> Посылка по CAN в STM32F3
Jenya7
сообщение Aug 17 2018, 09:56
Пользователь №: 71 075
Настраиваю CAN
CODE
void CAN_Setup(void)
GPIO_InitTypeDef GPIO_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
CAN_InitTypeDef CAN_InitStructure;
CAN_FilterInitTypeDef CAN_FilterInitStructure;
/* CAN GPIOs configuration **************************************************/
/* Enable GPIO clock */
RCC->AHBENR |= RCC_AHBPeriph_GPIOB;
/* Connect CAN pins to AF9 */
GPIO_PinAFConfig(GPIOB, GPIO_PinSource8, GPIO_AF_9);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource9, GPIO_AF_9);
/* Configure CAN RX and TX pins */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8| GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
GPIO_Init(CAN_GPIO_PORT, &GPIO_InitStructure);
/* NVIC configuration *******************************************************/
NVIC_InitStructure.NVIC_IRQChannel = USB_LP_CAN1_RX0_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
NVIC_InitStructure.NVIC_IRQChannel = CAN1_RX1_IRQn;
/* CAN configuration ********************************************************/
/* Enable CAN clock */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);
/* CAN register init */
CAN_DeInit(CAN1);
CAN_StructInit(&CAN_InitStructure);
// CAN cell init
CAN_InitStructure.CAN_TTCM = DISABLE;
CAN_InitStructure.CAN_ABOM = DISABLE;
CAN_InitStructure.CAN_AWUM = DISABLE;
CAN_InitStructure.CAN_NART = DISABLE;
CAN_InitStructure.CAN_RFLM = DISABLE;
CAN_InitStructure.CAN_TXFP = DISABLE;
CAN_InitStructure.CAN_Mode = CAN_Mode_Normal;
/* CAN Baudrate = 1MBps (CAN clocked at 36 MHz) */
CAN_InitStructure.CAN_BS1 = CAN_BS1_9tq;
CAN_InitStructure.CAN_BS2 = CAN_BS2_8tq;
CAN_InitStructure.CAN_Prescaler = 2;
CAN_InitStructure.CAN_SJW = CAN_SJW_1tq;
//CAN_InitStructure.CAN_BS1 = CAN_BS1_3tq;
//CAN_InitStructure.CAN_BS2 = CAN_BS2_5tq;
//CAN_InitStructure.CAN_Prescaler = 39;
//CAN_InitStructure.CAN_SJW = 2;
CAN_Init(CANx, &CAN_InitStructure);
/* CAN filter init */
CAN_FilterInitStructure.CAN_FilterNumber = 0;
CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask;
CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_32bit;
CAN_FilterInitStructure.CAN_FilterIdHigh = 0x0000;
CAN_FilterInitStructure.CAN_FilterIdLow = 0x0000;
CAN_FilterInitStructure.CAN_FilterMaskIdHigh = 0x0000;
CAN_FilterInitStructure.CAN_FilterMaskIdLow = 0x0000;
CAN_FilterInitStructure.CAN_FilterFIFOAssignment = 0;
CAN_FilterInitStructure.CAN_FilterActivation = ENABLE;
CAN_FilterInit(&CAN_FilterInitStructure);
/* Enable FIFO 0 message pending Interrupt */
CAN_ITConfig(CANx, CAN_IT_FMP0, ENABLE);
/* Enable FIFO 1 message pending Interrupt */
CAN_ITConfig(CANx, CAN_IT_FMP1, ENABLE);
Посылаю
    TxMessage.StdId = ( (0x100 *(i+1)) + CAN_COM_WHO_IS);
    TxMessage.DLC = 1;
    TxMessage.RTR = CAN_RTR_DATA;
    TxMessage.IDE = CAN_ID_STD;
     CAN_Transmit(CAN1, &TxMessage);
В функции посылки - все мейлбоксы заняты - я попадаю в transmit_mailbox = CAN_TxStatus_NoMailBox;
CODE
