Осциллограф Tektronix TDS540B
4 канала, 500 МГц
2Gs/s c интерполяцией до 100Gs/s
Чувствительность 1mv/дел. - 10V/дел.
Интерфейс GPIB, дополнительный выход VGA на монитор.
Режим ZOOM, 2 развертки.
Дисплей YT, XY
цена 50 т.р.
Екатеринбург, отправка по РФ
Алексей
rv9cts@gmail.com
8-912-26-32-327
Features & Benefits
InstaVu™ Acquisition (100,000 wfms/sec capture rate)
500-MHz Bandwidth
Sample rates to 2 GS/s
Four Input Channels
Pulse Width, 1-ns Glitch, Runt, Pattern, and State Triggering
1 mV/div - 10 V/div Sensitivity
Infinite- and Variable-Persistence Displays
Record Lengths to 50,000 Points (Extendable to 500K on TDS540B)
8-Bit Vertical Resolution and up to 12 Bits with Hi-Res Acquisition Mode
3.5-inch DOS Floppy Disk Drive (Optional)
Vertical Accuracy to 1%
Tek TriStar™ (DSP) Processor
Slew Rate, Setup, and Hold Violation Triggers, and Time-Out Triggering
Waveform Pass/Fail Testing
Dual Window Zoom
Channel Deskew
Direct Readout in "Amperes" and "Watts" (with P5200 and TCP202 Probes)
25 Automatic Measurements
Full GPIB Programmability
Desktop-Publishing Outputs
Segmentable Acquisition Memory
VGA Output
