> picoblaze, много ядер picoblaze
picodebug
сообщение May 5 2016, 12:06
Пользователь №: 22 119
Всем, привет.
Есть несколько ядер picoblaze, если в ISE (v.13.4) Keep Hierarchy = NO, то всё нормально разводится.
При Keep Hierarchy = YES - ошибка
Pack:2811 - Directed packing was unable to obey the user design constraints (BLKNM=M1/M1/KCPSM6_SANDR) which requires the combination of the symbols listed below to be packed into a single SLICE component.
The directed pack was not possible because: The top reasons for failure were:
-> A legal placement was never found for register symbol "M1/M1/data_path_loop[7].low_hwbuild.shift_rotate_flop".
-> A legal placement was never found for register symbol "M1/M1/data_path_loop[6].low_hwbuild.shift_rotate_flop".
-> Function generator M1/M1/data_path_loop[4].mid_shift_rotate.shift_rotate_lut/LUT6 is the LUT6 portion of the LUT6_2 and can only go into a LUT6 site.
-> Function generator M1/M1/data_path_loop[6].msb_shift_rotate.shift_rotate_lut/LUT6 is the LUT6 portion of the LUT...
NOTE: This message is very long (~3 K) and has been shortened to a maximum of 1000 characters for viewing in this context.
Please refer to the corresponding ASCII report for the full message.
Pack:2811 - Directed packing was unable to obey the user design constraints (BLKNM=M2/M1/KCPSM6_SANDR) which requires the combination of the symbols listed below to be packed into a single SLICE component.
-> A legal placement was never found for register symbol "M2/M1/data_path_loop[7].low_hwbuild.shift_rotate_flop".
-> A legal placement was never found for register symbol "M2/M1/data_path_loop[6].low_hwbuild.shift_rotate_flop".
-> Function generator M2/M1/data_path_loop[4].mid_shift_rotate.shift_rotate_lut/LUT6 is the LUT6 portion of the LUT6_2 and can only go into a LUT6 site.
-> Function generator M2/M1/data_path_loop[6].msb_shift_rotate.shift_rotate_lut/LUT6 is the LUT6 portion of the LUT...
что поправить в ядре, чтобы не было ошибки?
Прикрепленные файлы
RSS Текстовая версия Сейчас: 20th July 2025 - 14:51
Страница сгенерированна за 0.01374 секунд с 7
