> вышел хотфикс SIGRITY 2017/2018, хотфиксы для SIGRITY
rom67
сообщение Aug 7 2018, 07:04
Пользователь №: 88 095
вышел хотфикс SIGRITY 2017, HOTFIX VERSION: 011
Fixed CCRs: SIGRITY2017 HF011
08-03-2018
CCRID     Product           Title
1926744   3D_EM             Port is invalid because connected shape is too narrow error is not reported in PowerSI.err file
1885224   ASI_PI            Allegro's mirrored via is not translated correctly
1946644   ASI_SI            The dynamic ground shape is missing even with 'Ignore voids in engulfed static shapes' option enabled in SPDIF
1927038   OPTIMIZEPI        Several problems related to OptimizePI TCL script run occur in batch mode
1890354   POWERDC           Initialize FEM fail error is generated for PowerDC thermal simulation
1926224   POWERDC           Resistors with values greater than 100 reappear in the canvas when Build Tree option is used multiple times
1928236   POWERDC           PowerDC in 17.2 HF009 cannot recognize line continuation char "\" in TCL script in Linux, while in 17.2 HF008 it does
1928329   POWERDC           PowerTree does not run the simulation and looks for missing current information on Disabled Sinks
1928875   POWERDC           Resistance filter does not work
1928975   POWERDC           Incorrect values calculated for Global Via Current and Constraint on Global Current Density (A/mm*mm)
1932407   POWERDC           PowerDC cannot import a stackup file (*.csv) that is exported by PowerDC
1933500   POWERDC           2D E-Distribution plots display results incorrectly
1934406   POWERDC           Import stackup using CSV file option cannot complete import operation in PowerDC
1948280   POWERDC           PowerTree cannot read the value from Allegro netlist files
1917365   POWERSI           PowerSI EMC/EMI analysis exits abruptly when using 40-bit pattern for current stimulus
1929068   POWERSI           Check S-Parameter by BBS does not function properly if the path contains space characters
1946024   SPEED2000         Unable to correlate simulation results to measured; result from third-party tool is much closer to measured than SPDSIM
1909072   SYSTEMSI          SystemSI PBA uses memory's pullup voltage value for VDDCA instead of using controllers's VDDQ value
1909075   SYSTEMSI          SystemSI PBA channel and circuit simulations do not respond if bit pattern is 1s or 0s
1911297   SYSTEMSI          SystemSI PBA (DDR) circuit simulations with 10K bits are not working in Linux
1916101   SYSTEMSI          Lack of stimulus in file causes Serial Link Analysis to become unresponsive
1919562   SYSTEMSI          SystemSI generates wrong timing bathtub curves in channel simulations for write and read
1920441   SYSTEMSI          SystemSI correlation is not working in Windows and Linux when EBD model is used in READ cycle
1923679   SYSTEMSI          System Explorer simulation aborts because of large time step value
1935195   SYSTEMSI          Frequency Domain response simulation failed for some nets due to "<" and ">" in the net name
1894124   XCITEPI           Large capacitance and resistance are reported in EPA results
1927092   XCITEPI           VSDP header is missing port for pseudo bump
1933974   XCITEPI           Via resistance is wrong in new clf+gds flow
вышла база SIGRITY 2018
Fixed CCRs: SIGRITY2018 BASE
07-20-2018
CCRID     Product           Title
1861523   3D_EM             Simulation is extremely slow for 3D-EM/Hybrid Cut and Stitch flow
1891759   3D_EM             Cannot enable the port using TCL command
1909780   3D_EM             3D-EM reports "Engine last run failed" in the log file when running a case in user's Linux LSF
1921332   3D_EM             Performing cutting and stitching operation and generating spds results in an error
1937912   3D_EM             Multi-terminal circuits cause simulation to become unresponsive
1933491   ASI_PI            TCL script sigrity::open document does not work correctly
1682898   ASI_SI            Lower section of ERC/PCB Editor windows gets hidden under Windows task bar
1895159   ASI_SI            Mirrored component with asymmetric outline is displayed with wrong outline at bottom layer
1918871   ASI_SI            Square multi-drill padstack is not translated correctly
1938587   ASI_SI            GND structures are lost after the translation of .brd file (directly or using SPDLinks) in Sigrity tools
1940376   ASI_SI            Large fake antipad incorrectly appears after translation
1726802   OPTIMIZEPI        After archiving, the path for the snp models in the layout file is wrong
1887758   OPTIMIZEPI        OptimizePI shape process generates incorrect short errors
1917197   OPTIMIZEPI        AmLibGen does not properly include SPICE circuit models for resistors
1923826   OPTIMIZEPI        Impedance observations cannot be seen after cutting
1822501   POWERDC           PowerTree is unable to handle multi-pin series devices
1893753   POWERDC           Component center location should be updated when merging two design files together
1899910   POWERDC           Extract PowerTree in Design does not recognize component value
1920529   POWERDC           Setting output current ratio of VRM1 to 0% still outputs current after simulation
1920546   POWERDC           MultiVRMs generate different temperature results
1922993   POWERDC           When comparing two trees, zoom area is in sync between the trees, but zoom fit is not
1925235   POWERDC           Multiple filament models fail due to overlapping vias
1928996   POWERDC           Extract PowerTree in Design not parsing component values
1932659   POWERDC           Pin resistance is not calculated by passing through multiple power nets
1877194   POWERSI           When switching the mode in PSI from ERC to Extraction, the layout view is still stuck on the impedance overlay
1916930   POWERSI           TCL support required to show Y-axis in log scale
1918816   POWERSI           TCL command inserting shapes not working as expected
1921415   POWERSI           ERC Report generation failed with script error
1936971   POWERSI           S600 in Sigrity 2018 exits unexpectedly in Red Hat Linux 7.4 environment
1805975   SPEED2000         TDR simulation does not run due to node errors
1912245   SPEED2000         Change the behavior of SystemSI to reject any SPICE file with "$" comments or have SPDSIM accept such files
1890918   TRANSLATOR        Wirebonds are not translated using SPDLink
1909248   TRANSLATOR        [PowerSI] Via diameter is changed with save-reopen operation
1917304   TRANSLATOR        ODB++ is not translating properly, but it looks good in ODB++ Viewer
1920373   TRANSLATOR        Rotation of wirebond shell is translated incorrectly
1921290   TRANSLATOR        Traces on negative plane layer in ODB++ are not translated correctly
1943973   TRANSLATOR        Need correct ODB++ translation of backdrill
1888419   XTRACTIM          Unexpected inductance results are reported with low solution frequency setting in XtractIM
1908292   XTRACTIM          EPA mode generates "Net loop L extraction" and "invalid data in file" errors
1918783   XTRACTIM          Net Loop L Extraction Error
1920225   XTRACTIM          In resource log file, print the run time in days:hr:min:sec in addition to the run time in seconds
RSS Текстовая версия Сейчас: 20th August 2025 - 00:25