uint8_t CAN_Transmit(CAN_TypeDef* CANx, CanTxMsg* TxMessage)
uint8_t transmit_mailbox = 0;
/* Check the parameters */
assert_param(IS_CAN_ALL_PERIPH(CANx));
assert_param(IS_CAN_IDTYPE(TxMessage->IDE));
assert_param(IS_CAN_RTR(TxMessage->RTR));
assert_param(IS_CAN_DLC(TxMessage->DLC));
/* Select one empty transmit mailbox */
if ((CANx->TSR&CAN_TSR_TME0) == CAN_TSR_TME0)
else if ((CANx->TSR&CAN_TSR_TME1) == CAN_TSR_TME1)
transmit_mailbox = 1;
else if ((CANx->TSR&CAN_TSR_TME2) == CAN_TSR_TME2)
transmit_mailbox = 2;
else
if (transmit_mailbox != CAN_TxStatus_NoMailBox)
/* Set up the Id */
CANx->sTxMailBox[transmit_mailbox].TIR &= TMIDxR_TXRQ;
if (TxMessage->IDE == CAN_Id_Standard)
assert_param(IS_CAN_STDID(TxMessage->StdId));
CANx->sTxMailBox[transmit_mailbox].TIR |= ((TxMessage->StdId << 21) | \
TxMessage->RTR);
else
assert_param(IS_CAN_EXTID(TxMessage->ExtId));
CANx->sTxMailBox[transmit_mailbox].TIR |= ((TxMessage->ExtId << 3) | \
TxMessage->IDE | \
TxMessage->RTR);
/* Set up the DLC */
TxMessage->DLC &= (uint8_t)0x0000000F;
CANx->sTxMailBox[transmit_mailbox].TDTR &= (uint32_t)0xFFFFFFF0;
CANx->sTxMailBox[transmit_mailbox].TDTR |= TxMessage->DLC;
/* Set up the data field */
CANx->sTxMailBox[transmit_mailbox].TDLR = (((uint32_t)TxMessage->Data[3] << 24) |
((uint32_t)TxMessage->Data[2] << 16) |
((uint32_t)TxMessage->Data[1] << 8) |
((uint32_t)TxMessage->Data[0]));
CANx->sTxMailBox[transmit_mailbox].TDHR = (((uint32_t)TxMessage->Data[7] << 24) |
((uint32_t)TxMessage->Data[6] << 16) |
((uint32_t)TxMessage->Data[5] << 8) |
((uint32_t)TxMessage->Data[4]));
/* Request transmission */
CANx->sTxMailBox[transmit_mailbox].TIR |= TMIDxR_TXRQ;
return transmit_mailbox;
Если принимающая сторона не приняла мейлбокс он не освободился ?
Сообщение отредактировал IgorKossak - Aug 19 2018, 20:06
Причина редактирования: [codebox] для длинного кода, [code] - для короткого!
Obam
сообщение Aug 17 2018, 15:47
Пользователь №: 83 663
Коллега, вы хрензнает сколько лет на форуме, листинг в (1024 по вертикали) 4 экрана - перебор. Ну хоть чуть-чуть уважения к окружающим.
Пролетарий умственного труда.
esaulenka
сообщение Aug 17 2018, 16:02
Из: Маськва
Пользователь №: 35 877
Цитата(Obam @ Aug 17 2018, 18:47) *
листинг ... - перебор
Листинг - это единственная полезная часть исходного сообщения.
Если его выкинуть (спрятать), останется просто бессмысленное "у меня не работает".
Тут обсуждается творческий порыв, а не соответствие каким-либо стандартам ©
x893
сообщение Aug 17 2018, 18:20
Из: Планета Земля
Пользователь №: 41 226
Цитата(Jenya7 @ Aug 17 2018, 12:56) *
Настраиваю
Да
Jenya7
сообщение Aug 19 2018, 07:31
для отладки я изменил случай когда все мейлбоксы заняты
else
    //force pending messages to be sent anyway
    CANx->sTxMailBox[0].TIR |= TMIDxR_TXRQ;
    CANx->sTxMailBox[1].TIR |= TMIDxR_TXRQ;
    CANx->sTxMailBox[2].TIR |= TMIDxR_TXRQ;
я становлюсь скопом на ножку CAN_TX и не вижу никаких выходящих сигналов. что происходит? кто может объяснить?
