Цитата(petrov @ Apr 25 2016, 13:33)
Выкидываете дециматор из КИХ, между коэффициентами приподнятого косинуса вставляете нули в соответствии с коэффициентом децимации, полученные фильтры каскадно соединяете и подаёте дельта-импульс, строите АЧХ полученной ИХ.
Спасибо попробую.
Собственно нашел пример как описывать подобного рода штуки.
Может как и мне, кому-ни-ть бригодится.
RRC_rolloff = 0.22; % RRC rolloff factor
RRC_order = 34; % RRC order is one less than the filter length.
RRC_L_factor = 4; % interpolate by this number in the RRC
% create a SQUARE ROOT RAISED COSINE filter based on the above parameters.
dRRC = fdesign.pulseshaping(RRC_L_factor,'Square Root Raised Cosine','N,Beta',RRC_order,RRC_rolloff);
hRRCtemp = design(dRRC);
hRRC = mfilt.firinterp(RRC_L_factor, hRRCtemp.Numerator);
% CIC COMPENSATION (CFIR) SECTION
% (Note: some parameters belong to the CIC being compensated.)
CFIR_L_factor = 2; % interpolation factor of CFIR
CIC_D = 1; % differential delay of CIC
CIC_N = 5; % number of stages in CIC
CIC_R = 8; % interpolation factor of CIC
CFIR_Fp = 1e6; % passband edge frequency of CFIR
CFIR_Fst = 2e6; % stopband edge frequency of CFIR
CFIR_Ap = 0.2; % passband ripple of CFIR (in dB)
CFIR_Ast = 80; % stopband attenuation of CFIR (in dB)
CFIR_Fs = 12.5e6; % OUTPUT (interpolated) sampling frequency of CFIR
% create a CIC COMPENSATION FILTER based on the above parameters
dCFIR = fdesign.interpolator(CFIR_L_factor,'ciccomp', CIC_D, CIC_N, CIC_R, ...
'Fp,Fst,Ap,Ast', ...
CFIR_Fp, CFIR_Fst, CFIR_Ap, CFIR_Ast, CFIR_Fs);
hCFIR = design(dCFIR,'equiripple');
% create a CFIR SCALING FACTOR OBJECT
% (NOTE: the coefficients are scaled to prevent loss of signal power due to
% insertion of zero samples - this requires correction for convenient
% plotting of the spectrum.)
K_cfir = 1/CFIR_L_factor; % gain compensation value
hKcfir = dfilt.scalar(K_cfir);
% CIC SECTION
CIC_Fs = 100e6; % OUTPUT (interpolated) sampling frequency of CIC
CIC_iwl = 10; % CIC input
% create a CIC filter object
hCIC = mfilt.cicinterp(CIC_R, CIC_D, CIC_N);%, 10, CIC_Fs);
% create a CIC scaling factor object
K_cic = 1/(CIC_R^CIC_N); % gain compensation value
hK = dfilt.scalar(K_cic);
% CASCADE SECTION
% create a cascade of the objects
hCIChK = mfilt.cascade(hCIC,hK); % CIC with scaling applied
hCFIRhKcfir = mfilt.cascade(hCFIR,hKcfir); % CFIR with scaling applied
hCASC = mfilt.cascade(hRRC,hCFIR,hKcfir,hCIC,hK); % cascade of all filters and scalings
Код для примера.
Всем спасибо.
