> Кто знаком с ADM-SDK ? Собранный из сорцов пример при запуске роняет систему.
MarSS
сообщение Nov 15 2006, 06:43
Из: Сингапур
Пользователь №: 15 861
не понимаю что происходит с картой - она перегружает машину при обращении.
Осваиваю PCI карту ADM-XRC-4/LX160-10, пытаюсь собрать пример из ADM SDK User Guide:
Synopsis
The Simple FPGA design demonstrates how to implement host-accessible registers in an FPGA design.
** simple.v - Trivial design demonstrating how to implement
**            registers in the FPGA.
`timescale 1ns / 100ps
module simple(
    lclk,
    lreset_l,
    lwrite,
    lads_l,
    lblast_l,
    lbterm_l,
    la,
    ld,
    lready_l,
    lbe_l,
    fholda);
input           lclk;
wire            lclk;
input           lreset_l;
wire            lreset_l;
input           lwrite;
wire            lwrite;
input           lads_l;
wire            lads_l;
input           lblast_l;
wire            lblast_l;
output          lbterm_l;
wire            lbterm_l;
inout [31:0]    ld;
wire  [31:0]    ld;
input [23:2]    la;
wire  [23:2]    la;
output          lready_l;
wire            lready_l;
input [3:0]     lbe_l;
wire  [3:0]     lbe_l;
input           fholda;
wire            fholda;
wire            rst;
wire            lblast_i;
wire            lads_i;
wire            lwrite_i;
wire            lready_o;
wire            lready_oe;
wire            lbterm_o;
wire            lbterm_oe;
wire [23:2]     la_i;
wire [31:0]     ld_o;
wire [31:0]     ld_i;
wire            ld_oe;
wire [3:0]      lbe_i;
wire            qlads;
wire            ds_xfer;
wire            ds_decode;
wire            ds_write;
reg  [23:2]     la_q;
reg  [31:0]     reg0;
wire [31:0]     reg0_rev;
reg             oe_reg0;
reg  [31:0]     reg1;
reg             oe_reg1;
// Convert the inputs to active high.
assign rst      = ~lreset_l;
assign lblast_i = ~lblast_l;
assign lads_i   = ~lads_l;
assign lwrite_i = lwrite;
assign la_i     = la;
assign ld_i     = ld;
assign lbe_i    = ~lbe_l;
// Generate a qualified version of 'lads_l', which is
// asserted when the FPGA is addressed AND the FPGA is
// not the local bus master.
assign qlads = lads_i && !la_i[23] && !fholda;
// Latch the local bus address on the 'lads_l' pulse.
always @ (posedge rst or posedge lclk)
begin
    if (rst) begin
        la_q <= 0;
    end else begin
        if (lads_i) begin
            la_q <= la_i;
        end
    end
end
// 'lbterm_l' should only be driven when the FPGA is addressed; otherwise
// float, because the control logic on the card might also drive it.
assign lbterm_l = lbterm_oe ? ~lbterm_o : 1'bZ;
// 'lready_l' should only be driven when the FPGA is addressed; otherwise
// float because the control logic on the card might also drive it.
assign lready_l = lready_oe ? ~lready_o : 1'bZ;
// Drive the local data bus on a read.
assign ld = ld_oe ? ld_o : 32'hZZZZZZZZ;
// If the current cycle is a write, update the registers
begin
    if (rst) begin
        reg0 <= 0;
        reg1 <= 0;
    end else begin
        if (ds_xfer && ds_write) begin
            if (!la_q[2]) begin
                if (lbe_i[0]) begin
                    reg0[7:0] <= ld_i[7:0];
                end
                if (lbe_i[1]) begin
                    reg0[15:8] <= ld_i[15:8];
                end
                if (lbe_i[2]) begin
                    reg0[23:16] <= ld_i[23:16];
                end
                if (lbe_i[3]) begin
                    reg0[31:24] <= ld_i[31:24];
                end
            end else begin
                if (lbe_i[0]) begin
                    reg1[7:0] <= ld_i[7:0];
                end
                if (lbe_i[1]) begin
                    reg1[15:8] <= ld_i[15:8];
                end
                if (lbe_i[2]) begin
                    reg1[23:16] <= ld_i[23:16];
                end
                if (lbe_i[3]) begin
                    reg1[31:24] <= ld_i[31:24];
                end
            end
        end
    end
end
// Generate the 'oe_reg*' signals, for enabling registers onto
// the internal data bus.
