> перевод кода программы с ASM на СИ
Valdemar4ik
сообщение Mar 16 2012, 15:41
Пользователь №: 70 537
Доброе время суток!
Помогите плиз перевести код программы с Ассемблера на С.Заранее благодарю.
; PROCESSOR DECLARATION
     LIST      P=PIC18F26K20         ; list directive to define processor
     #INCLUDE <P18F26K20.INC>        ; processor specific variable definitions
; CONFIGURATION WORD SETUP
    ;Setup CONFIG11H
     CONFIG FOSC = INTIO67, FCMEN = OFF, IESO = OFF
    ;Setup CONFIG2L
     CONFIG PWRT = ON, BOREN = OFF, BORV = 18
    ;Setup CONFIG2H
     CONFIG WDTEN = OFF, WDTPS = 1
    ;Setup CONFIG3H
     CONFIG MCLRE = ON, HFOFST = OFF, LPT1OSC = OFF, PBADEN = OFF
    ;Setup CONFIG4L
     CONFIG CCP2MX = PORTBE, STVREN = OFF, LVP = OFF, XINST = OFF, DEBUG = OFF
    ;Setup CONFIG5L
     CONFIG CP0 = OFF, CP1 = OFF, CP2 = OFF, CP3 = OFF
    ;Setup CONFIG5H
     CONFIG CPB = OFF, CPD = OFF
    ;Setup CONFIG6L
     CONFIG EBTR0 = OFF
    ;Setup CONFIG6H
     CONFIG EBTR1 = OFF
    ;Setup CONFIG7L
     CONFIG EBTR2 = OFF
    ;Setup CONFIG7H
     CONFIG EBTR3 = OFF
; VARIABLE DEFINITIONS
W_TEMP          EQU             0x0000 ; w register for context saving (ACCESS)
STATUS_TEMP     EQU             0x0001 ; status used for context saving
BSR_TEMP        EQU             0x0002; bank select used for ISR context saving
TMR1_l          EQU             0x0060
TMR1_h          EQU             0x0061
TMR1_u          EQU             0x0062
RT_TEMP         EQU             0x0063
ITERATOR        EQU             0x0064
PROGRAM_4       EQU             0x0065
PROGRAM_2       EQU             0x0066
PROGRAM_1       EQU             0x0067
PORT_ON         EQU             0x0068
PORT_OFF        EQU             0x0069
PORT_4Hz        EQU             0x006A
PORT_2Hz        EQU             0x006B
PORT_1Hz        EQU             0x006C
PORT_TEMP       EQU             0x006D
; RESET VECTOR
RES_VECT
        ORG     0x0000           ; processor reset vector
        goto    start            ; go to beginning of program
; HIGH PRIORITY INTERRUPT VECTOR
ISRH
        ORG     0x0008
        goto    HIGH_ISR                 ; Run the High Priority Interrupt Service Routine
; LOW PRIORITY INTERRUPT VECTOR
ISRL
        ORG     0x0018
        goto    LOW_ISR          ; Run the Low Priority Interrupt Service Routine
        ORG     0x0020
READ_TABLE:
        movwf   RT_TEMP
        rlncf   RT_TEMP,0
        addwf   PCL,    1
TABLE_PROGRAMM
        nop
        retlw   b'11111111'
        retlw   b'01010101'
        retlw   b'00010001'
; HIGH PRIORITY INTERRUPT SERVICE ROUTINE
HIGH_ISR
         ; Context Saving for High ISR
        movwf   W_TEMP             ; save W register
        movff   STATUS, STATUS_TEMP; save status register
        movff   BSR, BSR_TEMP      ; save bankselect register
         ; Insert High Priority ISR Here
        btfsc   PIR1,   TMR1IF         ; TMR1 interrupt?
