> GPIO через расширитель pcf8574 на i2c-tiny-usb, Как правильно инициировать GPIO
Чижик
сообщение Mar 20 2017, 10:37
Пользователь №: 95 864
Добрый день.
Через конвертер i2c-tiny-usb подключен расширитель pcf8574.
Система на базе Intel. Ядро скомпилировано с модулями поддержки указанных устройств.
Имеем вывод
Last login: Mon Mar 20 12:58:17 MSK 2017 on tty1
Linux SONY 3.16.39v1 #1 SMP Wed Mar 15 10:39:26 MSK 2017 i686
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
root@SONY:~# uname -a
Linux SONY 3.16.39v1 #1 SMP Wed Mar 15 10:39:26 MSK 2017 i686 GNU/Linux
root@SONY:~# modprobe i2c-tiny-usb
[   41.713431] usbcore: registered new interface driver i2c-tiny-usb
root@SONY:~# modprobe i2c-dev
[   48.306626] i2c /dev entries driver
root@SONY:~# [   53.808164] usb 5-2: new high-speed USB device number 5 using ehci-pci
[   53.940723] usb 5-2: New USB device found, idVendor=0409, idProduct=005a
[   53.940879] usb 5-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[   53.941709] hub 5-2:1.0: USB hub found
[   53.941937] hub 5-2:1.0: 4 ports detected
[   54.228148] usb 5-2.4: new low-speed USB device number 6 using ehci-pci
[   54.346406] usb 5-2.4: New USB device found, idVendor=0403, idProduct=c631
[   54.346566] usb 5-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   54.346713] usb 5-2.4: Product: i2c-tiny-usb
[   54.346803] usb 5-2.4: Manufacturer: Till Harbaum
[   54.347841] i2c-tiny-usb 5-2.4:1.0: version 1.05 found at bus 005 address 006
[   54.348702] i2c i2c-6: connected i2c-tiny-usb device
modprobe i2c-echo ds1307 0x68 > /sys/class/i2c-adapter/i2c-6/new_device
[   65.011568] i2c i2c-6: new_device: Instantiated device ds1307 at 0x68
root@SONY:~# [   65.122707] rtc-ds1307 6-0068: rtc core: registered ds1307 as rtc1
[   65.131649] rtc-ds1307 6-0068: 56 bytes nvram
echo ds1307 0echo pcf857x 0x20 > /sys/class/i2c-adapter/i2c-6/new_device
[   92.587659] i2c i2c-6: new_device: Instantiated device pcf857x at 0x20
root@SONY:~# i2cdetect -y 6
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: 20 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: 40 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- 57 -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- --
70: 70 -- -- -- -- -- -- --
root@SONY:~# echo 76 > /sys/class/gpio/export
-bash: echo: ошибка записи: Нет такого устройства
На шине i2c три устройства. DS1307 подключается, регистрируется /dev/rtc1/.Все работает.
Модуль PCF857x загружается, но как к нему обратиться через gpio не понятно.
Какие пины можно зарегистрировать? Где это посмотреть или задать?
Что означает выдаваемая ошибка? Что-то недоконфигурено в ядре?
Конфиг ядра для GPIO
# Pin controllers
# CONFIG_PINMUX is not set
# CONFIG_PINCONF is not set
# CONFIG_DEBUG_PINCTRL is not set
CONFIG_PINCTRL_BAYTRAIL=y
CONFIG_ARCH_WANT_OPTIONAL_GPIOLIB=y
CONFIG_GPIOLIB=y
CONFIG_GPIO_DEVRES=y
CONFIG_GPIO_ACPI=y
# CONFIG_DEBUG_GPIO is not set
CONFIG_GPIO_SYSFS=y
# Memory mapped GPIO drivers:
# CONFIG_GPIO_GENERIC_PLATFORM is not set
# CONFIG_GPIO_IT8761E is not set
# CONFIG_GPIO_F7188X is not set
# CONFIG_GPIO_SCH311X is not set
# CONFIG_GPIO_SCH is not set
# CONFIG_GPIO_ICH is not set
CONFIG_GPIO_VX855=m
# CONFIG_GPIO_LYNXPOINT is not set
# I2C GPIO expanders:
# CONFIG_GPIO_MAX7300 is not set
# CONFIG_GPIO_MAX732X is not set
# CONFIG_GPIO_PCA953X is not set
CONFIG_GPIO_PCF857X=m
# CONFIG_GPIO_ADP5588 is not set
Помогите вЪехать в тему. Куда посмотреть?
PS Понятно что через i2c-tools пины pc8574 читаются и пишутся.
Сообщение отредактировал Чижик - Mar 20 2017, 10:41
RSS Текстовая версия Сейчас: 22nd August 2025 - 19:11
Страница сгенерированна за 0.01309 секунд с 7