begin
    if (rst) begin
        oe_reg0 <= 1'b0;
        oe_reg1 <= 1'b0;
    end else begin
        if (ds_xfer && (lblast_i || lbterm_o)) begin
            oe_reg0 <= 1'b0;
            oe_reg1 <= 1'b0;
        end else begin
            if (ds_decode && !ds_write) begin
                oe_reg0 <= ~la_q[2];
                oe_reg1 <= la_q[2];
            end
        end
    end
end
// Drive 'ld_o' with nibble reversed 'reg0' when register 0 is read,
// and with 'reg1' when register 1 is read.
// This synthesises to an internal tristate bus, unless the
// synthesis tool optimises it into a multiplexor.
assign reg0_rev = { reg0[3:0],
                    reg0[7:4],
                    reg0[11:8],
                    reg0[15:12],
                    reg0[19:16],
                    reg0[23:20],
                    reg0[27:24],
                    reg0[31:28] };
assign ld_o = oe_reg0 ? reg0_rev : 32'hZZZZZZZZ;
assign ld_o = oe_reg1 ? reg1 : 32'hZZZZZZZZ;
// Instantiate the direct slave state machine; monitors the local bus for
// direct slave cycles and responds appropriately.
plxdssm plxdssm0(
    .clk        (lclk),
    .rst        (rst),
    .sr         (1'b0),
    .qlads      (qlads),
    .lblast     (lblast_i),
    .lwrite     (lwrite_i),
    .ld_oe      (ld_oe),
    .lready     (lready_o),
    .lready_oe  (lready_oe),
    .lbterm     (lbterm_o),
    .lbterm_oe  (lbterm_oe),
    .transfer   (ds_xfer),
    .decode     (ds_decode),
    .write      (ds_write),
    .ready      (1'b1),
    .stop       (1'b1));
endmodule
собсна нужное действие с входом происходит вот тут
                    reg0[7:4],
                    reg0[11:8],
                    reg0[15:12],
                    reg0[19:16],
                    reg0[23:20],
                    reg0[27:24],
                    reg0[31:28] };
т.е. шестнадцатиричные цифры переставляются в обратном порядке.
А когда пытаюсь только в этом месте что-нибудь другое с входом сделать, например вот
parameter oper1 = 32'b11111100000011110000111000110010;
assign reg0_rev = $signed(reg0)*$signed(oper1);
т.е. умножить на константу - система падает, когда приложение посылает карте первое же число. Умножать можно и просто на 2, результат тот же. Все функции вплоть до ADMXRC2_ConfigureFromFile выполняются успешно, все падает уже на этапе
while (1)
        scanf("%lx", &dataOut);
        fpgaSpace[0] = (DWORD) dataOut;
        dataIn = (unsigned long) fpgaSpace[0];
        printf("Out = %8.8lx, In = %8.8lx\n", (unsigned long) dataOut, (unsigned long) dataIn);
        if (dataOut == 0x55AAU)
            break;
Win2003Server
Собираю .bit в Xilinx ISE8.1+XST с .ucf из этого же примера.
Для общения с карточкой использую ADM SDK4.6.0, С++ код приложения собираю в Visual Studio (также из примера, и не изменяю его вообще никак).
Что может вызывать такую странную реакцию машины? Почему общение с картой происходит нормально вплоть до разводки, а первое же обращение уже не срабатывает?
RSS Текстовая версия Сейчас: 23rd July 2025 - 18:16
Страница сгенерированна за 0.01409 секунд с 7
