> Немного цен на измериловку
Guest_bestcomps4u_*
сообщение Apr 17 2013, 07:08
Guests
Sweep Generators
HP 8340A/006/007, 10 MHz to 26.5 GHz $4 945
Agilent 83623B/004/008, 10 MHz to 20 GHz, High Power $15 255
HP 83640L/001, 10 MHz to 40 GHz, High Performance $21 280
HP 83650B/001, 10 MHz to 50 GHz, High Performance $25 760
HP 83650L/001/008, 10 MHz to 50 GHz, High Performance $23 520
HP 83651B, 10 MHz to 50 GHz, HPIB only $17 250
HP 83751B/1E1, 2-20 GHz, 1E1 adds step attenuator, +17 dBm $14 950
HP 83752A/1E1, .01-20 GHz, 1E1 adds attenuator, +10 dBm $8 625
Gigatronics 7200, 10 MHz to 40 GHz $11 385
Rohde & Schwarz SME03/B19 Signal Generator, 5 KHz to 3 GHz $2 013
Wiltron 68169B/2B, 10 MHz to 40 GHz, to +13 dBm $18 400
Oscilloscopes
HP 54506B, 300 MHz, 2 channel, 500 MS/s $1 750
HP 54600B, 100 MHz, 2 channel, 20 MS/s $1 120
HP 54624A, 100 MHz, 4 channel, 250 MS/s $1 680
HP 54645D, 100 MHz, 2 channel, plus 16-channel Logic Analyzer $1 960
HP 54831D, 600 MHz, 4 channel, with 16-channel Logic Analyzer $8 060
HP 54846A, 2.25 GHz, 4 channel, 8 Gs/s $6 345
Agilent DSO6104L/8MH, 1 GHz, 4 channel, Low Profile $6 160
Agilent MSO6012A, 100 MHz, 2 channel, w/16 Ch. Logic Analyzer $2 940
Tektronix TDS3032, 300 MHz, 2 channel, 2.5 Gs/s $2 520
Tektronix TDS520/13/1M, 500 MHz, 2 channel, 500 Ms/s $1 463
Tektronix TDS540C, 500 MHz, 4 channel, /13/1F/1M/2F/2C $2 940
Tektronix TDS7054/1M, 500 MHz, 4 channel, 5 Gs/s $8 060
Spectrum Analyzers
Agilent E4403B/B72/A4H, 9 kHz to 3.0 GHz $5 750
Anritsu MS610C, 10 kHz to 2 GHz $2 100
HP 8560A, 30 Hz to 2.9 GHz $4 500
HP 8560A/002, 50 Hz to 2.9 GHz, High Performance, option 002 adds tracking generator $7 935
HP 8561B, 50 Hz to 6.5 GHz $4 140
HP 8563E, 9 kHz to 26.5 GHz, High Performance $9 085
HP 8564E, 9 kHz to 40 GHz, High Performance $19 550
HP 8564EC, 9 kHz to 40 GHz, High Performance $22 885
HP 8565E/005/007/008, 9 kHz to 50 GHz, High Performance $24 725
HP 8566B, 100 Hz to 22 GHz, High Performance $3 848
HP 8590B/001/021, 9 KHz to 1.8 GHz, HPIB, 75 Ohm $1 823
HP 8592A, 50 kHz to 22 GHz $4 025
HP 8592L/021, 9 KHz to 22 GHz, w/HPIB $4 600
HP 8594E, 9 KHz to 2.9 GHz $3 120
HP 8595E/041, 9 KHz to 6.5 GHz $4 255
HP 8596E/004/021/105/151, 9 KHz to 12.8 GHz, Precision Frequency Reference, HPIB, Time gated, Digital Demodulator $5 175
Network Analyzers
HP 3577A, 5 Hz to 200 MHz $2 160
HP 85025D Detector, .01-50 GHz, for use with 8757D $2 025
HP 85037B Detector, .01-26.5 GHz $1 485
HP 85050A Calibration Kit, 7mm $1 337
