> Трабл с gcc, avr-gcc-462 avrlibc-1.7.1 трабл
Errorkpi
сообщение Jul 3 2013, 13:16
Пользователь №: 47 659
avr-gcc-462 avrlibc-1.7.1 трабл состоит в следующем не находит файлы с описанием контроллера:
Текст ошибки:
cannot find crtm16.o: Нет такого файла или каталога
Процесс компиляции с ключем -v
**** Build of configuration Debug for project test5 ****
make all
Building file: ../main.c
Invoking: AVR Compiler
avr-gcc-462 -v -Wall -g2 -gstabs -O0 -fpack-struct -fshort-enums -std=gnu99 -funsigned-char -funsigned-bitfields -mmcu=atmega16 -DF_CPU=1000000UL -MMD -MP -MF"main.d" -MT"main.d" -c -o "main.o" "../main.c"
Using built-in specs.
COLLECT_GCC=avr-gcc-462
COLLECT_LTO_WRAPPER=/opt/cross/avr/lib/gcc/avr/4.6.2/lto-wrapper
Target: avr
Configured with: ../gcc-4.6.2/configure -v --prefix=/opt/cross/avr --exec-prefix=/opt/cross/avr --libdir=/opt/cross/avr/lib --libexecdir=/opt/cross/avr/lib --mandir=/opt/cross/avr/share/man --infodir=/opt/cross/avr/share/info --with-gnu-ld --with-gnu-as --target=avr --enable-languages=c,c++ --program-prefix=avr- --program-suffix=-462 --with-sys-root=/opt/cross/avr --disable-nls --disable-libssp --with-dwarf2 --without-ppl --without-cloog
Thread model: single
Finished building: ../main.c
gcc version 4.6.2 (GCC)
COLLECT_GCC_OPTIONS='-v' '-Wall' '-g2' '-gstabs' '-O0' '-fpack-struct' '-fshort-enums' '-std=gnu99' '-funsigned-char' '-funsigned-bitfields' '-mmcu=atmega16' '-D' 'F_CPU=1000000UL' '-MMD' '-MP' '-MF' 'main.d' '-MT' 'main.d' '-c' '-o' 'main.o'
/opt/cross/avr/lib/gcc/avr/4.6.2/cc1 -quiet -v -imultilib avr5 -MMD main.d -MF main.d -MP -MT main.d -D F_CPU=1000000UL ../main.c -quiet -dumpbase main.c -mmcu=atmega16 -auxbase-strip main.o -g2 -gstabs -O0 -Wall -std=gnu99 -version -fpack-struct -fshort-enums -funsigned-char -funsigned-bitfields -o /tmp/ccn0f7nh.s
Building target: test5.elf
Invoking: AVR C Linker
avr-gcc-462 -Wl,-Map,test5.map -mmcu=atmega16 -o "test5.elf"  ./main.o
GNU C (GCC) version 4.6.2 (avr)
    compiled by GNU C version 4.3.4 [gcc-4_3-branch revision 152973], GMP version 4.2.3, MPFR version 2.3.2, MPC version 0.8.2
warning: GMP header version 4.2.3 differs from library version 4.3.2.
warning: MPFR header version 2.3.2 differs from library version 2.4.2.
warning: MPC header version 0.8.2 differs from library version 0.8.1.
GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072
ignoring nonexistent directory "/opt/cross/avr/lib/gcc/avr/4.6.2/../../../../avr/sys-include"
ignoring nonexistent directory "/opt/cross/avr/lib/gcc/avr/4.6.2/../../../../avr/include"
#include "..." search starts here:
#include <...> search starts here:
/opt/cross/avr/lib/gcc/avr/4.6.2/include
/opt/cross/avr/lib/gcc/avr/4.6.2/include-fixed
End of search list.
Compiler executable checksum: 7b378730845ee03e3aeeace7c8a64cfc
/opt/cross/avr/lib/gcc/avr/4.6.2/../../../../avr/bin/as -v -mmcu=atmega16 -o main.o /tmp/ccn0f7nh.s
GNU assembler version 2.23.1 (avr) using BFD version (GNU Binutils) 2.23.1
COMPILER_PATH=/opt/cross/avr/lib/gcc/avr/4.6.2/:/opt/cross/avr/lib/gcc/avr/4.6.2/:/opt/cross/avr/lib/gcc/avr/:/opt/cross/avr/lib/gcc/avr/4.6.2/:/opt/cross/avr/lib/gcc/avr/:/opt/cross/avr/lib/gcc/avr/4.6.2/../../../../avr/bin/
LIBRARY_PATH=/opt/cross/avr/lib/gcc/avr/4.6.2/avr5/:/opt/cross/avr/lib/gcc/avr/4.6.2/:/opt/cross/avr/lib/gcc/avr/4.6.2/../../../../avr/lib/
/opt/cross/avr/lib/gcc/avr/4.6.2/../../../../avr/bin/ld: cannot find crtm16.o: Нет такого файла или каталога
/opt/cross/avr/lib/gcc/avr/4.6.2/../../../../avr/bin/ld: cannot find -lc
collect2: ld returned 1 exit status
make: *** [test5.elf] Ошибка 1
RSS Текстовая версия Сейчас: 26th June 2025 - 16:56
Страница сгенерированна за 0.01604 секунд с 7
