> Industrial Mini-ITX motherboards
nbn
сообщение Feb 26 2018, 11:16
Из: Санкт-Петербург
Пользователь №: 520
LV-669X-P
Onboard VIA C7 1.5 GHz processor with VIA CN700 & VT8237+,
one DIMM support up to 1 GB,
Onboard VGA and LVDS , 2 x Giga LAN
2 x SATA, 4 x serial ports, IEEE 1394, PCI and Mini-PCI ,
Audio, GPIO, CompactFlash socket, 8 ~ 24 V full range DC input
Mini-ITX Motherboard (170 x 170 mm)
CPU Onboard VIA C7 1.5 GHz processor.
Memory 1 x 184-pin DDR up to 1 GB
Chipset VIA CN700 & VT8237R+Real Time Clock Chipset integrated RTC with onboard lithium battery
Watchdog Timer Generates a system reset internal timer for 1min ~ 255 min
Power Management
ACPI 1.0 compliant, supports power saving mode
PCI Enhanced IDE 2 x DMA133 IDE channel up to 4 ATAPI devices. (1 x 40-pin and 1 x 44-pin)
VGA Interface VIA CN700 integrated Unichrome Pro 3D/2D Graphics controller.
Serial ATA Interface 2 x Serial ATA Interface with 150 MB/s transfer rate.
Audio Interface Realtek ALC655 5.1 channel Audio
LAN Interface 2x Realtek RTL8110S-32 Gigabit Ethernet .
Solid State Disk IDE1 supports 44-pin DiskOnModule +5V power supply CompactFlash Type-II on the rear .
GPIO Interface
Onboard programmable 8-bit digital I/O interface
Extend Interface
1 x PCI slot , 1 x Min-PCI socket
External I/O Port
2 x RJ45 LAN port, 1x DB15 VGA port, 1 x PS/2 Keyboard / Mouse ports, 2 x COM, 1 x IEEE 1394 ports, 4 x USB 2.0 ports, Audio , DC input connector
Internal I/O Port 1 x RS232 & 1 x RS232/422/485, 1 x slim FDD, 1 x IrDA , 2 x USB 2.0, 1 x 8-bit GPIO, 1 x Audio, 1 x LPT
Power Requirement 8 V ~ 24 V full range DC input , onboard 4-pin 12V connector Board Dimension 170mm x 170 mm (L x W)
Operation Temperature 0 ~ 60C
CPU: Onboard VIA C7 1.5 GHz processor.
Memory: 1 x 184-pin DDR up to 1 GB and optional onboard 256 MB SDRAM
Chipset: VIA CN700 & VT8237R+
VGA Interface: VIA CN700 integrated Unichrome Pro 3D/2D Graphics controller.
LVDS interface: Optional Onboard 18/24-bit Dual channel LVDS connector.
DVI interface: Optional onboard DVI interface.
Enhanced IDE: Two DMA133 IDE interface supports up to 4 ATAPI Devices.
Serial ATA: 2 x Serial ATA interface with 150 MB/s transfer rate.
LAN Interface: 2 x Realtek RTL8110S-32 Gigabit Ethernet .
Audio: Realtek ALC655 5.1 channel AC97 Codec.
Solid State Disk: IDE1 supports 44-pin DiskOnModule with +5V power supply. CompactFlash Type-II socket on the solder side .
IEEE 1394: 1 x IEEE1394 port.
GPIO interface: Onboard 8-bit Digital I/O interface.
Extended interface: 1 x Mini-PCI socket and 1 x PCI.
Rear I/O ports: PS/2 Keyboard/Mouse , VGA , 2 x LAN ,4 x USB2.0 , Audio , 2 x COM , IEEE 1394 , DC input.
Новая, полный комплект в коробке (могу отдать 1Гб модуль памяти в комплекте), на ebay такая стоит 200$, пусть будет 6000р
Продаётся по причине несовместимости VIA c SB Creative Audigy SE (драйвера ставятся, но звука нет)
Сообщение отредактировал nbn - Feb 26 2018, 11:33
maxick
сообщение Mar 3 2018, 20:02
Пользователь №: 102 126
Норм комплектик.
http://kuharochka.pp.ua
sasha klimov
сообщение Mar 4 2018, 12:57
Пользователь №: 45 200
Какая версия BIOS? Пожалуйста приведите полное наименование...
nbn
сообщение Mar 4 2018, 17:21
Из: Санкт-Петербург
Пользователь №: 520
BIOS 1.2
LV-669X-P
http://www.commell.com.tw/Support/Product%...port/LV-669.htm
sasha klimov
сообщение Mar 4 2018, 18:45
Радиатор с кулером входят в комплект?
Приношу свои извинения за беспокойство, но после доп. изучения ТТХ -вопрос о покупке отпал.
Сообщение отредактировал sasha klimov - Mar 4 2018, 18:55
nbn
сообщение Mar 5 2018, 14:57
Из: Санкт-Петербург
Пользователь №: 520
Да, всё в комплекте. Новая цена 5000р
RSS Текстовая версия Сейчас: 20th July 2025 - 11:29
Страница сгенерированна за 0.01411 секунд с 7
