> XC8+PIC16+I2C
animal
сообщение May 29 2014, 07:09
Из: Нижний Новгород
Пользователь №: 34 535
Добрый день, господа! Прошу Вашей помощи.
#include <../../../../../../../../include/xc.h>
#include <../../../../../../include/pic16f1518.h>
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
// CONFIG1
#pragma config FOSC = INTOSC    // Oscillator Selection (INTOSC oscillator: I/O function on CLKIN pin)
#pragma config WDTE = OFF       // Watchdog Timer Enable (WDT disabled)
#pragma config PWRTE = OFF      // Power-up Timer Enable (PWRT disabled)
#pragma config MCLRE = OFF      // MCLR Pin Function Select (MCLR/VPP pin function is digital input)
#pragma config CP = OFF         // Flash Program Memory Code Protection (Program memory code protection is disabled)
#pragma config BOREN = OFF      // Brown-out Reset Enable (Brown-out Reset disabled)
#pragma config CLKOUTEN = OFF   // Clock Out Enable (CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin)
#pragma config IESO = OFF       // Internal/External Switchover (Internal/External Switchover mode is disabled)
#pragma config FCMEN = ON       // Fail-Safe Clock Monitor Enable (Fail-Safe Clock Monitor is enabled)
// CONFIG2
#pragma config WRT = OFF        // Flash Memory Self-Write Protection (Write protection off)
#pragma config VCAPEN = OFF     // Voltage Regulator Capacitor Enable bit (VCAP pin function disabled)
#pragma config STVREN = OFF      // Stack Overflow/Underflow Reset Enable (Stack Overflow or Underflow will cause a Reset)
#pragma config BORV = LO        // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (Vbor), low trip point selected.)
#pragma config LPBOR = OFF      // Low-Power Brown Out Reset (Low-Power BOR is disabled)
#define _XTAL_FREQ 16000000
#define __delay_ms(x) _delay((unsigned long)((x)*(_XTAL_FREQ/4000.0)))
unsigned char Tmp;
main(void)
{   OSCCON = 0b01111010;        // Internal OSC @ 16MHz
    SSPCON1=0b00101000;         //I2C master
    SSPCON3bits.SDAHT = 1;      // Minimum of 300 ns hold time on SDA
                                // after the falling edge of SCL
    SSPSTAT=0b10000000;         //slew rate control disabled
    SSPADD=0x27;                //100 kHz
    SSPIF = 0;                  // Clear the serial port interrupt flag
    BCLIF = 0;                  // Clear the bus coll interrupt flag
    BCLIE = 1;                  // Enable bus collision interrupts
    SSPIE = 1;                  // Enable serial port interrupts
    PEIE = 1;                   // Enable peripheral interrupts
    GIE = 1;                    // Enable global interrupts
    PORTC = 0x00;               // Clear PORTC
    LATC = 0x00;                // Clear PORTC latches
    TRISC = 0b00011000;         // Set RC3, RC4 as inputs for I2C
    PORTB=0x00;
    LATB=0x00;
    TRISB=0x00;
    __delay_ms(100);
do{
   SSPCON2bits.SEN = 1;      // set start bit
   SSPBUF=0x30;
   do{}while(!SSPIF);
   SSPIF=0;
  //  SSPBUF=0x55;
//  do{}while(!SSPIF);
  //  SSPIF=0;
    SSPCON2bits.PEN = 1;       // set stop bit
    PORTBbits.RB5=1;
    __delay_ms(100);
    PORTBbits.RB5=0;
    __delay_ms(100);
}while(1);
На RB5 - светодиод. Без строчек с SSP все мигает. При загрузке приведенного кода мигания нет. При запуске в отладке с PicKit3 происхдят "перескоки" на начало программы (даже если в теле программы про SSP только одна строчка старт-бита). Контроллер PIC16F1518, XC8 1.31, MPLAB-X 1.9, код слизан с AN734. Пните пожалуйста в нужном направлении. sad.gif
- animal   XC8+PIC16+I2C   May 29 2014, 07:09
- - Voldemari4   У вас разрешены прерывания, а где обработчик преры...   May 29 2014, 07:30
|- - animal   Цитата(Voldemari4 @ May 29 2014, 15:40) У...   May 29 2014, 08:46
|- - A. Fig Lee   Цитата(animal @ May 29 2014, 08:56) Мырга...   May 29 2014, 08:58
|- - animal   Цитата(A. Fig Lee @ May 29 2014, 17:08) Н...   May 30 2014, 01:32
- - A. Fig Lee   Именно. Обработчика нет. 2. А что, так можно: GIE...   May 29 2014, 07:34
|- - Voldemari4   Цитата(A. Fig Lee @ May 29 2014, 16:44) А...   May 29 2014, 07:40
- - A. Fig Lee   А.. интересненько.. Не, пожалуй, с битами лучше. Н...   May 29 2014, 08:43
- - Voldemari4   Ваша программа может зависать на циклах while. Все...   May 30 2014, 02:20
|- - animal   Цитата(Voldemari4 @ May 30 2014, 10:30) В...   May 30 2014, 02:31
- - A. Fig Lee   Я на XC8. Вот выжимка из рабочего кода PIC18F14K5...   May 30 2014, 07:10
|- - animal   За выжимку спасибо. Я, хоть тресни, не вижу ошибки...   May 30 2014, 07:54
|- - A. Fig Lee   Цитата(animal @ May 30 2014, 08:04) За вы...   May 30 2014, 08:32
|- - animal   Цитата(A. Fig Lee @ May 30 2014, 16:42) А...   May 30 2014, 08:55
- - A. Fig Lee   Остается сравнить состояния регистров до I2C START...   May 30 2014, 09:34
- - Voldemari4   ЦитатаДобавил : ADCON0bits.ADON=0; //ADC disable Е...   May 30 2014, 11:16
|- - A. Fig Lee   Цитата(Voldemari4 @ May 30 2014, 11:26) Е...   May 30 2014, 12:00
|- - evc   Цитата(Voldemari4 @ May 30 2014, 19:26) Е...   May 31 2014, 04:30
|- - animal   Цитата(evc @ May 31 2014, 12:40) Ага. Все...   Jun 2 2014, 01:43
|- - animal   Код слейва: Код#include <xc.h> // CONFIG1 ...   Jun 2 2014, 02:38
- - Voldemari4   Добавьте ожидание пока SEN и PEN обнуляться. А то ...   Jun 2 2014, 01:52
RSS Текстовая версия Сейчас: 24th August 2025 - 08:28
Страница сгенерированна за 0.01392 секунд с 7
