> Viewpoint Validator
Dainis
сообщение Jan 1 2005, 12:03
Пользователь №: 154
Разыскивается Viewpoint Validator
http://www.viewpointengineering.com/viewnet/products.html
High test speed is provided by running a little test code on the target CPU. Management flexibility is provided by running test management code on the host. Test management code is developed by the development and/or test engineer in a high-level language similar to Java or C.
Validator combines the following basic support tools that are needed to move a new board from engineering to manufacturing
Remote control of microprocessor-based boards
Test creation and debugging in engineering
Interactive hardware debugging
Automated test analysis and reporting
Test management for QA and Manufacturing Test
Manufacturing functional test
Validator can manage a variety of targets. Connect MIPS, ARM, PPC or Xscale target boards through JTAG. Validator can be customized to your on-board debug monitor via a serial or Ethernet connection.
One button test execution with automated reporting
Portable test cases - runtime environment variables
High speed via minimal assembly language usage.
Multi-CPU support:
MIPS32-64, PPC,
ARM-7,9, Xscale.
Quickly adapts to others
Uses JTAG instrumentation interface from Macraigor Systems, Ltd.
Integrated test development support with high-level and low-level debugging
- Dainis   Viewpoint Validator   Jan 1 2005, 12:03
RSS Текстовая версия Сейчас: 18th August 2025 - 19:37
Страница сгенерированна за 0.01347 секунд с 7
