> Помогите советом SAM7s256 шьется нормально, SAM7s128 - не хотят ни в какую!, Несколько экземпляров - логи одинаковые
Димон Безпарольн...
сообщение Mar 30 2011, 13:27
Пользователь №: 61 247
Лог SAM7s128
- Initializing CPU core (Init sequence) ...
- Initialized successfully
- JTAG speed: 8000 kHz (Auto)
- CPU clock frequency: 32 kHz (Auto detected)
- J-Link found 1 JTAG device. Core ID: 0x3F0F0F0F (ARM7)
- Connected successfully
Programming and verifying target (7108 bytes, 1 range) ...
- Programming target (7108 bytes, 1 range) ...
- ERROR: Write memory error @ address 0x00200000, word access: Memory access timeout.
Failed to verify RAMCode for CPU clock frequency detection!
- ERROR: RAM check failed @ address 0x00200000.
- ERROR: Write: 0xE7FEE7FD E083E069
- ERROR: Read: 0xAAAAAAAA AAAAAAAA
- ERROR: (0 bytes of RAM have been checked successfully)
- ERROR: Failed to program target
- ERROR: Failed to program and verify target
Disconnecting ...
- Disconnected
Лог SAM7s256
Connecting ...
- Connecting via USB to J-Link device 0
- J-Link firmware: V1.20 (J-Link compiled Jul 30 2008 11:24:37 ARM Rev.5)
- CPU clock frequency: 2312 kHz (Auto detected)
- Target programmed successfully
- Verifying target (7108 bytes, 1 range) ...
- All loaded bytes verified OK!
- Target programmed and verified successfully - Completed after 0.451 sec
Закипел я.
RSS Текстовая версия Сейчас: 30th July 2025 - 13:28
Страница сгенерированна за 0.01361 секунд с 7
