> Восстановление I2C (stm32)
Boriska
сообщение Mar 22 2013, 18:07
Пользователь №: 32 772
Пытаюсь вернуть i2c в рабочее состояние после сбоя.
В апп ноте написано:
The procedure is as follows:
1) Master tries to assert a Logic 1 on the SDA line
2) Master still sees a Logic 0 and then generates a clock
pulse on SCL (1-0-1 transition)
3) Master examines SDA. If SDA = 0, go to Step 2; if
SDA = 1, go to Step 4
4) Generate a STOP condition
Note that this process may need to be repeated because
the cleared SDA line may have been cleared for the next
bit, which was a 1. There may be some concern about the
effect this additional clocking and STOPping has on other
peripherals. There is no adverse effect; other slaves are
not paying attention due to the fact that they have not
been addressed. Only the slave that had the interrupted
message will respond to the clocks.
Сделал так:
GPIO_PinAFConfig(GPIO_SCL, GPIO_PinSource_SCL, 0); //GPIO_AF_I2Cx
    GPIO_PinAFConfig(GPIO_SDA, GPIO_PinSource_SDA, 0); //GPIO_AF_I2Cx
    //Configure and initialize the GPIOs
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_SCL;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
    GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
    GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_NOPULL;
    GPIO_Init(GPIO_SCL, &GPIO_InitStructure);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_SDA;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
    GPIO_Init(GPIO_SDA, &GPIO_InitStructure);
    i=0;
    while((GPIO_ReadInputDataBit(GPIO_SDA,GPIO_Pin_SDA)==0)&&(i<20)){
        GPIO_ResetBits(GPIO_SCL,GPIO_Pin_SCL);
        delay10us(1);
        GPIO_SetBits(GPIO_SCL,GPIO_Pin_SCL);
        delay10us(1);
        i++;
    sEE_LowLevel_Init();
Подскажите, где может быть ошибка в реализации? И как можно инициировать сбой, чтобы отладить данный код?
RSS Текстовая версия Сейчас: 7th August 2025 - 14:10
Страница сгенерированна за 0.0136 секунд с 7
