2 страниц V  < 1 2
> SIM900 в роли модема для ПК(через COM port)
_saper_
сообщение Jan 9 2014, 16:58
Пользователь №: 36 228
Waldelk мне кажется что wvdial именно то что мне нужно. буду надеяться что в ядре планшета уже всё есть))
нашел даже коекакие инструкции
1) I never could get a 100% stable 3G connection 24/7 running. Sometimes they lose the connections (sometimes the provider is responsible for it, sometimes the usb-dongle itself). Newer dongles are better.
2) After testing betavine, and some other tools … I went back to wvdial … easy and 99% stable
3) you need 3 files wvdial & USB_ModeSwitch & USB_ModeSwitch_data.
Important: wvdial has to be build for the Arm architecture, I don`t know, if this is done for the Raspberry Pi … if not (maybe larson ??? should contact carl at excito, who has done this for the excito bubba)
4) usb-dongle, there are a lot dongles on the market, but the often are the same. To start I would suggest a dongle which is not brand-new and
Important: it should be in the USB_ModeSwitch_data, it saves a lot of time
5) Install wvdial & USB_ModeSwitch & USB_ModeSwitch_data per
apt-get install …
6) Edit wvdial.conf with your provider data (this example is for drei.at)
------ /etc/wvdial.conf --------------
Code: Select all
[Dialer Defaults]
Area Code =
Ask Password = 0
Auto DNS = 1
Baud = 460800
Carrier Check = 0
Compuserve = 0
Dial Command = ATD
DialMessage1 =
DialMessage2 =
Force Address =
ISDN = 0
Idle Seconds = 3000
Init1 = ATZ
Init2 = ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0
Init3 = AT+CGDCONT=1,"IP","drei.at"
Modem = /dev/ttyUSB0
Modem Type = Analog Modem
New PPPD = yes
Password = ;
Phone = *99#
Stupid Mode = 1
Username = ;
Auto Reconnect = On
------ end of /etc/wvdial.conf ------
The best way is *NOT* to use SIM pin codes
6) Edit /etc/network/interfaces and add this lines:
auto ppp0
iface ppp0 inet wvdial
7) Test
Type * wvdial * and you should get a connection
Contrl Z and then type bg
restart the Raspberry Pi and you should
8) For setting up a dyndns.org address
I use the linux-client: ddclient : http://sourceforge.net/apps/trac/ddclient/
9) now you could connect to your Raspberry Pi – Drone with your dyndns.org adress
и вот ещё ссылка
http://www.starterkit.ru/html/index.php?na...=8028&num=3
Сообщение отредактировал _saper_ - Jan 9 2014, 17:00
Waldelk
сообщение Jan 10 2014, 05:21
Пользователь №: 77 841
То что Вы привели это скорей относится к "свисткам" Huawei, которые работают в режиме "виртуального CD-ROM"
Если будете SIM900 использовать, то Вам надо UART где-то в планшете взять
CADiLO
сообщение Jan 10 2014, 07:04
Из: Днепр
Пользователь №: 7 988
>>>> укрчастотнадзор ещё лет сто будет вводить черный список имей. так же как и гаи регистрацию скутеров
Если не в курсе, то уже ввели, просто с мобилками разбираться проблемнее. По модулям уже были отключения.
>>>> спасибо за наводку
Уже теплее, но еще не попали.
Маркировка NI - это не зарегестрированые транзитные модули, они в Украину не заходят, а идут сразу к соседям где не нужна регистрация - Молдова, Грузия.....
Если бы посмотрели на нашем сайте, то нашли бы что зарегистрированый модуль SIM900R(64) еще дешевле - 105 гривен.
>>>но я всеравно хотел купить уже готовую плату на ибее за 27 баксов
Ну и купите его с версией 1137B11SIM900M64_ST, а обновления и тем более последнюю расширеную прошивку официально получить не сможете.
А если в один прекрасный день отключат, то тоже не очень хорошо получится. ИБЕЮ пофигу, они Вам продали, а дальше сами разбирайтесь что да как...
_saper_
сообщение Jan 10 2014, 19:18
Сообщение #19
Вот ведь схема подключения
GSM модем SIM900--> STM32F3DISCOVERY--->USB(slave)--> USB(OTG)-->планшет
STM32F3DISCOVERY будет подключатся как виртуальный com port
>>>> спасибо за наводку
на нашем сайте это на ХАГе?
просто я пока не спешу покупать что либо. что-бы зря деньги не выкинуть.
кстати не вижу разницы между мобильником и модемом для оператора и черного списка.
вобщем получу планшет и буду думать что дальше.огромное спасибо за совет
CADiLO
сообщение Jan 11 2014, 19:28
Сообщение #20
Из: Днепр
http://microchip.ua/
или посмотрите дистрибьюторов на http://wm.sim.com/en/marketen.aspx
разница в ввозе и прохождении таможки
киньте в личку телефон или перезвоните на любой номер с сайта - отвечу на все вопросы
Waldelk
сообщение Jan 13 2014, 05:23
Сообщение #21
Удачи Вам в настройке маршрутизации пакетов в таком "бутерброде"
vassabi
сообщение Jan 13 2014, 21:22
Сообщение #22
Из: Киев
Пользователь №: 75 678
Ну чего?... Можно же попробовать линукс на discovery поднять... тогда минут 10 работы. sm.gif
2 страниц V  < 1 2
RSS Текстовая версия Сейчас: 28th August 2025 - 21:53
Страница сгенерированна за 0.01417 секунд с 7
