> Проблема с прошивкой fuse-bit в ATmega32U4, avrdude
Doka
сообщение Feb 9 2016, 12:15
Electrical Engineer
Группа: СуперМодераторы
Пользователь №: 778
возникла проблема с atmega32u4 (китайский клон Arduino Pro Micro) - прошивается всё, кроме фьюзов:
sudo /usr/bin/avrdude -C /etc/avrdude/avrdude.conf -p atmega32u4 -c avr109 -P /dev/ttyACM0 -b 19200 -U lfuse:w:0x90:m -U hfuse:w:0xd9:m
Connecting to programmer: .
Found programmer: Id = "CATERIN"; type = S
    Software Version = 1.0; No Hardware Version given.
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize=128 bytes.
Programmer supports the following devices:
    Device code: 0x44
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9587
avrdude: reading input file "0x90"
avrdude: writing lfuse (1 bytes):
Writing |                                                    | 0% 0.00s ***failed;
Writing | ################################################## | 100% 0.00s
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0x90:
avrdude: load data lfuse data from input file 0x90:
avrdude: input file 0x90 contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
         0x90 != 0xff
avrdude: verification error; content mismatch
avrdude: safemode: lfuse changed! Was 90, and is now ff
Would you like this fuse to be changed back? [y/n]
все секции memory присутствуют в /etc/avrdude/avrdude.conf и соответствуют даташиту
расширенная диагностика при чтении фьюзов:
sudo /usr/bin/avrdude -C /etc/avrdude/avrdude.conf -p atmega32u4 -c avr109 -P /dev/ttyACM0 -b 19200 -U lfuse:r:-:i -U hfuse:r:-:i -v
avrdude: Version 5.10, compiled on Oct 22 2010 at 08:16:12
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/etc/avrdude/avrdude.conf"
         User configuration file is "/root/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyACM0
         Using Programmer              : avr109
         avr910_devcode (avrdude.conf) : none
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       1024    8      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : avr910
         Description     : Atmel AppNote AVR109 Boot Loader
    Device code: 0x44
avrdude: devcode selected: 0x44
avrdude: safemode: lfuse reads as FF
avrdude: safemode: hfuse reads as D8
avrdude: safemode: efuse reads as CB
avrdude: reading lfuse memory:
avrdude: writing output file "<stdout>"
0xff
avrdude: reading hfuse memory:
0xd8
avrdude: reading lock memory:
0xef
avrdude: safemode: Fuses OK
avrdude done.  Thank you.
any ideas?
RSS Текстовая версия Сейчас: 12th August 2025 - 02:17
Страница сгенерированна за 0.01365 секунд с 7