HP 85052D Calibration Kit, 3.5mm, .045 to 26.5 GHz $4 500
HP 8712ES/1EC, 300 kHz to 1.3 GHz, S-Parameter, 75 Ω $7 360
HP 8752A, 300 KHz to 1.3 GHz, Transmission/Reflection $4 485
HP 8752C/006, 300 KHz to 6 GHz, Transmission/Reflection $6 785
HP 8753C/010 Network Analyzer, 300 kHz to 3 GHz, option 010 Time Domain $4 140
HP 8753ES/11 Vector Network Analyzer, 30 kHz to 3 GHz $9 085
HP 8756A Scalar Network Analyzer, 10 MHz to 40 GHz $863
HP 8757D Scalar Network Analyzer, to 110 GHz $5 750
HP E8357A/010/015, VNA, 300 kHz to 6 GHz, Time Domain $16 675
Logic Analyzers
Agilent 16754A Module, 4 GHz/600 MHz/ 68 channel $1 050
HP 1660AS, Logic Analyzer/O’scope, 136 channel, 500 MHz timing/100 MHz state, plus 2-channel O’scope $2 450
HP 1661AS, Logic Analyzer/O’scope, 102 channel, 500 MHz timing/100 MHz state, plus 1 Gs/s 2-ch. O’scope $1 750
HP 1662A, 68 channel, 500 MHz timing/100 MHz state $700
HP 16700A, Logic Analyzer Mainframe, 5 slots $770
HP 16700B/003, Logic Analyzer Mainframe, 5 slots, with performance upgrade $910
HP 1670G, 136 channel, 250 MHz timing $3 500
HP 1672A, 68 channel, 250 MHz/70 MHz $1 050
HP 54620A, 16 channel, 500 Ms/s $1 120
Multimeters & Counters
HP 3468A, 5.5 Digit Multimeter $290
HP 53181A, Frequency Counter, 0-225 MHz, 10 Digits, GPIB $1 146
HP 53181A/015, Frequency Counter, 0-1.5 GHz, 3 Channel, GPIB $1 305
HP 5348A/002, Frequency Counter/Power Meter, 10 Hz to 26.5 GHz, option 002 adds battery pack $2 465
HP 5350A/001/006, Frequency Counter, 10 Hz to 20 GHz, with High Stability Time Base $2 103
HP 5351B, Frequency Counter, 10 Hz to 26.5 GHz $1 233
HP 5352B Frequency Counter, 10 Hz to 40 GHz $3 038
Philips PM6654C/16, 0-1.5 GHz Counter/Timer $1 233
Power Supplies
HP 6236B, Triple Output, 0-20V/0-20V/0-6V, meters $300
HP 6264B, 0-20V/0-20A, meters $525
HP 6284A, 0-20V/0-3A $225
HP 66000 Power Supply Mainframe $1 170
HP 66001A MPS Keyboard $300
HP 66102A Module, 0-20V/0-7.5A $863
HP 6621A, Dual Output, 0-7V/10A or 0-20V/4A, HPIB $375
HP 6623A, Triple Output, 2 ea 0-20V/0-2A, 0-50V/0-.8A, 80W, HPIB $338
HP 6627A, 4 outputs, 2 ea 0-20V/2A, 2 ea 0-50V/.8A, GPIB $525
HP 6671A/J1H, 0-5V/0-250A, HPIB $1 425
Kepco OPS55-10M, 0-55V/0-10A $300
Sorensen XTS 30-2, 0-30V/0-2A, LCD $263
Xantrex XT15-4, 0-15V/0-4A, LCD $263
Доставка и растаможка не включена, в среднем порядка $50 за 1 кг. Все детали мылом cis@bestcomps4u.com
- bestcomps4u   Немного цен на измериловку   Apr 17 2013, 07:08
RSS Текстовая версия Сейчас: 22nd July 2025 - 02:45
Страница сгенерированна за 0.01364 секунд с 7
