> MAX10 - Flash Update module
Jenya7
сообщение Apr 3 2018, 07:47
Пользователь №: 71 075
Я создал Flash Update module - Tools->IP Catalog->Library->Basic Functions->On Chip Memory->Altera On-Chip Flash
CODE
entity flash_update is
port (
clock : in std_logic := '0'; -- clk.clk
avmm_csr_addr : in std_logic := '0'; -- csr.address
avmm_csr_read : in std_logic := '0'; -- .read
avmm_csr_writedata : in std_logic_vector(31 downto 0) := (others => '0'); -- .writedata
avmm_csr_write : in std_logic := '0'; -- .write
avmm_csr_readdata : out std_logic_vector(31 downto 0); -- .readdata
avmm_data_addr : in std_logic_vector(18 downto 0) := (others => '0'); -- data.address
avmm_data_read : in std_logic := '0'; -- .read
avmm_data_writedata : in std_logic_vector(31 downto 0) := (others => '0'); -- .writedata
avmm_data_write : in std_logic := '0'; -- .write
avmm_data_readdata : out std_logic_vector(31 downto 0); -- .readdata
avmm_data_waitrequest : out std_logic; -- .waitrequest
avmm_data_readdatavalid : out std_logic; -- .readdatavalid
avmm_data_burstcount : in std_logic_vector(3 downto 0) := (others => '0'); -- .burstcount
reset_n : in std_logic := '0' -- nreset.reset_n
end entity flash_update;
architecture rtl of flash_update is
component altera_onchip_flash is
generic (
INIT_FILENAME : string := "";
INIT_FILENAME_SIM : string := "";
DEVICE_FAMILY : string := "Unknown";
PART_NAME : string := "Unknown";
DEVICE_ID : string := "Unknown";
SECTOR1_START_ADDR : integer := 0;
SECTOR1_END_ADDR : integer := 0;
SECTOR2_START_ADDR : integer := 0;
SECTOR2_END_ADDR : integer := 0;
SECTOR3_START_ADDR : integer := 0;
SECTOR3_END_ADDR : integer := 0;
SECTOR4_START_ADDR : integer := 0;
SECTOR4_END_ADDR : integer := 0;
SECTOR5_START_ADDR : integer := 0;
SECTOR5_END_ADDR : integer := 0;
MIN_VALID_ADDR : integer := 0;
MAX_VALID_ADDR : integer := 0;
MIN_UFM_VALID_ADDR : integer := 0;
MAX_UFM_VALID_ADDR : integer := 0;
SECTOR1_MAP : integer := 0;
SECTOR2_MAP : integer := 0;
SECTOR3_MAP : integer := 0;
SECTOR4_MAP : integer := 0;
SECTOR5_MAP : integer := 0;
ADDR_RANGE1_END_ADDR : integer := 0;
ADDR_RANGE1_OFFSET : integer := 0;
ADDR_RANGE2_OFFSET : integer := 0;
AVMM_DATA_ADDR_WIDTH : integer := 19;
AVMM_DATA_DATA_WIDTH : integer := 32;
AVMM_DATA_BURSTCOUNT_WIDTH : integer := 4;
SECTOR_READ_PROTECTION_MODE : integer := 31;
FLASH_SEQ_READ_DATA_COUNT : integer := 2;
FLASH_ADDR_ALIGNMENT_BITS : integer := 1;
FLASH_READ_CYCLE_MAX_INDEX : integer := 4;
FLASH_RESET_CYCLE_MAX_INDEX : integer := 29;
FLASH_BUSY_TIMEOUT_CYCLE_MAX_INDEX : integer := 112;
FLASH_ERASE_TIMEOUT_CYCLE_MAX_INDEX : integer := 40603248;
FLASH_WRITE_TIMEOUT_CYCLE_MAX_INDEX : integer := 35382;
PARALLEL_MODE : boolean := true;
READ_AND_WRITE_MODE : boolean := true;
WRAPPING_BURST_MODE : boolean := false;
IS_DUAL_BOOT : string := "False";
IS_ERAM_SKIP : string := "False";
IS_COMPRESSED_IMAGE : string := "False"
port (
clock : in std_logic := 'X'; -- clk
reset_n : in std_logic := 'X'; -- reset_n
avmm_data_addr : in std_logic_vector(18 downto 0) := (others => 'X'); -- address
avmm_data_read : in std_logic := 'X'; -- read
avmm_data_writedata : in std_logic_vector(31 downto 0) := (others => 'X'); -- writedata
avmm_data_write : in std_logic := 'X'; -- write
avmm_data_readdata : out std_logic_vector(31 downto 0); -- readdata
avmm_data_waitrequest : out std_logic; -- waitrequest
avmm_data_readdatavalid : out std_logic; -- readdatavalid
avmm_data_burstcount : in std_logic_vector(3 downto 0) := (others => 'X'); -- burstcount
