> MAX10 - Flash Update module
Jenya7
сообщение Apr 3 2018, 07:47
Пользователь №: 71 075
Я создал Flash Update module - Tools->IP Catalog->Library->Basic Functions->On Chip Memory->Altera On-Chip Flash
CODE
entity flash_update is
port (
clock : in std_logic := '0'; -- clk.clk
avmm_csr_addr : in std_logic := '0'; -- csr.address
avmm_csr_read : in std_logic := '0'; -- .read
avmm_csr_writedata : in std_logic_vector(31 downto 0) := (others => '0'); -- .writedata
avmm_csr_write : in std_logic := '0'; -- .write
avmm_csr_readdata : out std_logic_vector(31 downto 0); -- .readdata
avmm_data_addr : in std_logic_vector(18 downto 0) := (others => '0'); -- data.address
avmm_data_read : in std_logic := '0'; -- .read
avmm_data_writedata : in std_logic_vector(31 downto 0) := (others => '0'); -- .writedata
avmm_data_write : in std_logic := '0'; -- .write
avmm_data_readdata : out std_logic_vector(31 downto 0); -- .readdata
avmm_data_waitrequest : out std_logic; -- .waitrequest
avmm_data_readdatavalid : out std_logic; -- .readdatavalid
avmm_data_burstcount : in std_logic_vector(3 downto 0) := (others => '0'); -- .burstcount
reset_n : in std_logic := '0' -- nreset.reset_n
end entity flash_update;
architecture rtl of flash_update is
component altera_onchip_flash is
generic (
INIT_FILENAME : string := "";
INIT_FILENAME_SIM : string := "";
DEVICE_FAMILY : string := "Unknown";
PART_NAME : string := "Unknown";
DEVICE_ID : string := "Unknown";
SECTOR1_START_ADDR : integer := 0;
SECTOR1_END_ADDR : integer := 0;
SECTOR2_START_ADDR : integer := 0;
SECTOR2_END_ADDR : integer := 0;
SECTOR3_START_ADDR : integer := 0;
SECTOR3_END_ADDR : integer := 0;
SECTOR4_START_ADDR : integer := 0;
SECTOR4_END_ADDR : integer := 0;
SECTOR5_START_ADDR : integer := 0;
SECTOR5_END_ADDR : integer := 0;
MIN_VALID_ADDR : integer := 0;
MAX_VALID_ADDR : integer := 0;
MIN_UFM_VALID_ADDR : integer := 0;
MAX_UFM_VALID_ADDR : integer := 0;
SECTOR1_MAP : integer := 0;
SECTOR2_MAP : integer := 0;
SECTOR3_MAP : integer := 0;
SECTOR4_MAP : integer := 0;
SECTOR5_MAP : integer := 0;
ADDR_RANGE1_END_ADDR : integer := 0;
ADDR_RANGE1_OFFSET : integer := 0;
ADDR_RANGE2_OFFSET : integer := 0;
AVMM_DATA_ADDR_WIDTH : integer := 19;
AVMM_DATA_DATA_WIDTH : integer := 32;
AVMM_DATA_BURSTCOUNT_WIDTH : integer := 4;
SECTOR_READ_PROTECTION_MODE : integer := 31;
FLASH_SEQ_READ_DATA_COUNT : integer := 2;
FLASH_ADDR_ALIGNMENT_BITS : integer := 1;
FLASH_READ_CYCLE_MAX_INDEX : integer := 4;
FLASH_RESET_CYCLE_MAX_INDEX : integer := 29;
FLASH_BUSY_TIMEOUT_CYCLE_MAX_INDEX : integer := 112;
FLASH_ERASE_TIMEOUT_CYCLE_MAX_INDEX : integer := 40603248;
FLASH_WRITE_TIMEOUT_CYCLE_MAX_INDEX : integer := 35382;
PARALLEL_MODE : boolean := true;
READ_AND_WRITE_MODE : boolean := true;
WRAPPING_BURST_MODE : boolean := false;
IS_DUAL_BOOT : string := "False";
IS_ERAM_SKIP : string := "False";
IS_COMPRESSED_IMAGE : string := "False"
port (
clock : in std_logic := 'X'; -- clk
reset_n : in std_logic := 'X'; -- reset_n
avmm_data_addr : in std_logic_vector(18 downto 0) := (others => 'X'); -- address
avmm_data_read : in std_logic := 'X'; -- read
avmm_data_writedata : in std_logic_vector(31 downto 0) := (others => 'X'); -- writedata
avmm_data_write : in std_logic := 'X'; -- write
