> завести XDS110 в CCS7 lubuntu17, не проходит тест XDS110 под лубунтой в VirtualBox
AlexRayne
сообщение Jul 13 2017, 11:47
Пользователь №: 30 877
Привет!
помогите завести отладчик в CCS7. студия запускается в lubuntu 17 на виртуалке VBox, хост win8. отладочная плата launchXL-cc1310
собираю проект из примеров ContikiOS - rime.
настраиваю target в Texas Instruments XDS110 USB Debug Probe, камень cc1310f128
тест соединения выдает журнал с егогом - см ниже.
запуск того же теста из студии под вендой проходит прекрасно.
удавалось ли комуто завести отладку в CCS под линем? научите!
[Start: Texas Instruments XDS110 USB Debug Probe]
Execute the command:
%ccs_base%/common/uscif/dbgjtag -f %boarddatafile% -rv -o -S integrity
[Result]
-----[Print the board config pathname(s)]------------------------------------
/home/alexrayne/.ti/ti/0/0/BrdDat/testBoard.dat
-----[Print the reset-command software log-file]-----------------------------
This utility has selected a 100- or 510-class product.
This utility will load the adapter 'libjioxds110.so'.
The library build date was 'May 2 2017'.
The library build time was '12:38:03'.
The library package version is '6.0.628.1'.
The library component version is '35.35.0.0'.
The controller does not use a programmable FPGA.
The controller has a version number of '5' (0x00000005).
The controller has an insertion length of '0' (0x00000000).
This utility will attempt to reset the controller.
This utility has successfully reset the controller.
-----[Print the reset-command hardware log-file]-----------------------------
The scan-path will be reset by toggling the JTAG TRST signal.
The controller is the XDS110 with USB interface.
The link from controller to target is direct (without cable).
The software is configured for XDS110 features.
The controller cannot monitor the value on the EMU[0] pin.
The controller cannot monitor the value on the EMU[1] pin.
The controller cannot control the timing on output pins.
The controller cannot control the timing on input pins.
The scan-path link-delay has been set to exactly '0' (0x0000).
An error occurred while hard opening the controller.
-----[An error has occurred and this utility has aborted]--------------------
This error is generated by TI's USCIF driver or utilities.
The value is '-275' (0xfffffeed).
The title is 'SC_ERR_SCAN_POLL_BUSY'.
The explanation is:
The attempt to poll a target device exceeded its timeout limit.
The utility or debugger has requested that a target device be
repeatedly accessed for a specific data or status value.
This has failed because the built-in limit for the maximum number
of attempts when polling the JTAG scan-path has been exceeded.
[End: Texas Instruments XDS110 USB Debug Probe]
RSS Текстовая версия Сейчас: 15th June 2025 - 20:22