avmm_csr_addr : in std_logic := 'X'; -- address
avmm_csr_read : in std_logic := 'X'; -- read
avmm_csr_writedata : in std_logic_vector(31 downto 0) := (others => 'X'); -- writedata
avmm_csr_write : in std_logic := 'X'; -- write
avmm_csr_readdata : out std_logic_vector(31 downto 0) -- readdata
end component altera_onchip_flash;
begin
onchip_flash_0 : component altera_onchip_flash
generic map (
INIT_FILENAME => "",
INIT_FILENAME_SIM => "",
DEVICE_FAMILY => "MAX 10",
PART_NAME => "10M50DAF484C7G",
DEVICE_ID => "50",
SECTOR1_START_ADDR => 0,
SECTOR1_END_ADDR => 8191,
SECTOR2_START_ADDR => 8192,
SECTOR2_END_ADDR => 16383,
SECTOR3_START_ADDR => 16384,
SECTOR3_END_ADDR => 114687,
SECTOR4_START_ADDR => 114688,
SECTOR4_END_ADDR => 188415,
SECTOR5_START_ADDR => 188416,
SECTOR5_END_ADDR => 360447,
MIN_VALID_ADDR => 0,
MAX_VALID_ADDR => 360447,
MIN_UFM_VALID_ADDR => 0,
MAX_UFM_VALID_ADDR => 16383,
SECTOR1_MAP => 1,
SECTOR2_MAP => 2,
SECTOR3_MAP => 3,
SECTOR4_MAP => 4,
SECTOR5_MAP => 5,
ADDR_RANGE1_END_ADDR => 360447,
ADDR_RANGE1_OFFSET => 2048,
ADDR_RANGE2_OFFSET => 0,
AVMM_DATA_ADDR_WIDTH => 19,
AVMM_DATA_DATA_WIDTH => 32,
AVMM_DATA_BURSTCOUNT_WIDTH => 4,
SECTOR_READ_PROTECTION_MODE => 0,
FLASH_SEQ_READ_DATA_COUNT => 4,
FLASH_ADDR_ALIGNMENT_BITS => 2,
FLASH_READ_CYCLE_MAX_INDEX => 5,
FLASH_RESET_CYCLE_MAX_INDEX => 7,
FLASH_BUSY_TIMEOUT_CYCLE_MAX_INDEX => 36,
FLASH_ERASE_TIMEOUT_CYCLE_MAX_INDEX => 10500000,
FLASH_WRITE_TIMEOUT_CYCLE_MAX_INDEX => 9150,
PARALLEL_MODE => true,
READ_AND_WRITE_MODE => true,
WRAPPING_BURST_MODE => false,
IS_DUAL_BOOT => "False",
IS_ERAM_SKIP => "True",
IS_COMPRESSED_IMAGE => "True"
port map (
clock => clock, -- clk.clk
reset_n => reset_n, -- nreset.reset_n
avmm_data_addr => avmm_data_addr, -- data.address
avmm_data_read => avmm_data_read, -- .read
avmm_data_writedata => avmm_data_writedata, -- .writedata
avmm_data_write => avmm_data_write, -- .write
avmm_data_readdata => avmm_data_readdata, -- .readdata
avmm_data_waitrequest => avmm_data_waitrequest, -- .waitrequest
avmm_data_readdatavalid => avmm_data_readdatavalid, -- .readdatavalid
avmm_data_burstcount => avmm_data_burstcount, -- .burstcount
avmm_csr_addr => avmm_csr_addr, -- csr.address
avmm_csr_read => avmm_csr_read, -- .read
avmm_csr_writedata => avmm_csr_writedata, -- .writedata
avmm_csr_write => avmm_csr_write, -- .write
avmm_csr_readdata => avmm_csr_readdata -- .readdata
end architecture rtl; -- of flash_update
Мне нужно два имиджа - бутлодер (CFM0) а с него я буду прожигать основную програму(CFM1-CFM2). Поэтому мне нужен Dual Compressed Images.
Выставляю Assignments -> Device -> Devise and Pin Options -> Configuration -> Dual Compressed Images
В генериках выставляю
IS_DUAL_BOOT        => "True",
При компиляции получаю ошибку.
Error (169130): Configuration mode specified as Remote but remote update block is not found in design
Если выставляю Assignments -> Device -> Devise and Pin Options -> Configuration -> Single Compressed Image
И генерики
Компилируется без ошибок.
И генерики
Error (14740): Configuration mode on atom "bootloader:U_BOOTLOADER|flash_update:U_FLASH_UPDATE|altera_onchip_flash:onc
hip_flash_0|altera_onchip_flash_block:altera_onchip_flash_block|ufm_block" does not match the project setting. Update and regenerate the Qsys system to match the project setting.
Как бороться с этой бедой?
Сообщение отредактировал Jenya7 - Apr 3 2018, 07:47
RSS Текстовая версия Сейчас: 18th August 2025 - 13:17
Страница сгенерированна за 0.01375 секунд с 7
