5 страниц V   1 2 3 > »
> BPSK матлаб модулятор демодулятор
Acvarif
сообщение Mar 19 2018, 12:14
Пользователь №: 39 850
Имеется код BPSK модема, передатчик и приемник.
CODE
clear all;
Br = 117.1875*10^3;
Fd = Br*8;
Fif = 20*10^6;
Fdif = 60*10^6;
Fdopl = 100;
%% === TRANSMITTER ===
M = pngen(5);
D = rand(1, 200*8) > 0.5;
CRC = zeros(1, 16);
for i=1:length(D),
CRC(16) = xor(CRC(16), D(i));
CRC = [CRC(2:16) CRC(1)];
end;
FILL = ones(1, 200)*0.5;
DATA = [dec2bin(length(D)/8, 11)=='1' D CRC];
packet = [FILL M M diff_enc([0 DATA]) FILL]*2-1;
% redescr
Ndkr = Fd/Br;
pkt = packet(ceil(0.01:1/Ndkr:length(packet)));
hch = firls(31, [0 .24 .3 .5]*2, [1 1 0 0]);
pktf = filter(hch, [1], pkt);
% upsample
t1 = upsample4(pktf, 31);
t2 = upsample4(t1, 31);
pktfu = upsample4(t2, 31)';
% -> IF
l = length(pktfu);
s = sin(2*pi*(Fif+Fdopl)*(0:1/Fdif:l/Fdif));
c = cos(2*pi*(Fif+Fdopl)*(0:1/Fdif:l/Fdif));
pkts = pktfu.*s(1:l);
pktc = pktfu.*c(1:l);
%% === TRANSMIT LINE ===
Ir = awgn(awgn(pkts, 0.05), 0.01);
Qr = awgn(awgn(pktc, 0.05), 0.01);
%% === RECEIVER ===
% -> 0
l = length(Ir);
s = sin(2*pi*Fif*(0:1/Fdif:l/Fdif));
c = cos(2*pi*Fif*(0:1/Fdif:l/Fdif));
Rreu = Ir.*s(1:l) + Qr.*c(1:l);
Rimu = Qr.*s(1:l) - Ir.*c(1:l);
tr00 = downsample4(Rreu);
tr01 = downsample4(tr00);
Rre_ = downsample4(tr01);
Rre = filter(hch, [1], Rre_);
tr10 = downsample4(Rimu);
tr11 = downsample4(tr10);
Rim_ = downsample4(tr11);
Rim = filter(hch, [1], Rim_);
%figure; hold on; plot(Rre); plot(Rim, 'r');
% detection
Ms = M(ceil(0.01:1/Ndkr:length(M)));
cfh = Ms(length(Ms):-1:1);
cre = filter(cfh, [1], Rre)/length(cfh);
cim = filter(cfh, [1], Rim)/length(cfh);
%cr = sqrt(cre.^2 + cim.^2);
cr = (7/8)*max(abs(cre), abs(cim)) + (1/8)*min(abs(cre), abs(cim));
%figure; hold on; plot(cre); plot(cim); plot(cr, 'r');
env(length(cr)) = 0;
for j=1:length(cr),
f = max(1, j-Ndkr*length(M)+2*Ndkr);
t = min(length(cr), max(2, j-Ndkr));
env(j) = sum(cr(f:t))/(t-f);
end;
%figure; hold on; plot(cr, 'r'); plot(env, 'g'); plot(env*5);
for i=length(M)*Ndkr+1:length(cr)-1,
c1 = cr(i) > env(i)*5;
% c2 = (cr(i) > cr(i-1)) && (cr(i) > cr(i+1));
c2 = (cr(i-1) > cr(i-2)) && (cr(i-1) > cr(i));
c3 = abs(cr(i)-cr(i-length(M)*Ndkr)) < 4*env(i);
c4 = cr(i-length(M)*Ndkr) > env(i-length(M)*Ndkr)*5;
if c1 && c2 && c3 && c4,
break;
end;
end;
i
re = Rre(i:length(Rre));
im = Rim(i:length(Rim));
%figure; hold on; plot(re); plot(im, 'r');
figure; hold on; plot(cr, 'r'); plot(env, 'g'); plot(env*5); plot((c1&c2&c3&c4)*1.3, 'k');
l = length(re);
lb = length(packet);
Yre(lb) = 0;
Yim(lb) = 0;
fre(lb) = 0;
fim(lb) = 0;
are(lb) = 0;
aim(lb) = 0;
mark(l) = 0;
bit(lb) = 0;
k = 1;
gamma = 0.1;
Yre(1) = re(1);
Yim(1) = im(1);
for i = 8:8:length(re)-10,
mark(i) = 1;
are(k) = sum(re(i-6:i-1));
aim(k) = sum(im(i-6:i-1));
% okre(k) = are(k)*Yim(k) - aim(k)*Yre(k);
okim(k) = aim(k)*Yim(k) + are(k)*Yre(k);
bit(k) = sign(okim(k));
fre(k) = are(k)*bit(k);
fim(k) = aim(k)*bit(k);
Yre(k+1) = (1-gamma)*Yre(k) + gamma*fre(k);
Yim(k+1) = (1-gamma)*Yim(k) + gamma*fim(k);
k = k + 1;
end;
bit_dec = diff_dec(sign(bit+1));
bits = bit_dec(2:length(bit_dec));
