> Проблема с переносом проекта на GCC
igorenja
сообщение Jun 30 2011, 15:38
Из: Новосибирск
Пользователь №: 39 488
Доброе время суток!
Возникла необходимость переноса проекта написанного под IAR на CodeSourcery.
Написал Makefile все вроде бы компилируется но с ликером проблема.
arm-none-eabi-g++ -nostartfiles -mcpu=cortex-m0 -mthumb -Wl,--gc-sections -T lpc1xxx/memory.ld -o release/Exe/mtv.elf release/Obj/temperature.o release/Obj/ccanopenobjectdictionary.o release/Obj/cgpio.o release/Obj/cwatchdog.o release/Obj/tools.o release/Obj/main.o release/Obj/csdoserver.o release/Obj/cuart.o release/Obj/csysticktimer.o release/Obj/system.o release/Obj/ccriticalsection.o release/Obj/cadc.o release/Obj/cspi.o release/Obj/ccan.o release/Obj/cflashat25.o release/Obj/cresult.o release/Obj/cstorage.o release/Obj/ccanopen.o release/Obj/cflashcopier.o release/Obj/LPC11xx_handlers.o release/Obj/LPC1xxx_startup.o
/opt/arm-2011.03/bin/../lib/gcc/arm-none-eabi/4.5.2/../../../../arm-none-eabi/lib/armv6-m/libc.a(lib_a-abort.o): In function `abort':
abort.c:(.text+0xa): undefined reference to `_exit'
/opt/arm-2011.03/bin/../lib/gcc/arm-none-eabi/4.5.2/../../../../arm-none-eabi/lib/armv6-m/libc.a(lib_a-fstatr.o): In function `_fstat_r':
fstatr.c:(.text+0xe): undefined reference to `_fstat'
/opt/arm-2011.03/bin/../lib/gcc/arm-none-eabi/4.5.2/../../../../arm-none-eabi/lib/armv6-m/libc.a(lib_a-sbrkr.o): In function `_sbrk_r':
sbrkr.c:(.text+0xc): undefined reference to `_sbrk'
/opt/arm-2011.03/bin/../lib/gcc/arm-none-eabi/4.5.2/../../../../arm-none-eabi/lib/armv6-m/libc.a(lib_a-signalr.o): In function `_kill_r':
signalr.c:(.text+0xe): undefined reference to `_kill'
/opt/arm-2011.03/bin/../lib/gcc/arm-none-eabi/4.5.2/../../../../arm-none-eabi/lib/armv6-m/libc.a(lib_a-signalr.o): In function `_getpid_r':
signalr.c:(.text+0x2a): undefined reference to `_getpid'
/opt/arm-2011.03/bin/../lib/gcc/arm-none-eabi/4.5.2/../../../../arm-none-eabi/lib/armv6-m/libc.a(lib_a-writer.o): In function `_write_r':
writer.c:(.text+0x10): undefined reference to `_write'
/opt/arm-2011.03/bin/../lib/gcc/arm-none-eabi/4.5.2/../../../../arm-none-eabi/lib/armv6-m/libc.a(lib_a-closer.o): In function `_close_r':
closer.c:(.text+0xc): undefined reference to `_close'
/opt/arm-2011.03/bin/../lib/gcc/arm-none-eabi/4.5.2/../../../../arm-none-eabi/lib/armv6-m/libc.a(lib_a-isattyr.o): In function `_isatty_r':
isattyr.c:(.text+0xc): undefined reference to `_isatty'
/opt/arm-2011.03/bin/../lib/gcc/arm-none-eabi/4.5.2/../../../../arm-none-eabi/lib/armv6-m/libc.a(lib_a-lseekr.o): In function `_lseek_r':
lseekr.c:(.text+0x10): undefined reference to `_lseek'
/opt/arm-2011.03/bin/../lib/gcc/arm-none-eabi/4.5.2/../../../../arm-none-eabi/lib/armv6-m/libc.a(lib_a-readr.o): In function `_read_r':
readr.c:(.text+0x10): undefined reference to `_read'
collect2: ld returned 1 exit status
make: *** [all] Error 1
Когда линкер запускается без стартапа выше обозначенных ошибок нет.