Jenya7
сообщение Sep 13 2018, 13:02
CAN по прежнему не работает.Вопрос - нужно ли чистить флаги в прерывании? я за основу взял пример где флаги не чистяться.
void USB_LP_CAN1_RX0_IRQHandler(void)
  can_params.message_received = 1;
  can_params.fifo_num = CAN_FIFO0;
void CAN1_RX1_IRQHandler(void)
  can_params.fifo_num = CAN_FIFO1;
Jenya7
сообщение Sep 17 2018, 04:59
CAN заработал. надо было перемычку замкнуть на пин 8 конвертора.
Другая проблема. При приеме слейв через какое то время отсыхает. Я смотрю на ESR и вижу что TEC увеличивается при каждом принятии пакета, хотя данные пришли, иногда уменьшается но чаще увеличивается. Когда TEC = 0xFF прием отсыхает и LEC = 5.
Как бороться с этой бедой?
Alechek
сообщение Sep 17 2018, 05:27
Из: Челябинск
Пользователь №: 10 882
Ничего тут не напутано? На прием REC работает, на передачу TEC.
Сдается мне, что физически что-то как-то не так подключено.
Физический интерфейс имеется?
Резистор в линии имеется?
Jenya7
сообщение Sep 17 2018, 06:04
я вижу приходящие сообщения от мастера. слейв ему отвечает и ответ я тоже вижу. Вы говорите TEC - это значит слейв послал с ошибкой?
Alechek
сообщение Sep 17 2018, 10:11
Из: Челябинск
Цитата(Jenya7 @ Sep 17 2018, 11:04) *
CAN контроллер всегда слушает линию. Если вдруг в линии не то, что мы ожидали (коллизия), передатчик сообщает об ошибке.
Доминатное состояние достигается за счет драйвера, рецессивное за счет нагрузки в линии.
Для подтверждения приема служит бит ACK, его генерирует приемник, он контролируется передатчиком.
Передатчик по-умолчанию будет посылать сообщение, пока его кто-нибудь не примет (или достигнется лимит TEC)
Контроллер в STM32 можно настроить так, чтобы сообщение он принял, а АСК бит не выдал и даже не проконтролировал!
Полагаю, где-то тут ваш случай.
Передачу данных очень наглядно отображает даже дешевый логический анализатор.
Jenya7
сообщение Sep 17 2018, 10:35
с анализатором (USB-CAN Plus) мастер работает нормально. да и данными мастер-слейв вроде как обмениваются. бес его знает что там CANу не нравиться.
я что то не нашел где там АСК отменить. я отменил бесперерывную посылку (NART =1). послал один раз и все, не фиг линию грузить.
Сообщение отредактировал Jenya7 - Sep 17 2018, 11:07
редактор
сообщение Sep 17 2018, 12:47
Пользователь №: 28 315
Почитайте спецификацию на CAN?хотя бы в русском переводе.
Хорошую систему делают из стандартных блоков нестандартно мыслящие инженеры.
Jenya7
сообщение Sep 17 2018, 14:11
я могу читать отсюда и до Урала, там регистров с гулькин нос. все биты просмотрел.
adnega
сообщение Sep 17 2018, 18:48
Из: Ярославль, Россия
Пользователь №: 27 702
Может, это
Silent mode
The bxCAN can be put in Silent mode by setting the SILM bit in the CAN_BTR register.
In Silent mode, the bxCAN is able to receive valid data frames and valid remote frames, but
it sends only recessive bits on the CAN bus and it cannot start a transmission. If the bxCAN
has to send a dominant bit (ACK bit, overload flag, active error flag), the bit is rerouted
internally so that the CAN Core monitors this dominant bit, although the CAN bus may
remain in recessive state. Silent mode can be used to analyze the traffic on a CAN bus
without affecting it by the transmission of dominant bits (Acknowledge Bits, Error Frames).
Jenya7
сообщение Sep 18 2018, 04:49
Цитата(adnega @ Sep 18 2018, 00:48) *
Может, это
спасибо. попробую.
RSS Текстовая версия Сейчас: 28th April 2024 - 14:50
Страница сгенерированна за 0.01596 секунд с 7