        call    TMR1_Interrupt         ; YES
         ; Restore Context for High ISR
        movf    W_TEMP, 0          ; restore W register
        movff   STATUS_TEMP, STATUS; restore status register
        movff   BSR_TEMP, BSR      ; restore bank select register
        retfie
; LOW PRIORITY INTERRUPT SERVICE ROUTINE
LOW_ISR
         ; Context Saving for Low ISR
         ; Insert Low Priority ISR Here
        retfie
; MAIN PROGRAM
start
        clrf    PORTB
        clrf    TRISB                  ; PORTB,0-7 - out
        clrf    PORT_TEMP
        call    GET_PROGRAM
        call    GET_VALUE_PORT_DEFAULT
        call    TIMER1_Init
        call    GET_PRESCALER_FOR_TMR1
        bsf     RCON,   IPEN           ; Enable priority levels on interrupts
        bsf     INTCON, GIE            ; Enable interrupts
MAIN
        goto    MAIN
GET_PROGRAM                            ;Reading program
        lfsr    FSR0, PROGRAM_1
        movlw   0x03
        movwf   ITERATOR
READ_TABLE_PROGRAMM
        movf    ITERATOR,0
        call    READ_TABLE
        movwf   POSTDEC0
        decfsz  ITERATOR,1
        bra     READ_TABLE_PROGRAMM
        return
        movlw   b'10000000'    ;PORTB 7 - ON
        movwf   PORT_ON
        movlw   b'00010000'    ;PORTB 4 - OFF
        movwf   PORT_OFF
        movlw   b'00100011'    ;PORTB 0,1,5 - 1Hz
        movwf   PORT_1Hz
        movlw   b'00001000'    ;PORTB 3     - 2Hz
        movwf   PORT_2Hz
        movlw   b'01000100'    ;PORTB 2,6   - 4Hz
        movwf   PORT_4Hz
        return
TIMER1_Init
        movlw   0x80                   ; Preload TMR1 register pair
        movwf   TMR1H
        clrf    TMR1L
        movlw   b'00001001'    ; Configure for internal clock,
        movwf   T1CON          ; Asynchronous operation, Internal oscillator
        bsf     PIE1,   TMR1IE         ; Enable Timer1 interrupt
        bsf     IPR1,   TMR1IP         ; Timer1 High priority
        return
        movlw   0x01
        movwf   TMR1_l
        movlw   0x00
        movwf   TMR1_h
        movlw   0x00
        movwf   TMR1_u
        return
TMR1_Interrupt
        bcf     PIR1,   TMR1IF         ; clear TMR1 Overflow Interrupt Flag bit
        dcfsnz  TMR1_l, 1
        return
        dcfsnz  TMR1_h, 1
        return
        dcfsnz  TMR1_u, 1
        return
        call    SET_VALUE_PORT_USING_PROGRAM
        return
                                                       ;PORT_TEMP='xxxxxxxx'
        movf    PORT_ON,        0              ;PORT_ON=  '10000000'
        iorwf   PORT_TEMP,      1      ;PORT_TEMP='1xxxxxxx'
        comf    PORT_OFF,       0              ;PORT_OFF= '00010000'
        andwf   PORT_TEMP,      1      ;PORT_TEMP='1xx0xxxx'
        lfsr    FSR1, PORT_1Hz
        movlw   0x03
        movwf   ITERATOR
READ_PROGRAMM
        movf    POSTDEC1,       0
        btfsc   INDF0,          0
        xorwf   PORT_TEMP,      1      ;PORT_TEMP='1ii0iiiii'
        rrncf   POSTDEC0,       1
        decfsz  ITERATOR,1
        bra     READ_PROGRAMM
        movf    PORT_TEMP,      0
        movwf   PORTB
        return
    END
Сергей Борщ
сообщение Mar 16 2012, 17:59
Из: Рига, Латвия
Пользователь №: 17 095
QUOTE (Valdemar4ik @ Mar 16 2012, 17:41) *
Простите, помочь или сделать вашу работу за вас? "помочь" - это когда сам почти все сделал, но непонятны какие-то детали. А с вашей постановкой задачи вам надо в раздел "предлагаю работу".
RSS Текстовая версия Сейчас: 20th July 2025 - 17:36
Страница сгенерированна за 0.01369 секунд с 7