avmm_data_readdata : out std_logic_vector(31 downto 0); -- readdata
avmm_data_waitrequest : out std_logic; -- waitrequest
avmm_data_readdatavalid : out std_logic; -- readdatavalid
avmm_data_burstcount : in std_logic_vector(3 downto 0) := (others => 'X'); -- burstcount
avmm_csr_addr : in std_logic := 'X'; -- address
avmm_csr_read : in std_logic := 'X'; -- read
avmm_csr_writedata : in std_logic_vector(31 downto 0) := (others => 'X'); -- writedata
avmm_csr_write : in std_logic := 'X'; -- write
avmm_csr_readdata : out std_logic_vector(31 downto 0) -- readdata
end component altera_onchip_flash;
begin
onchip_flash_0 : component altera_onchip_flash
generic map (
INIT_FILENAME => "",
INIT_FILENAME_SIM => "",
DEVICE_FAMILY => "MAX 10",
PART_NAME => "10M50DAF484C7G",
DEVICE_ID => "50",
SECTOR1_START_ADDR => 0,
SECTOR1_END_ADDR => 8191,
SECTOR2_START_ADDR => 8192,
SECTOR2_END_ADDR => 16383,
SECTOR3_START_ADDR => 16384,
SECTOR3_END_ADDR => 114687,
SECTOR4_START_ADDR => 114688,
SECTOR4_END_ADDR => 188415,
SECTOR5_START_ADDR => 188416,
SECTOR5_END_ADDR => 360447,
MIN_VALID_ADDR => 0,
MAX_VALID_ADDR => 360447,
MIN_UFM_VALID_ADDR => 0,
MAX_UFM_VALID_ADDR => 16383,
SECTOR1_MAP => 1,
SECTOR2_MAP => 2,
SECTOR3_MAP => 3,
SECTOR4_MAP => 4,
SECTOR5_MAP => 5,
ADDR_RANGE1_END_ADDR => 360447,
ADDR_RANGE1_OFFSET => 2048,
ADDR_RANGE2_OFFSET => 0,
AVMM_DATA_ADDR_WIDTH => 19,
AVMM_DATA_DATA_WIDTH => 32,
AVMM_DATA_BURSTCOUNT_WIDTH => 4,
SECTOR_READ_PROTECTION_MODE => 0,
FLASH_SEQ_READ_DATA_COUNT => 4,
FLASH_ADDR_ALIGNMENT_BITS => 2,
FLASH_READ_CYCLE_MAX_INDEX => 5,
FLASH_RESET_CYCLE_MAX_INDEX => 7,
FLASH_BUSY_TIMEOUT_CYCLE_MAX_INDEX => 36,
FLASH_ERASE_TIMEOUT_CYCLE_MAX_INDEX => 10500000,
FLASH_WRITE_TIMEOUT_CYCLE_MAX_INDEX => 9150,
PARALLEL_MODE => true,
READ_AND_WRITE_MODE => true,
WRAPPING_BURST_MODE => false,
IS_DUAL_BOOT => "False",
IS_ERAM_SKIP => "True",
IS_COMPRESSED_IMAGE => "True"
port map (
clock => clock, -- clk.clk
reset_n => reset_n, -- nreset.reset_n
avmm_data_addr => avmm_data_addr, -- data.address
avmm_data_read => avmm_data_read, -- .read
avmm_data_writedata => avmm_data_writedata, -- .writedata
avmm_data_write => avmm_data_write, -- .write
avmm_data_readdata => avmm_data_readdata, -- .readdata
avmm_data_waitrequest => avmm_data_waitrequest, -- .waitrequest
avmm_data_readdatavalid => avmm_data_readdatavalid, -- .readdatavalid
avmm_data_burstcount => avmm_data_burstcount, -- .burstcount
avmm_csr_addr => avmm_csr_addr, -- csr.address
avmm_csr_read => avmm_csr_read, -- .read
avmm_csr_writedata => avmm_csr_writedata, -- .writedata
avmm_csr_write => avmm_csr_write, -- .write
avmm_csr_readdata => avmm_csr_readdata -- .readdata
end architecture rtl; -- of flash_update
Мне нужно два имиджа - бутлодер (CFM0) а с него я буду прожигать основную програму(CFM1-CFM2). Поэтому мне нужен Dual Compressed Images.
Выставляю Assignments -> Device -> Devise and Pin Options -> Configuration -> Dual Compressed Images
В генериках выставляю
IS_DUAL_BOOT        => "True",
При компиляции получаю ошибку.
Error (169130): Configuration mode specified as Remote but remote update block is not found in design
Если выставляю Assignments -> Device -> Devise and Pin Options -> Configuration -> Single Compressed Image
И генерики
Компилируется без ошибок.
