> Zynq, Petalinux, прерывания и заголовочные файлы
Balabes
сообщение Apr 11 2018, 12:47
Пользователь №: 77 442
Здравствуйте!
Хочу обработать прерывания от AXI Timer в линуксе. На сайте xilinx нарыл пример.
CODE
#include <linux/kernel.h>
#include <linux/module.h>
#include <linux/interrupt.h>
#include <linux/irq.h>
#include <linux/platform_device.h>
#include <linux/slab.h>
#include <asm/io.h>
MODULE_LICENSE("GPL");
#define DEVICE_NAME "xilaxitimer"
#define IRQ_NUM 91
#define XIL_AXI_TIMER_BASEADDR 0x41C00000
#define XIL_AXI_TIMER_HIGHADDR 0x41C0FFFF
#define XIL_AXI_TIMER_TCSR_OFFSET 0x0
#define XIL_AXI_TIMER_TLR_OFFSET 0x4
#define XIL_AXI_TIMER_TCR_OFFSET 0x8
#define XIL_AXI_TIMER_CSR_INT_OCCURED_MASK 0x00000100
#define XIL_AXI_TIMER_CSR_CASC_MASK 0x00000800
#define XIL_AXI_TIMER_CSR_ENABLE_ALL_MASK 0x00000400
#define XIL_AXI_TIMER_CSR_ENABLE_PWM_MASK 0x00000200
#define XIL_AXI_TIMER_CSR_ENABLE_TMR_MASK 0x00000080
#define XIL_AXI_TIMER_CSR_ENABLE_INT_MASK 0x00000040
#define XIL_AXI_TIMER_CSR_LOAD_MASK 0x00000020
#define XIL_AXI_TIMER_CSR_AUTO_RELOAD_MASK 0x00000010
#define XIL_AXI_TIMER_CSR_EXT_CAPTURE_MASK 0x00000008
#define XIL_AXI_TIMER_CSR_EXT_GENERATE_MASK 0x00000004
#define XIL_AXI_TIMER_CSR_DOWN_COUNT_MASK 0x00000002
#define XIL_AXI_TIMER_CSR_CAPTURE_MODE_MASK 0x00000001
#define TIMER_CNT 0xF8000000
static struct platform_device *pdev;
void *dev_virtaddr;
static int int_cnt;
static irqreturn_t xilaxitimer_isr(int irq,void*dev_id)
unsigned int data;
* Check Timer Counter Value
data = ioread32(dev_virtaddr + XIL_AXI_TIMER_TCR_OFFSET);
printk("xilaxitimer_isr: Interrupt Occurred ! Timer Count = 0x%08X\n",data);
* Clear Interrupt
data = ioread32(dev_virtaddr + XIL_AXI_TIMER_TCSR_OFFSET);
iowrite32(data | XIL_AXI_TIMER_CSR_INT_OCCURED_MASK,
* Disable Timer after 100 Interrupts
int_cnt++;
if (int_cnt>=100)
printk("xilaxitimer_isr: 100 interrupts have been occurred. Disabling timer");
iowrite32(data & ~(XIL_AXI_TIMER_CSR_ENABLE_TMR_MASK),
return IRQ_HANDLED;
static int __init xilaxitimer_init(void)
unsigned int data;
int_cnt = 0;
printk(KERN_INFO "xilaxitimer_init: Initialize Module \"%s\"\n", DEVICE_NAME);
* Register ISR
if (request_irq(IRQ_NUM, xilaxitimer_isr, 0, DEVICE_NAME, NULL)) {
printk(KERN_ERR "xilaxitimer_init: Cannot register IRQ %d\n", IRQ_NUM);
return -EIO;
else {
printk(KERN_INFO "xilaxitimer_init: Registered IRQ %d\n", IRQ_NUM);
* Map Physical address to Virtual address
dev_virtaddr = ioremap_nocache(XIL_AXI_TIMER_BASEADDR,
XIL_AXI_TIMER_HIGHADDR - XIL_AXI_TIMER_BASEADDR + 1);
* Set Timer Counter
iowrite32(TIMER_CNT,
dev_virtaddr + XIL_AXI_TIMER_TLR_OFFSET);
data = ioread32(dev_virtaddr + XIL_AXI_TIMER_TLR_OFFSET);
printk("xilaxitimer_init: Set timer count 0x%08X\n",data);
* Set Timer mode and enable interrupt
iowrite32(XIL_AXI_TIMER_CSR_LOAD_MASK,
iowrite32(XIL_AXI_TIMER_CSR_ENABLE_INT_MASK | XIL_AXI_TIMER_CSR_AUTO_RELOAD_MASK,
* Register Device Module
pdev = platform_device_register_simple(DEVICE_NAME, 0, NULL, 0);
if (pdev == NULL) {
printk(KERN_WARNING "xilaxitimer_init: Adding platform device \"%s\" failed\n", DEVICE_NAME);
kfree(pdev);
return -ENODEV;
* Start Timer
iowrite32(data | XIL_AXI_TIMER_CSR_ENABLE_TMR_MASK,
return 0;
static void __exit xilaxitimer_edit(void)
* Exit Device Module
iounmap(dev_virtaddr);
free_irq(IRQ_NUM, NULL);
platform_device_unregister(pdev);
printk(KERN_INFO "xilaxitimer_edit: Exit Device Module \"%s\".\n", DEVICE_NAME);
module_init(xilaxitimer_init);
module_exit(xilaxitimer_edit);
MODULE_AUTHOR ("Xilinx");
MODULE_DESCRIPTION("Test Driver for Zynq PL AXI Timer.");
MODULE_LICENSE("GPL v2");
MODULE_ALIAS("custom:xilaxitimer");
собираю образ и файловую систему. загружается. все отлично. но в /usr/include/linux нет <linux/interrupt.h> и других. понимаю что нужно в конфиге ядра или файловой системе что-то сделать.
Кто опытен в линуксах на цинке подскажите как быть. т.к. опыта особого ни в цинке ни в линуксе не имею.
Сообщение отредактировал Balabes - Apr 11 2018, 16:48
RSS Текстовая версия Сейчас: 6th September 2025 - 10:03
Страница сгенерированна за 0.02038 секунд с 7