%figure; hold on; plot(okim); plot(okre, 'r');
%figure; hold on; plot(re); plot(Yre(ceil(0.01:1/Ndkr:length(bit))), 'r');
%figure; hold on; plot(im); plot(Yim(ceil(0.01:1/Ndkr:length(bit))), 'r');
figure; hold on; plot(im); plot(mark, 'k');
len = bin2dec(int2str(bits(1:11)));
data = bits(12:12+len*8-1);
rcrc = bits(12+len*8:12+len*8+15);
crc = zeros(1, 16);
for i=1:length(D),
crc(16) = xor(crc(16), data(i));
crc = [crc(2:16) crc(1)];
end;
disp('---');
disp(sprintf('Received packet length: %d bytes', len));
disp(sprintf('Data ok: %d', sum(abs(data-D))==0));
disp(sprintf('CRC ok: %d', sum(abs(crc-rcrc))==0));
При компиляции возникает ошибка:
Undefined function 'pngen' for input arguments of type 'double'.
Error in Modem (line 10)
M = pngen(5);
Я так понимаю, что функция pngen должна быть где-то описана. Или такая функция уже встроена в Матлаб последних версий.
Использую R2014a.
Подскажите пожалуйста в чем проблема.
Если кто сталкивался, подсобите пожалуйста простейшим рабочим кодом BPSK модема (передатчик + приемник).
Grizzzly
сообщение Mar 19 2018, 12:18
Пользователь №: 75 748
Нет, это не встроенная функция. Ее написал автор этого кода. Надо искать реализацию.
Acvarif
сообщение Mar 19 2018, 13:00
Спасибо. Понятно.
CODE
clear
% несущаЯ
Fc = 2400;
% частота выборки бит из вектора Х
Fd = 2400;
% частота выборки выходного модулированного сигнала
Fs = 19200;
% количество сэмплов на 1 бит
Sb = Fs/Fd;
% количество 0 сэмплов перед сигналом
ZeroS = 10;%round(Sb/0.8);
NoiseLev = 0.2;
% ограничение тракта
Amax = 5;
% Количество наборов фаз на символ
M = 2;
% МодулирующаЯ последовательность
x = repmat([0 1 0 0 0 0 0 1 1 1 1 1 0 1 0 1 0 1 0 0 1 0 0 0],1,1); x=x(sm.gif;
% Modulate, keeping track of time.
[y,t] = dmod(x,Fc,Fd,[Fs pi/2],'psk',M);
% Всего выборок в выходом сигнале
samples_total = length(y);
if ZeroS > 0
y(ZeroS + 1: samples_total) = y (1 : samples_total - ZeroS);
y(1 : ZeroS) = 0;
end
noise = NoiseLev*randn(size(y));
% yn сигнал на входе демодулЯтора
yn = y + noise;
% Смоделировать выход за динамический диапазон по входу
for sn = 1 : samples_total
if yn(sn) > Amax
yn(sn) = Amax;
elseif yn(sn) < -Amax
yn(sn) = -Amax;
end
end
% ДемодулЯциЯ
% Вектор номеров выборок
samples_vector = 1 : samples_total;
%ГенерациЯ векторов sin и cos локальной несущей длЯ коррелЯции c Y
dFs = 2*pi*Fc/Fs;
% sin и cos на длине одного периода
sinFc = sin(0:dFs:2*pi-dFs)';
cosFc = cos(0:dFs:2*pi-dFs)';
samples_sin = length(sinFc);
% sin и cos на длине вектора входного сигнала
sinY = repmat(sinFc, samples_total/samples_sin, 1);
cosY = repmat(cosFc, samples_total/samples_sin, 1);
% ДвигаЯсь по выборкам скользЯщим окном, равным длине битового интервала, вычислЯем коррелЯцию с несущей
demod_y(1:samples_total) = 0;
demod_I(1:samples_total) = yn.*cosY;
demod_Q(1:samples_total) = yn.*sinY;
demod_y = demod_I + demod_Q*j;
% Усреднение I и Q на длине битового интервала
demod_avr_I(1:samples_total) = 0;
demod_avr_Q(1:samples_total) = 0;
avr_interval = samples_sin;
for sn = avr_interval : samples_total
demod_avr_I(sn) = sum(demod_I( sn - avr_interval + 1: sn ))/avr_interval*2;
