> Есть ли разница в DAC_Channel_1 и DAC_Channel_2 ?, STM32F103RCT6
misyachniy
сообщение Jan 4 2015, 12:47
Из: Kyiv
Пользователь №: 5 454
Исходный пример использует DAC_Channel_1 http://chipspace.ru/stm32-dac-3/
Я свел в одну функцию:
CODE
void WavePlayer_Init(void)
DMA_InitTypeDef DMA_InitStructure;
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
GPIO_InitTypeDef GPIO_InitStructure;
DAC_InitTypeDef DAC_InitStructure;
//Sinus_calculate();
for(int i=0; i<360; i++)
Wavebuffer[i] = (uint16_t) lround((sin(i*(pi/180)) + 1)*4095/2);
//RCC_Configuration();
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);
//GPIO_Configuration();
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
GPIO_Init(GPIOA, &GPIO_InitStructure);
//DMA_Configuration();
DMA_InitStructure.DMA_PeripheralBaseAddr = DAC_1_DATA;
DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&Wavebuffer;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
DMA_InitStructure.DMA_BufferSize = 360;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA1_Channel2, &DMA_InitStructure);
// DMA_Cmd(DMA1_Channel2, ENABLE);
//DAC_Configuration();
/* DAC channel1 Configuration */
DAC_InitStructure.DAC_Trigger = DAC_Trigger_None;
DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;
DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Enable;
DAC_InitStructure.DAC_LFSRUnmask_TriangleAmplitude = DAC_TriangleAmplitude_4095;
// vovka
DAC_Init(DAC_Channel_1, &DAC_InitStructure);
//DAC_Cmd(DAC_Channel_1, ENABLE);
//Timer_Configuration();
//TIM2 - управление DAC (формирование синусоиды гармоники)
TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
TIM_TimeBaseStructure.TIM_Period = 333;
TIM_TimeBaseStructure.TIM_Prescaler = 0;
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
//TIM2 TRGO selection
TIM_SelectOutputTrigger(TIM2, TIM_TRGOSource_Update);
TIM_DMACmd(TIM2, TIM_DMA_Update, ENABLE);
// TIM_Cmd(TIM2, ENABLE);
После разрешения на выходе идет синусоида амплитудой в полное напряжение питания.
С нагрузкой в 3,3 кОм.
Если конфигурирую DAC_Channel_2, то на выходе сигнал всего 0,2 вольта.
Это что-то подкорачивает, подгорело или где-то "мелким почерком" написано в документации?
Сообщение отредактировал IgorKossak - Jan 5 2015, 12:29
Причина редактирования: [codebox] для длинного кода, [code] - для короткого!!!
RSS Текстовая версия Сейчас: 26th July 2025 - 09:30
Страница сгенерированна за 0.01365 секунд с 7
