вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 044
Fixed CCRs: SPB 17.2 HF044
07-27-2018
CCRID Product ProductLevel2 Title
1943727 ADW DBEDITOR EDM DBEditor: Cannot check in/out schematic model symbols with many linked parts
1800630 ADW FLOW_MGR Support spaces in design directory path on Windows
1951052 ADW LRM LRM stops responding on project update and removes parts from design
1891428 ADW PART_MANAGER Resistor turns into a capacitor when placed
1945194 ALLEGRO_EDITOR 3D_CANVAS 3D Viewer crashes when opening from board file.
1935558 ALLEGRO_EDITOR INTERFACES Exported STEP file missing components when viewed in free STEP viewer
1945640 ALLEGRO_EDITOR MULTI_USER Symphony client disconnects from server without any notification
1948454 ALLEGRO_EDITOR MULTI_USER Window DRC stops responding when run in Symphony
1946619 ALLEGRO_EDITOR SHAPE Pin/via with suppressed pad on shape layer and thermal connection type of none should void to drill hole.
1946708 ALLEGRO_EDITOR SHAPE Same net hole to shape voiding is incorrect.
1952213 ALLEGRO_EDITOR SHAPE Shape voiding from Thru Via when the via regular pad is not completely drilled out by Backdrill hole is not consistent
1889433 ALLEGRO_EDITOR UI_GENERAL Command window shows result at the end of a command rather than showing dynamic updates
1933503 ALLEGRO_EDITOR UI_GENERAL Extra click required to enable command window
1943692 ALLEGRO_EDITOR UI_GENERAL Funckey commands are not working
1945914 ALLEGRO_EDITOR UI_GENERAL Mouse focus lost in the command console when doing an 'undo' from the toolbar icon
1945920 ALLEGRO_EDITOR UI_GENERAL Focus lost from command window when the toolbar is used for any operation
1949922 ALLEGRO_EDITOR UI_GENERAL Focus lost from command window after save or even autosave
1947551 ALLEGRO_EDITOR WIREBOND PCB Editor crashes in wirebond edit mode
1935722 ALLEGRO_PROD_TOOLB OTHERS Panelization: Cannot place parts after migrating design from release 16.6 to 17.2-2016
1951511 APD REPORTS The result of Metal Usage Report is incorrect.
1952942 ASDA GRAPHICS Need metric (mm) support in grids in SDA
1948122 ASDA TDO If user ID has uppercase characters in teamassignmenttemplate.xml, TDO fails to join a project
1931199 CONCEPT_HDL COPY_PROJECT Stop hard coding Copy Project license inside EDM
1938153 CONCEPT_HDL OTHER Component Browser stops responding on replacing and modifying components
1770601 CONCEPT_HDL PDF Wire Pattern set to two-dot chain line not shown in PDF
1791175 PCB_LIBRARIAN CORE Allow baseline of cells with pins at symbol origin: change error to warning
1922238 PCB_LIBRARIAN CORE Unable to check in into EDM Server due to con2con error SPLBPD-323 - Origin on pin connection point
1936812 PCB_LIBRARIAN GRAPHICAL_EDI New Symbol Editor: Wrong text being updated when editing text after copy and paste
1804159 PCB_LIBRARIAN SYMBOL_EDITOR Copy and paste of pins in new symbol editor: issues with pin name, rotation, and move
1927422 PCB_LIBRARIAN SYMBOL_EDITOR Symbol outline not updated correctly in the new default graphic editor in Part Developer release 17.2-2016
1939272 PCB_LIBRARIAN SYMBOL_EDITOR Symbol Editor changes origin to bottom left, outline to invisible, shows rectangle with center rectangle at new origin
1928076 RF_PCB DISCRETE_LIBX dlibx2iff does not work with managed libraries and library-level PTF
1929574 RF_PCB DISCRETE_LIBX Discrete Library to third-party Translator does not populate the Available Parts section correctly
1850360 TDA CORE TDO crashes while changing the root design
1934388 TDA SDA SDA TDO crashes on attempting to check in a 'New Block in Shared Area'
