> Кто-нибудь работал с BQ34Z100 ?
vladimir_orl
сообщение Mar 4 2015, 13:41
Из: Орёл
Пользователь №: 73 591
Здравствуйте. Разбираюсь с микросхемой контроля заряда BQ34Z100. Она общается с МК по I2C.
В даташите на неё написано следующее:
STANDARD DATA COMMANDS
The bq34z100 uses a series of 2-byte standard commands to enable host reading and writing of battery
information. Each standard command has an associated command-code pair, as indicated in Table 2. Because
each command consists of two bytes of data, two consecutive HDQ/I
2
C transmissions must be executed both to
initiate the command function and to read or write the corresponding two bytes of data. Standard commands are
accessible in NORMAL operation. Also, two block commands are available to read Manufacturer Name and
Device Chemistry. Read/Write permissions depend on the active access mode.
Пока что смог посмотреть только текущее напряжение. И то командой 0х0809 выдаётся напряжение в сотнях мВ. Командой 0х0707 выдаются милливольты (младший байт).
Если кто работал с ней, подскажите. На инофорумах как-то всё расплывчато.
The bq34z100 uses a series of 2-byte standard commands to enable host reading and writing of battery information. Each standard command has an associated command-code pair,
as indicated in Table 2. Because each command consists of two bytes of data, two consecutive HDQ/I2C transmissions must be executed both to
initiate the command function and to read or write the corresponding two bytes of data. Standard commands are accessible in NORMAL operation. Also,
two block commands are available to read Manufacturer Name and Device Chemistry. Read/Write permissions depend on the active access mode.
RSS Текстовая версия Сейчас: 24th August 2025 - 11:49
Страница сгенерированна за 0.01344 секунд с 7