demod_avr_Q(sn) = sum(demod_Q( sn - avr_interval + 1: sn ))/avr_interval*2;
end
% Перемножение усредненных I и Q с задержанной на 1 бит версией
demod_dly_I(1:samples_total) = 0;
demod_dly_Q(1:samples_total) = 0;
demod_dly_I(1+Sb:samples_total) = demod_avr_I(1:samples_total - Sb).* demod_avr_I(1+Sb:samples_total);
demod_dly_Q(1+Sb:samples_total) = demod_avr_Q(1:samples_total - Sb).* demod_avr_Q(1+Sb:samples_total);
demod_dly = demod_dly_I + demod_dly_Q;
% ФильтрациЯ демодулированного сигнала
[demod_b,demod_a]=butter(2,(Fd/Fs));
demod_filt = filter(demod_b,demod_a,sign(demod_dly));
subplot(5,1,1), plot (samples_vector, y, 'b', samples_vector, y, 'r'), grid on;
set (gca, 'XLimMode', 'manual',...
'XLim', [1,samples_total]',...
'XTickMode', 'manual',...
'XTick', [Sb:Sb:samples_total]');
subplot(5,1,2), plot (samples_vector, yn), grid on;
subplot(5,1,3), plot (samples_vector, demod_I, samples_vector, demod_Q, samples_vector, abs(demod_y)), grid on;
subplot(5,1,4), plot (samples_vector, demod_dly_I, samples_vector, demod_dly_Q, samples_vector, demod_dly), grid on;
subplot(5,1,5), plot (samples_vector, demod_dly, samples_vector, sign(demod_dly), samples_vector, sign(demod_filt)), grid on;
'XTick', [Sb:Sb:samples_total]',...
'YLimMode', 'manual',...
'YLim', [-1.5, 1.5]',...
'YTickMode', 'manual',...
'YTick', [-1.5:0.5:1.5]');
Очевидно в этом коде функция dmod тоже принадлежит автору?
https://www.gaussianwaves.com/digital-modul...s-from-scratch/
Я так понимаю это за деньги. Можно-ли найти подобную литературу не за деньги?
Хотя dmod вроде существует http://matlab.exponenta.ru/communication/book2/6/dmod.php
Но начиная с какой версии Матлаб?
Даже код кое-какой имеется http://read.pudn.com/downloads40/sourcecod...MM/DMOD.M__.htm
Сообщение отредактировал Acvarif - Mar 19 2018, 13:01
ataradov
сообщение Mar 19 2018, 16:59
Из: San Jose, CA
Пользователь №: 24 202
Ух ты. Я написал этот код много лет назад и все эти функции есть у меня на домашнем компе.
Я так предполагаю это из РТИ? Или это код дальше разошелся?
pngen() генерирует М-последовательность длинны 2^n, где n - это параметр функции. Можно просто найти любую М-последовательность длинны 32 и подставить напрямую.
Сообщение отредактировал ataradov - Mar 19 2018, 17:08
ataradov
сообщение Mar 20 2018, 00:45
Из: San Jose, CA
Вот исходник этой pngen():
CODE
function x=pngen(p);
% x=pnegn(p) - Generate pseudo-random sequence
% p = either a scaler (2..12) to generate a PN sequence
% using a predefined polynomial of length p, or
% a binary generating polynomial.
% x = sequence, of length 2^length(p) - 1.
% Predefined seqence polynomials:
pl{2} = [1 1];
pl{3} = [1 1 0];
pl{4} = [1 0 0 1];
pl{5} = [1 0 1 1 1];
pl{6} = [1 1 1 0 0 1];
pl{7} = [1 1 0 0 1 0 1];
pl{8} = [1 0 1 0 1 1 1 1];
pl{9} = [1 0 1 0 1 1 0 1 1];
pl{10} = [1 0 1 0 1 0 1 0 1 1];
pl{11} = [1 0 1 0 1 0 1 0 1 0 1];
pl{12} = [1 1 0 1 0 0 0 0 1 1 0 1];
if length(p) == 1
p = pl{p};
end
L=length(p);
N=2^L-1;
s=ones(1,length(p));
x=zeros(1,N);
for i=1:N
snew = mod(sum(and(p,s)),2);
x(i) = snew;
s=[s(2:end),snew];
end
Если нужна помощь с остальным - обращайтесь, помогу.
