Приветствую.
Установил ecos-2.0 под cygwin (CYGWIN_NT-5.1 1.5.19)
Пытаюсь собрать configtool следуя инструкциям с
http://www.ecoscentric.com/devzone/configtool.shtml. То есть для начала собираю wxWindows-2.4 и тут вылазят ошибки:
/tmp/wxWindows-2.4.0/src/msw/window.cpp: In member function `virtual long int wxWindow::MSWWindowProc(WXUINT, WXWPARAM, WXLPARAM)':
/tmp/wxWindows-2.4.0/src/msw/window.cpp:2661: error: `VK_OEM_PLUS' undeclared (first use this function)
/tmp/wxWindows-2.4.0/src/msw/window.cpp:2661: error: (Each undeclared identifier is reported only once for each function it appears in.)
/tmp/wxWindows-2.4.0/src/msw/window.cpp:2662: error: `VK_OEM_COMMA' undeclared (first use this function)
/tmp/wxWindows-2.4.0/src/msw/window.cpp:2663: error: `VK_OEM_MINUS' undeclared (first use this function)
/tmp/wxWindows-2.4.0/src/msw/window.cpp:2664: error: `VK_OEM_PERIOD' undeclared (first use this function)
/tmp/wxWindows-2.4.0/src/msw/window.cpp: In function `int wxCharCodeMSWToWX(int)':
/tmp/wxWindows-2.4.0/src/msw/window.cpp:4762: error: `VK_OEM_PLUS' undeclared (first use this function)
/tmp/wxWindows-2.4.0/src/msw/window.cpp:4763: error: `VK_OEM_COMMA' undeclared (first use this function)
/tmp/wxWindows-2.4.0/src/msw/window.cpp:4764: error: `VK_OEM_MINUS' undeclared (first use this function)
/tmp/wxWindows-2.4.0/src/msw/window.cpp:4765: error: `VK_OEM_PERIOD' undeclared (first use this function)
make: *** [window.o] Error 1
При этом windows.cpp однозначно имеет определения этих макросов. Что не так?
