SIM900 пересоединение с помощью AT+SAPBR |
Mar 20 2013, 06:24
Пользователь №: 52 029
прошивка модуля - Revision:1137B09SIM900M64_ST_DTMF_JD_MMS, пытаюсь переустановить соединение, где ошибка ? Код 20.03.2013 08:28:25.168 [TX] - AT+CUSD=1,"*111#"<CR>
20.03.2013 08:28:25.188 [RX] - AT+CUSD=1,"*111#"<CR> <CR><LF> OK<CR><LF> <CR><LF> +CUSD: 0,"Na rahunku: 32.73 grn. Info pro bonusy na *112# i *119#.<LF> Zahysty svoju pryvatnist'! Zamov "Dodatkovyj nomer": 477*76*<LF> ",64<CR><LF>
20.03.2013 08:28:51.086 [TX] - AT+CREG?<CR>
20.03.2013 08:28:51.118 [RX] - AT+CREG?<CR> <CR><LF> +CREG: 0,1<CR><LF> <CR><LF> OK<CR><LF>
20.03.2013 08:29:06.414 [TX] - AT+SAPBR=3,1,"Contype","GPRS"<CR><LF>
20.03.2013 08:29:06.442 [RX] - AT+SAPBR=3,1,"Contype","GPRS"<CR><LF> <CR><LF> OK<CR><LF>
20.03.2013 08:29:09.598 [TX] - AT+SAPBR=3,1,"APN","www.ab.kyivstar.net"<CR><LF>
20.03.2013 08:29:09.625 [RX] - AT+SAPBR=3,1,"APN","www.ab.kyivstar.net"<CR><LF> <CR><LF> OK<CR><LF>
20.03.2013 08:29:12.839 [TX] - AT+SAPBR=3,1,"USER",""<CR>
20.03.2013 08:29:12.872 [RX] - AT+SAPBR=3,1,"USER",""<CR> <CR><LF> OK<CR><LF>
20.03.2013 08:29:13.614 [TX] - AT+SAPBR=3,1,"PWD",""<CR>
20.03.2013 08:29:13.640 [RX] - AT+SAPBR=3,1,"PWD",""<CR> <CR><LF> OK<CR><LF>
20.03.2013 08:29:18.046 [TX] - AT+SAPBR=1,1<CR><LF>
20.03.2013 08:29:18.071 [RX] - AT+SAPBR=1,1<CR><LF> <CR><LF> ERROR<CR><LF>
20.03.2013 08:29:19.781 [TX] - AT+SAPBR=2,1<CR><LF>
20.03.2013 08:29:19.815 [RX] - AT+SAPBR=2,1<CR><LF> <CR><LF> +SAPBR: 1,3,"0.0.0.0"<CR><LF> <CR><LF> OK<CR><LF>
20.03.2013 08:29:24.830 [TX] - AT+SAPBR=0,1<CR><LF>
20.03.2013 08:29:24.853 [RX] - AT+SAPBR=0,1<CR><LF> <CR><LF> ERROR<CR><LF>
Mar 20 2013, 17:46
Пользователь №: 18 920
Проверить AT+CGATT? Должен быть +CGATT: 1 И повторить AT+SAPBR=1,1
Mar 22 2013, 06:21
спасибо, то что нужно Код 22.03.2013 08:17:51.767 [TX] - AT+CGATT?<CR>
22.03.2013 08:17:51.787 [RX] - AT+CGATT?<CR> <CR><LF> +CGATT: 0<CR><LF> <CR><LF> OK<CR><LF>
22.03.2013 08:20:37.199 [TX] - AT+CGATT=1<CR>
22.03.2013 08:20:37.224 [RX] - AT+CGATT=1<CR> <CR><LF> OK<CR><LF>
22.03.2013 08:20:49.849 [TX] - AT+SAPBR=2,1<CR><LF>
22.03.2013 08:20:49.878 [RX] - AT+SAPBR=2,1<CR><LF> <CR><LF> +SAPBR: 1,3,"0.0.0.0"<CR><LF> <CR><LF> OK<CR><LF>
22.03.2013 08:20:51.824 [TX] - AT+SAPBR=1,1<CR><LF>
22.03.2013 08:20:51.845 [RX] - AT+SAPBR=1,1<CR><LF> <CR><LF> OK<CR><LF>
22.03.2013 08:20:54.880 [TX] - AT+SAPBR=2,1<CR><LF>
22.03.2013 08:20:54.901 [RX] - AT+SAPBR=2,1<CR><LF> <CR><LF> +SAPBR: 1,1,"10.131.6.124"<CR><LF> <CR><LF> OK<CR><LF>
Apr 9 2013, 17:02
Цитата(AndyTrof @ Mar 22 2013, 09:21)  спасибо, то что нужно Код 22.03.2013 08:17:51.767 [TX] - AT+CGATT?<CR>
22.03.2013 08:20:54.901 [RX] - AT+SAPBR=2,1<CR><LF> <CR><LF> +SAPBR: 1,1,"10.131.6.124"<CR><LF> <CR><LF> OK<CR><LF> при этой же последовательности команд модуль при AT+SAPBR=1,1<CR><LF> стал возвращать ERROR. Денег достаточно, в железе ничего не менялось. В каком направлении копать ?