Acvarif
сообщение Mar 20 2018, 05:59
Большое спасибо. Помощь конечно-же нужна.
Для начала немного осмыслю как все работает...
ataradov
сообщение Mar 20 2018, 06:34
Из: San Jose, CA
Какая-то из версий этой модели была на Verilog-е реализована, но исходников этого мне сейчас уже точно не найти.
Ну и не стоит эту модель воспринимать как полную истину. Это моя первая модель модема созданная по следам чтения Скляра и экспериментов.
Acvarif
сообщение Mar 20 2018, 07:10
Да, я понимаю.
У меня пока совсем никакого представления. Только в общих чертах. Как работает ФАПЧ мне известно. На практике приходилось это делать, но только в бинарном варианте.
Но сейчас это все реализовывается в дискретном варианте на микроконтроллерах http://www.ti.com/lit/an/slaa681a/slaa681a.pdf, ПЛИС. Для начала пытаюсь хоть как-то понять это дело через Матлаб. Конечно Verilog (VHDL) код очень бы не помешал. Поскольку больше работаю с ПЛИС.
В коде появилась еще ошибка Undefined function 'diff_enc' for input arguments of type 'double'.
Похоже должна быть определена еще и функция diff_enc.
ataradov
сообщение Mar 20 2018, 07:12
Из: San Jose, CA
QUOTE (Acvarif @ Mar 20 2018, 00:10) *
CODE
function enc=diff_enc(data, start);
    if ~(exist('start'))
        start = 0;
    de(1)=xor(data(1), start);
    for i=2:length(data), de(i)=xor(de(i-1), data(i)); end;
    enc = de;
end
Этот модем скорее всего перебор по сравнению с той программной реализацией на МК.
Сообщение отредактировал ataradov - Mar 20 2018, 07:18
Acvarif
сообщение Mar 20 2018, 07:28
Спасибо. Дело продвинулось.
Далее Undefined function 'upsample4' for input arguments of type 'double'.
Похоже дальше есть еще неопределенные функции...
Перебор это в смысле..?
Сообщение отредактировал Acvarif - Mar 20 2018, 07:29
petrov
сообщение Mar 20 2018, 07:30
Из: Balakhna
Пользователь №: 937
Лучше сразу смотреть в строну симулинка, облегчает понимание и постепенно модель можно конретизировать до полноценного рабочего HDL кода не прибегая к внешним HDL симуляторам.
ataradov
сообщение Mar 20 2018, 07:36
Из: San Jose, CA
QUOTE (Acvarif @ Mar 20 2018, 00:28) *
Вот все функции какие у меня есть.
Я возможно не совсем понял статью, но они там похоже уже ожидают прямоугольный сигнал и только восстанавливают битовый клок.
Этот модем еще борется с несовпадением частоты дискретизации на приемнике и передатчике (или эффектом Допплера). Плюс тут много всяких заморочек с конкретным железом. Для модема на 100 Кбод не нужна дискретизация на 60 МГц.
Сообщение отредактировал ataradov - Mar 20 2018, 07:37
Прикрепленные файлы
Acvarif
сообщение Mar 20 2018, 07:51
Да. Согласен. Но в симуленке я сильно плаваю.
Архив не скачивается. Выскакивает на пустую страницу.
Насколько я понял там задействован внутренний АЦП микроконтроллера. Далее цифровые библиотеки FIR и т. п.
Доплер, это мне какраз и нужно.
ataradov
сообщение Mar 20 2018, 07:55
Из: San Jose, CA
QUOTE (Acvarif @ Mar 20 2018, 00:51) *
Может быть проще найти время и разобраться. Будет гораздо проще в итоге.
Добавил снова.
Одного АЦП в общем случае не достаточно нужно 2 квадратуры цифровать.
Прикрепленные файлы
Acvarif
сообщение Mar 20 2018, 08:06
Сообщение #15
Согласен. Придется разбираться.
Спасибо за функции. Главный код заработал. Попытаюсь разобраться.
Микроконтроллер имеет на борту многоканальный АЦП. Ну а если даже использовать один канал то при 4_х выборках на период можно использовать соседние выборки как синус и косинус.
RSS Текстовая версия Сейчас: 4th August 2025 - 07:32
Страница сгенерированна за 0.01492 секунд с 7
