> Загрузка соединений P-CAD 2001
Romashkaa
сообщение Mar 30 2014, 17:52
Пользователь №: 81 157
Доброе время суток, форумчане!
Подскажите пожалуйста, в чем заключается ошибка: в созданной схеме электрической принципиальной, создаю список соединений netlist и пытаюсь подгрузить соединения в утилите PCB.
В ответ получаю вот это:
* Component VD2 of type VD_HOR loaded with a pattern mismatch between the library (VD_HOR) and netlist file (PATTERN)
Warning: line 16
* Component VD3 of type VD_HOR loaded with a pattern mismatch between the library (VD_HOR) and netlist file (PATTERN)
Warning: line 24
* Component C3 of type CONDENSATOR_VER loaded with a pattern mismatch between the library (CONDENSATOR_VER) and netlist file (PATTERN)
Warning: line 32
* Component C2 of type CONDENSATOR_ELECTR_VER loaded with a pattern mismatch between the library (CONDENSATOR_ELECTR_VER) and netlist file (PATTERN)
Warning: line 40
* Component VD1 of type VD_VER loaded with a pattern mismatch between the library (VD_VER) and netlist file (PATTERN)
Warning: line 48
* Component VD6 of type VD_VER loaded with a pattern mismatch between the library (VD_VER) and netlist file (PATTERN)
Warning: line 56
* Component VD4 of type STAB_VER loaded with a pattern mismatch between the library (STAB_VER) and netlist file (PATTERN)
Warning: line 64
* Component VD5 of type VD_VER loaded with a pattern mismatch between the library (VD_VER) and netlist file (PATTERN)
Warning: line 72
* Component K1 of type K1_VER loaded with a pattern mismatch between the library (K1_VER) and netlist file (PATTERN)
Warning: line 80
* Component VT2 of type PNP_HOR loaded with a pattern mismatch between the library (PNP_HOR) and netlist file (PATTERN)
Warning: line 88
* Component VT1 of type NPN_HOR loaded with a pattern mismatch between the library (NPN_HOR) and netlist file (PATTERN)
Warning: line 96
* Component U14 of type RESISTOR_VERTICAL loaded with a pattern mismatch between the library (RESISTOR_VERTICAL) and netlist file (PATTERN)
Warning: line 104
* Component U15 of type GND loaded with a pattern mismatch between the library (GND) and netlist file (PATTERN)
Warning: line 112
* Component U16 of type GND loaded with a pattern mismatch between the library (GND) and netlist file (PATTERN)
Warning: line 120
* Component U17 of type XP loaded with a pattern mismatch between the library (XP) and netlist file (PATTERN)
Warning: line 128
* Component U10 of type RESISTOR_HORIZONTAL loaded with a pattern mismatch between the library (RESISTOR) and netlist file (PATTERN)
Warning: line 136
* Component U11 of type RESISTOR_VERTICAL loaded with a pattern mismatch between the library (RESISTOR_VERTICAL) and netlist file (PATTERN)
Warning: line 144
* Component U12 of type RESISTOR_VERTICAL loaded with a pattern mismatch between the library (RESISTOR_VERTICAL) and netlist file (PATTERN)
Warning: line 152
* Component U13 of type GND loaded with a pattern mismatch between the library (GND) and netlist file (PATTERN)
Error: line 154
* Component K1.1 not loaded. No pattern is attached.
Error: line 162
* Component K1.2 not loaded. No pattern is attached.
Warning: line 176
* Component U18 of type GND loaded with a pattern mismatch between the library (GND) and netlist file (PATTERN)
Warning: line 184
* Component U19 of type RESISTOR_VERTICAL loaded with a pattern mismatch between the library (RESISTOR_VERTICAL) and netlist file (PATTERN)
Warning: line 192
* Component U5 of type GND loaded with a pattern mismatch between the library (GND) and netlist file (PATTERN)
Warning: line 200
* Component U4 of type 12 loaded with a pattern mismatch between the library (12) and netlist file (PATTERN)
Error: line 202
* Component K2.1 not loaded. No pattern is attached.
Warning: line 216
* Component U6 of type RESISTOR_VERTICAL loaded with a pattern mismatch between the library (RESISTOR_VERTICAL) and netlist file (PATTERN)
Warning: line 224
* Component U1 of type 12 loaded with a pattern mismatch between the library (12) and netlist file (PATTERN)
Warning: line 232
30-Mar-14 23:32 Page 1
P-CAD Net List Load Errors
* Component U3 of type GND loaded with a pattern mismatch between the library (GND) and netlist file (PATTERN)
Warning: line 240
* Component U2 of type CONDENSATOR_ELECTR_VER loaded with a pattern mismatch between the library (CONDENSATOR_ELECTR_VER) and netlist file (PATTERN)
Warning: line 248
* Component U9 of type RESISTOR_VERTICAL loaded with a pattern mismatch between the library (RESISTOR_VERTICAL) and netlist file (PATTERN)
Warning: line 256
* Component U8 of type GND loaded with a pattern mismatch between the library (GND) and netlist file (PATTERN)
Warning: line 264
* Component VS1 of type SINIST_VER loaded with a pattern mismatch between the library (SINIST_VER) and netlist file (PATTERN)
Warning: Net NET00001 has less than two nodes.
Warning: Net NET00003 has less than two nodes.
Error: Net NET00004: Pin 3 of VS1-3 not found.
Either pin does not exist or TYPE and PATTERN are ambiguous.
Warning: Net NET00005 has less than two nodes.
Warning: Net NET00008 has less than two nodes.
Error: Net NET00007: Pin 0 of K1-0 not found.
Warning: Net NET00021 has less than two nodes.
Net List Errors: 5
Net List Warnings: 35
Сообщение отредактировал Romashkaa - Mar 30 2014, 17:56
Прикрепленные файлы
RSS Текстовая версия Сейчас: 23rd August 2025 - 14:59
Страница сгенерированна за 0.01271 секунд с 7