Стартап и скрипт линкера во вложении
Всем откликнувшимся заранее спасибо
AHTOXA
сообщение Jun 30 2011, 16:48
фанат дивана
Из: Уфа
Пользователь №: 29 684
http://electronix.ru/forum/index.php?showt...st&p=651990
igorenja
сообщение Jul 1 2011, 10:10
Из: Новосибирск
Цитата(AHTOXA @ Jun 30 2011, 23:48) *
Спасибо огромное. Подложил файл, скомпилировал, сборка прошла успешно. Но есть одно "НО" Размер бинарника 120кБ. У меня памяти без начального загрузчика осталось 24кБ. Может быть подскажете чем может быть вызвано такое разростание прошивки (В iar бинарник был 17кБ)
Опции компилятора:
arm-none-eabi-g++ -ffunction-sections -fdata-sections -fmessage-length=0 -DTARGET=LPC11xx -fno-builtin -Wall -O2 -c -mcpu=cortex-m0 -mthumb  -I. -I./io -I./wlib -I./system ccan.cpp -o release/Obj/ccan.o
Сергей Борщ
сообщение Jul 1 2011, 13:22
Из: Рига, Латвия
Пользователь №: 17 095
QUOTE (igorenja @ Jul 1 2011, 13:10) *
(s)printf?
AHTOXA
сообщение Jul 1 2011, 13:42
фанат дивана
Из: Уфа
Да, это такой у arm-gcc printf. Он тянет за собой malloc и кучу всего прочего. Замените его чем-нибудь попроще.
Не забыли к ключам компилятора -ffunction-sections -fdata-sections добавить ключ линкера -Wl,--gc-sections ?
igorenja
сообщение Jul 1 2011, 14:38
Из: Новосибирск
Цитата(Сергей Борщ @ Jul 1 2011, 20:22) *
(s)printf?
нет там такого добра
Единственное что я использую из библиотек это memove strcmp memset memcpy... ключ линкера есть
AHTOXA
сообщение Jul 1 2011, 15:06
фанат дивана
Из: Уфа
ftoa/dtoa? Чисто виртуальные функции? Исключения?
igorenja
сообщение Jul 1 2011, 15:21
Из: Новосибирск
Цитата(AHTOXA @ Jul 1 2011, 22:06) *
ftoa/dtoa? Исключения?
Нет
Есть... А что с ними не в порядке?
AHTOXA
сообщение Jul 1 2011, 15:29
фанат дивана
Из: Уфа
Они тоже много чего за собой тянут. Решение - тут.
IgorKossak
сообщение Jul 1 2011, 16:07
Шаман
Из: Киев, Украина
Пользователь №: 221
rand()?
igorenja
сообщение Jul 2 2011, 04:15
Из: Новосибирск
непомогло
Цитата(IgorKossak @ Jul 1 2011, 23:07) *
rand()?
нет.
AHTOXA
сообщение Jul 2 2011, 05:14
фанат дивана
Из: Уфа
Цитата(igorenja @ Jul 2 2011, 10:15) *
непомогло
igorenja
сообщение Jul 2 2011, 06:04
Из: Новосибирск
Цитата(AHTOXA @ Jul 2 2011, 12:14) *
Убрал, таже хрень.... Решил собрать хеллоуворлд и постепенно добавлять туда свои файлы. Глядишь и найду в чём дело... rolleyes.gif
Genadi Zawidowsk...
сообщение Jul 3 2011, 23:06
Из: Санкт-Петербург, Россия
Пользователь №: 28 634
гнусный хак: вставить в любой файл программы.
char __aeabi_unwind_cpp_pr0 [0];
Если библиотека собрана с обработкой ексепшинов... В сборке klen не требуется.
У меня тянуло за собой printf 64-битное деление целых чисел.
Сообщение отредактировал Genadi Zawidowski - Jul 3 2011, 23:09
Genadi Zawidowsk...
сообщение Jul 10 2011, 08:43
Цитата(igorenja @ Jul 2 2011, 10:04) *
Нашли? Моё предложение попробовали?
RSS Текстовая версия Сейчас: 27th August 2025 - 22:29
Страница сгенерированна за 0.02415 секунд с 7
