Всем привет! Осваиваю ПЛИС. Чип XC6SLX9-3TQG144C, SPI флеш память AT45DB041D. Среда Xilinx ISE Design Suite 13.4, программирую IMPACT -ом
В саму плисину все прекрасно загружается и прошивка работает. При попытке запрограммировать флеш память
'1': Erasing device... done. '1': Erasure completed successfully. INFO:iMPACT - Address 0x00000000 is in sector 0. INFO:iMPACT - Address 0x00053393 is not located at the start of a sector boundary. The whole sector will be erased. INFO:iMPACT - Address 0x00053393 is in sector 6. INFO:iMPACT - Address 0x00000000 is in sector 0. INFO:iMPACT - Address 0x00053393 is not located at the start of a sector boundary. The whole sector will be erased. INFO:iMPACT - Address 0x00053393 is in sector 6. INFO:iMPACT - Address 0x00000000 is in sector 0. INFO:iMPACT - Address 0x00053393 is not located at the start of a sector boundary. The whole sector will be erased. INFO:iMPACT - Address 0x00053393 is in sector 6. INFO:iMPACT - Address 0x00000000 is in sector 0. INFO:iMPACT - Address 0x00053393 is not located at the start of a sector boundary. The whole sector will be erased. INFO:iMPACT - Address 0x00053393 is in sector 6. INFO:iMPACT - Address 0x00000000 is in page 0. INFO:iMPACT - Address 0x00053393 is in page 1291. '1': Programming Flash...done. '1': Programming completed successfully. INFO:iMPACT - Address 0x00000000 is in page 0. INFO:iMPACT - Address 0x00053393 is in page 1291. '1': Verifying device...done. '1': Verification completed successfully. '1': Configuration data download to FPGA was not successful. DONE did not go high, please check your configuration setup and mode settings. INFO:iMPACT - '1': Flash was not programmed successfully. PROGRESS_END - End Operation. Elapsed time = 98 sec.
Сбой программирования. При этом флешка стирается и проверяется командой Blank Chek без ошибок. Вся схемотехника подключения флешки к плисине вроде сделана по Spartan-6 FPGA Configuration User Guide, только DONE не подтянут к Vcc, а висит на этом выводе светодиод с резистором на землю.
Подскажите что я делаю не так, заранее спасибо.