Apr 10 2013, 17:19
Из: BG
Пользователь №: 43 375
Цитата(AndyTrof @ Apr 9 2013, 20:02)  при этой же последовательности команд модуль при AT+SAPBR=1,1<CR><LF> стал возвращать ERROR. Денег достаточно, в железе ничего не менялось. В каком направлении копать ? С начале надо : AT+SAPBR=1,1 - open bearer а потом ( 2 - 3 sec delay): AT+SAPBR=2,1 - get IP
Nov 27 2013, 15:10
Пользователь №: 69 438
у меня тоже мистика. после прошивки на новую прошивку модуль перестал конектится к инету. вернул старую прошивку а ничего так и не поменялось. прошивал модем с подключеной СИМ картой. может после прошивки нужно выполнить какие-то спец команды? если устанавливать AT+SAPBR=1,1 в цикле то даже через 1000 итераций ответа ОК не будет. Код AT
at&f ОК
atz0 ОК
ATE0 OK
AT+GMR Revision:1137B06SIM900M64_ST OK AT+CREG? +CREG:0,1OK AT+CSCA? +CSCA:"+380672021111",145OK AT+CMGF=1 OK
AT+CSQ +CSQ:9,0OK AT+CUSD=1, "*111#", 15 +CUSD:0,"Narahunku:0.68grn.Infoprobonusyna*112#i*119#." OK AT+SAPBR=3,1,"CONTYPE","GPRS" OK AT+SAPBR=3,1,"APN","www.djuice.com.ua" OK AT+SAPBR=3,1,"USER","" OK AT+SAPBR=3,1,"PWD","" OK
AT+CGATT? +CGATT:1 OK
AT+SAPBR=1,1 ERROR AT+SAPBR=2,1 +SAPBR:1,3,"0.0.0.0"OK AT+HTTPINIT OK AT+HTTPPARA="CID",1 OK AT+HTTPPARA="URL","http://heating.sumdu.edu.ua/i/_index.php?n=1" OK AT+HTTPACTION=0 OK AT+HTTPREAD OK AT+HTTPTERM OK
Dec 6 2013, 08:25
Цитата(Цырен. @ Dec 5 2013, 08:29)  Я бы: 1. обновился до B11 или B02_ENHANCE 2. Добавил денег на счет (я не знаю, 0.68грн - это мало?) обновился до 1137B01SIM900D64_ST_ENHANCE пополнил счет команда AT+SAPBR=1,1 все равно возвращает ERROR но модем загружает страницу из интернета. заметил такую закономерность: 1) если сеанс связи происходит раз в 10мин, то передача прекращается после достижения баланса 0,00грн 2) если сеанс связи происходит раз в час, то передача прекращается если на счету осталось 1,03грн видимо в первом случае соединение GPRS не прерывается. и еще заметил не корректную работу функции SMS Autorun после получения модемом AT команды он отправляет ответ каждых 5 минут