И генерики
Error (14740): Configuration mode on atom "bootloader:U_BOOTLOADER|flash_update:U_FLASH_UPDATE|altera_onchip_flash:onc
hip_flash_0|altera_onchip_flash_block:altera_onchip_flash_block|ufm_block" does not match the project setting. Update and regenerate the Qsys system to match the project setting.
Как бороться с этой бедой?
Сообщение отредактировал Jenya7 - Apr 3 2018, 07:47
Ответов (1 - 6)
DmitryR
сообщение Apr 6 2018, 13:10
Из: Siegen
Пользователь №: 2 770
Надо сделать так, чтобы он бы found. Вставить то есть. Ибо без него вы не сможете сделать даже программную перезагрузку, и тем более не сможете сказать чипу, что он должен загрузиться из второй партиции.
Блок этот правда называется не Remote Update, а Dual Configuration или Dual Boot, в этом подстава.
Jenya7
сообщение Apr 10 2018, 05:11
спасибо. вставил.
CODE
entity altera_dual_config is
port (
avmm_rcv_address : in std_logic_vector(2 downto 0) := (others => '0'); -- avalon.address
avmm_rcv_read : in std_logic := '0'; -- .read
avmm_rcv_writedata : in std_logic_vector(31 downto 0) := (others => '0'); -- .writedata
avmm_rcv_write : in std_logic := '0'; -- .write
avmm_rcv_readdata : out std_logic_vector(31 downto 0); -- .readdata
clk : in std_logic := '0'; -- clk.clk
nreset : in std_logic := '0' -- nreset.reset_n
end entity altera_dual_config;
architecture rtl of altera_dual_config is
component altera_dual_boot is
generic (
INTENDED_DEVICE_FAMILY : string := "";
CONFIG_CYCLE : integer := 28;
RESET_TIMER_CYCLE : integer := 40
port (
clk : in std_logic := 'X'; -- clk
nreset : in std_logic := 'X'; -- reset_n
avmm_rcv_address : in std_logic_vector(2 downto 0) := (others => 'X'); -- address
avmm_rcv_read : in std_logic := 'X'; -- read
avmm_rcv_writedata : in std_logic_vector(31 downto 0) := (others => 'X'); -- writedata
avmm_rcv_write : in std_logic := 'X'; -- write
avmm_rcv_readdata : out std_logic_vector(31 downto 0) -- readdata
end component altera_dual_boot;
begin
dual_boot_0 : component altera_dual_boot
generic map (
INTENDED_DEVICE_FAMILY => "MAX 10",
CONFIG_CYCLE => 11,
RESET_TIMER_CYCLE => 16
port map (
clk => clk, -- clk.clk
nreset => nreset, -- nreset.reset_n
avmm_rcv_address => avmm_rcv_address, -- avalon.address
avmm_rcv_read => avmm_rcv_read, -- .read
avmm_rcv_writedata => avmm_rcv_writedata, -- .writedata
avmm_rcv_write => avmm_rcv_write, -- .write
avmm_rcv_readdata => avmm_rcv_readdata -- .readdata
end architecture rtl; -- of altera_dual_config
теперь проект компилируется. но непонятно как Dual Configuration мапить.
component altera_dual_config is
port (
end component;
например что за адрес avmm_rcv_address и зачем все эти avmm_rcv_writedata, avmm_rcv_readdata - они есть в flash_update модуле.
Сообщение отредактировал Jenya7 - Apr 10 2018, 05:11
DmitryR
сообщение Apr 10 2018, 07:26
Из: Siegen
А теперь почитайте документацию на все используемые блоки.
Jenya7
сообщение Apr 10 2018, 20:02
да читал, как же без этого. Altera On-Chip Flash расписан хорошо, все понятно, а на Dual Configuration нигде внятного описания не нашел.
вот описание модуля. на странице 19 рисунок модуля и это самая емкая информация в документе.
Сообщение отредактировал Jenya7 - Apr 10 2018, 20:10
Прикрепленный файл  ug_m10_config.pdf ( 586.86 килобайт ) Кол-во скачиваний: 9
Jenya7
сообщение Apr 29 2018, 06:03
Когда я генерировал модуль Altera On-Chip Flash в Qsys получил 5 секторов с адресами (на картинке)
А в сгенерированном коде адреса совсем другие
Кому верить?
Сообщение отредактировал Jenya7 - Apr 29 2018, 06:04
Jenya7
сообщение Sep 25 2018, 13:38
Такой вопрос.
Судя по картинке - ID5 - это CFM0. То есть чтоб прожечь CFM1 - надо начать с ID3 (16384) по ID4 (188415) ?
RSS Текстовая версия Сейчас: 24th August 2025 - 04:32
Страница сгенерированна за 0.01438 секунд с 7
