> STM32F4: ADC Interleaved + DMA
Brain13
сообщение May 31 2013, 12:28
Пользователь №: 52 078
Подобные темы уже поднимались, но уже приведенные исходники у меня так и не заработали стабильно.
Плата STM32F4Discovery.
Имеется код:
CODE
void init()
ADC_InitTypeDef ADC_InitStructure;
DMA_InitTypeDef DMA_InitStructure;
GPIO_InitTypeDef GPIO_InitStructure;
ADC_CommonInitTypeDef ADC_CommonInitStructure;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 | RCC_AHB1Periph_GPIOC, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_ADC2 |
RCC_APB2Periph_ADC3, ENABLE);
/* Configure ADC Channel 12 pin as analog input */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
GPIO_Init(GPIOC, &GPIO_InitStructure);
DMA_InitStructure.DMA_Channel = DMA_Channel_0;
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC_CDR_ADDRESS;
DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&ADCConvertedValue;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
DMA_InitStructure.DMA_BufferSize = adc_buffer_count;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
DMA_Init(DMA2_Stream0, &DMA_InitStructure);
/* DMA2_Stream0 enable */
DMA_Cmd(DMA2_Stream0, ENABLE);
/* ADCs configuration: triple interleaved with 5cycles delay to reach 6Msps */
/* ADC Common configuration *************************************************/
ADC_CommonInitStructure.ADC_Mode = ADC_TripleMode_Interl;
ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_1;
ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
ADC_CommonInit(&ADC_CommonInitStructure);
/* ADC1 regular channel 12 configuration ************************************/
ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
ADC_InitStructure.ADC_ScanConvMode = DISABLE;
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
ADC_InitStructure.ADC_ExternalTrigConv = 0;
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
ADC_InitStructure.ADC_NbrOfConversion = 1;
ADC_Init(ADC1, &ADC_InitStructure);
ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 1, ADC_SampleTime_3Cycles);
/* Enable ADC1 DMA */
ADC_DMACmd(ADC1, ENABLE);
/* ADC2 regular channel 12 configuration ************************************/
ADC_Init(ADC2, &ADC_InitStructure);
/* ADC2 regular channel12 configuration */
ADC_RegularChannelConfig(ADC2, ADC_Channel_11, 1, ADC_SampleTime_3Cycles);
/* ADC3 regular channel 12 configuration ************************************/
ADC_Init(ADC3, &ADC_InitStructure);
/* ADC3 regular channel12 configuration *************************************/
ADC_RegularChannelConfig(ADC3, ADC_Channel_11, 1, ADC_SampleTime_3Cycles);
/* Enable DMA request after last transfer (multi-ADC mode) ******************/
ADC_MultiModeDMARequestAfterLastTransferCmd(ENABLE);
/* Enable ADC1 **************************************************************/
ADC_Cmd(ADC1, ENABLE);
/* Enable ADC2 **************************************************************/
ADC_Cmd(ADC2, ENABLE);
/* Enable ADC3 **************************************************************/
ADC_Cmd(ADC3, ENABLE);
/* Start ADC1 Software Conversion */
ADC_SoftwareStartConv(ADC1);
int main()
for(int i=0;i<adc_buffer_count;i++)
ADCConvertedValue[i] = 0;
init();
delay(10000000);
for(;;);
return 0;
Изменения относительно примера в комплекте STMF4 Periferial Lib: DMA в режиме normal, режим доступап dma 1.
Частоты настроены: SYSCLK 144 МГц, APB2 72 МГц, APB1 36 МГц.
На PC1 подаю меандр 32кГц.
Ставлю брейкпоинт на строке "for(;;);", массив ADCConvertedValue заполнен значениями.
Но вот в чем странность: Между период меандра судя по отсчетам АЦП - ровно 300 отсчетов. То есть: Частота семплирования 300*32000 = 9,6 МГц.
Что многовато.
Есть и вторая странность. Такое ощущение, что отсчеты складываются в неправильном порядке, привожу кусок массива(повторяющиеся значения убрал):
CODE
переменная тип значение
ADCConvertedValue[144] short 4
ADCConvertedValue[145] short 3
ADCConvertedValue[146] short 4
ADCConvertedValue[147] short 4095
ADCConvertedValue[148] short 4095
ADCConvertedValue[149] short 4
ADCConvertedValue[150] short 4095
ADCConvertedValue[151] short 4095
ADCConvertedValue[152] short 4095
ADCConvertedValue[153] short 4095
ADCConvertedValue[154] short 4095
ADCConvertedValue[292] short 4095
ADCConvertedValue[293] short 4095
ADCConvertedValue[294] short 4095
ADCConvertedValue[295] short 4095
ADCConvertedValue[296] short 10
ADCConvertedValue[297] short 4095
ADCConvertedValue[298] short 4095
ADCConvertedValue[299] short 16
ADCConvertedValue[300] short 4
ADCConvertedValue[301] short 12
ADCConvertedValue[302] short 16
ADCConvertedValue[303] short 2
ADCConvertedValue[304] short 3
ADCConvertedValue[305] short 3
Видно дергание сигнала при переходе из единицы в ноль и обратно. Иногда получается без дергания.
Мозг уже кипит, не могу найти ошибку. Подскажите в чем дело.
Сообщение отредактировал Brain13 - May 31 2013, 12:29
RSS Текстовая версия Сейчас: 23rd July 2025 - 01:02
Страница сгенерированна за 0.01363 секунд с 7
