> самый быстрый мк на плате, здесь для удобства
Огурцов
сообщение May 1 2015, 18:23
Из: РФ
Пользователь №: 26 588
AM389x
• ARM Cortex-A8
• Up to 1.5GHz
• 2x 1G-Enet
• 3D Graphics
• PCIe, SATA
• DDR2/3
• Advanced Display
Rockchip RK3288, 28nm, Cortex-A17 Quad Core, 1.8GHZ;
Mali-T764 3D GPU (OpenGL ES 1.1/2.0 /3.0,and OpenCL 1.1)
SD/MMC/SDIO interface, compatible with SD3.0,SDIO3.0 and MMC4.5
One 8-channels I2S/PCM interface, One 8-channels SPDIF interface
One USB2.0 OTG , Two USB2.0 Host
100M/1000M RMII/RGMII Ethernet interface
Dual channel TS stream interface, descramble and demux support
Smart Card interface
GPS baseband interface
PS/2 master interface
5 UART, 3 SPI (master or slave), 6 I2C(up to 4Mbps), 5 PWM
$74 http://www.ebay.com/itm/1080P-Quad-Core-An...=item5d57c344e2
Beaglebone black
TI Sitara AM335x
1 GHz ARM® Cortex™-A8
SGX530 Graphics Engine
SDRAM: 512MB DDR3L 800MHZ
eMMC Flash: Rev C: 4GB (as of 2014.05.21)
High speed USB 2.0 Client port: Access to USB0, Client mode via miniUSB
High Speed USB 2.0 Host port: Access to USB1, Type A Socket, 500mA LS/FS/HS
Serial Port: UART0 access via 6 pin 3.3V TTL Header. Header is populated
10/100M Ethernet (RJ45)
$76 http://www.ebay.com/itm/BeagleBone-Black-R...=item3a9971831b
бюджетненько:
CPU RK3066 Dual Core 1.6G(Cortex-A9)
GPU Mali 400MP Support OpenGLES2.0/1.1
RAM 1GB DRIII
Internal Memory Built-in 8GB memory
Operation System Google Android 4.4
Bluetooth Bluetooth 4.0
Memory External Support Micro-SD card, up to 32GB, (not included Micro SD Card)
Networking WiFi 802.11b/g/n 10/100Mbps With internal Antenna
Graphics Type Integrated Graphics Mali400, Supports 1080P video (1920*1080)
GBP 24 http://www.ebay.com/itm/MK808B-Bluetooth-A...=item5d52ace6da
кстати, мощная фигня:
Светлячок rk3288 Quad Core cortex-a17 процессоров развития доска 2G / 16G WiFi BT
CPU RK3288 Cortex-A17 quad core@ 1.8GHz
RAM 2GB DDR3
Flash 16GB eMMC Flash, Micro SD
Internet Ethernet - 10/100/1000M RJ45
Wireless - 2.4GHz/5GHz AC WiFi, Support 802.11a/b/g/n/ac
Bluetooth 4.0
Video HDMI2.0 up to 3840x2160@60P
VGA up to 1080P
MIPI, LVDS, EDP, MIPI-CSI
Audio HDMI, SPDIF, erphone, MIC
USB 2 x USB2.0 HOST
1 x Micro USB OTG
$170 http://www.ebay.com/itm/Firefly-RK3288-Qua...=item2c93f9a9ce
Banana Pi bpi-r1 одиночный бортовой компьютер open source Smart беспроводной маршрутизатор
cpu a20 dual core
sdram 1gb
ethernet port * 5 10/100/1000
$82 http://www.ebay.com/itm/Banana-PI-BPI-R1-S...=item4ae7a3c5f5
Banana Pro 40 Dual Core 1GB RAM 1GHz 1 гигабит
SoC Allwinner A20
CPU ARM CortexTM-A7 Dual-Core @ 1.0GHz
GPU ARM Mali400MP2
SDRAM 1GB DDR3 (shared with GPU)
Display Supports multi-channel HD display:
HDMI 1.4 (Type A - full)
Composite video (PAL and NTSC) (via 3.5 mm TRRS jack shared with audio out)
LVDS/RGB/CPU display interface (DSI) for raw LCD panels
11 HDMI resolutions from 640Ч480 to 1920Ч1080 plus various PAL and NTSC standards
On board Network 10/100/1000Mbps ethernet (Realtek RTL8211E/D)
WiFi 802.11 b/g/n XXXXX
Camera Parallel 8-bit camera interface
On board Storage MicroSD (TF) card, SATA 2.0
Audio outputs HDMI,analog audio (via 3.5 mm TRRS jack shared with composite video out),I2S audio (also potentially for audio input)
USB 2 USB 2.0 host, 1 USB 2.0 OTG (all direct from A20 chip)
Low-level perpherials 30ЧGPIO, some of which can be used for specific functions including UART, I2C, SPI, PWM, CAN, I2S, SPDIF.
LRADC, ADC, LINE-IN,FM-IN,HP-IN.
$48 http://www.ebay.com/itm/Banana-Pro-40-Dual...=item5d54ae62ec
как-то наиболее красиво, хотя уже и не так круто:
Neuste Version! - Raspberry Pi 2 Modell / Model B - Quad-Core Prozessor 1GB RAM
Broadcom BCM2836 900 MHz ARM Cortex-A7 Quad-Core-Prozessor mit VideoCore IV Dual-Core-GPU
GPU bietet Open GL ES 2.0, OpenVG mit Hardwarebeschleunigung und 1080p30 H.264 High-Profile-Decoding
GPU ermцglicht 1 GPixel/s, 1,5 GTexel/s oder 24 GFLOPs mit Texturfilterung und DMA-Infrastruktur
1 GB LPDDR2 SDRAM
HD 1080p-Videoausgang
Composite-Video-Ausgang (PAL/NTSC) (ьber 3,5mm Klinkenbuchse)
Ethernet-Anschluss 10/100 BaseT RJ45
Video/Audiobuchse HDMI 1.3 und 1.4
4-polige Audio/Composite-Video-OUT-Buchse, 3,5 mm
4 USB 2.0-Buchsen
15-poliger MPI CSI-2-Steckverbinder fьr Raspberry Pi HD-Videokamera
15-poliger serieller Display-Schnittstellensteckverbinder
MicroSD-Kartensteckplatz
Wird von MicroSD-Karte gebootet, lдuft mit einer neuen Version des Linux-Betriebssystems
40-polige Stiftleiste fьr GPIO und serielle Busse (kompatibel mit 26-poliger Stiftleiste fьr Raspberry Pi 1)
EUR 43 http://www.ebay.com/itm/Neuste-Version-Ras...%3D361276402980
Сообщение отредактировал Огурцов - May 1 2015, 18:27
RSS Текстовая версия Сейчас: 22nd July 2025 - 06:14
Страница сгенерированна за 0.01386 секунд с 7
