CRIPULSE должен сбрасываться в значение по умолчанию командой AT&F
В противном случае уже другая группа товарищей вынуждена будет просить это удалить.
CADiLO
сообщение Mar 10 2011, 10:12
Из: Днепр
замечание принято - напишу производителю
ssokol
сообщение Mar 10 2011, 10:18
Т.е. в этой восьмерке дтмээфа еще нет, будет в следующей сборке?
А еще, уважаемый CADiLO, подскажите можно ли по S2-1040S-Z090C определить версию прошивки (на манер как было в 300ках) и каким образом.
CADiLO
сообщение Mar 10 2011, 10:32
Из: Днепр
S2-1040S-Z090C это 1137B04SIM900M64_ST
У меня есть табличка, но к сожалению выложить не могу.
Но кому нужно определить - спрашивайте - отвечу.
Еще нету - будет что-то наподобии B08Vxx - исправленая восьмерка.
вот пока последняя тестовая часть http://microchip.ua/temp/TEST_DTMF_0310V2.RAR
DTMF я проверил - в основном работает, далее тестируем сообща.
как только скажем что нам подходит, его внесут в 8 версию.
Velund
сообщение Mar 10 2011, 11:16
Пользователь №: 1 177
QUOTE (CADiLO @ Mar 10 2011, 13:32) *
Хотелось бы понять с какой версией S2-1040S-Z090М...
CADiLO
сообщение Mar 10 2011, 11:17
Из: Днепр
S2-1040S-Z090M = 1137B06SIM900M64_ST
Velund
сообщение Mar 10 2011, 11:33
QUOTE (CADiLO @ Mar 10 2011, 14:17) *
Спасибо!
ssokol
сообщение Mar 10 2011, 19:15
Пока заметил нижеследующее:
Call Ready
AT+DDET=1
OK
AT+DDET?
+DDET: 1
OK
AT+DDET=2 ????????????????????????????????????????????
+DDET:
OK
AT+DDET?
+DDET: 1
OK
Заметил, так же , что DDET не сохраняется по &W , т.е. так и задумано?
Короче,еще глюки...
Когда сим900 звонит на сотовый, после поднятия трубы на сотовом слышен в динамике "пум", дтмф при этом работает, звонил много раз, каждый раз начинает определять. Когда с сотового звоню на сим300, делаю ата, в динамике сотового слышен "пум" - после этого дтмф определяется, НО не всегда, примерно раза два из десяти при звонке на сим900 "пум" нет и дтмф не определяется, до тех пор пока не позвоню снова. Более того, позвонил на сим900, ата, и просто слушаю- стабильно, с интервалом 15 сек, в динамике сотового слышу "пум". Причем когда позвонил на сим900 и дтмф не определяется, "пум" с интервалом в 15 сек отсутствует.
Так же заметил несколько раз сообщения +DTMF:C +DTMF:D хотя у меня и кнопок то таких нет.
CADiLO
сообщение Mar 11 2011, 06:38
Из: Днепр
Да - определение должно включаться только на нужную сессию соединения. Поэтому сбрасывается и не сохраняется.
По поводу постороннего звука я тоже заметил, уже написал китайцам.
ssokol
сообщение Mar 11 2011, 08:20
Посторонний звук то - это пол беды, но то, что именно при звонке на сим900 не всегда включается определение дтмф - это очень плохо.
И DDet=2 то же как то странно...
Хотя остальное все классно, даже город определяет без вранья, задержки перед определением устраивают.
CADiLO
сообщение Mar 11 2011, 09:06
Из: Днепр
Я описал проблему полностью и подтвердил ее от себя - сейчас там разбираются.
Думаю или зададут дополнительные вопросы или пришлют следующую версию на тестирование.
По крайней мере эту тему мы доведем до конца и нормальное декодирование будет.
Могу сказать что эта проблема на контроле и у ихнего руководства - Венди уже спрашивала что достигнуто в плане работоспособности.
AT+DDET=2
Этот режим только для запроса последних определенных цифр - состояние 2 не запоминается.
Можно только запрашивать сколько угодно.
0 или 1 запоминается - кстати в первых версиях было только на текущую сессию, сейчас вроде уже до отключения.
<mode>
0 disable
1 enable
2 Record the total DTMF tones in the last call
Disable& enable will only take effect when set in non-active call status.
"2" is to record the tones in last call, which can record max 100 tones. It will restart from 0 when exceeding 100.
пришло исправление - проверяем - http://microchip.ua/temp/TEST_DTMF_0311.RAR
ssokol
сообщение Mar 11 2011, 18:59
"ПУМ" действительно не слышно, но проблема, когда иногда при звонке на сим900 дтмф не определяется - остается.
Кстати, заметил, что чаще это происходит если ата делать после первого ring.
RSS Текстовая версия Сейчас: 31st August 2025 - 13:44
Страница сгенерированна за 0.01506 секунд с 7
