> Orcad Layout Plus 10.5 & слои SP2, SP3, как включить?
Old1
сообщение Dec 1 2006, 00:47
Из: Могилев
Пользователь №: 7 095
В менеджере библиотек при создании футпринта планирую использовать слои SPARE2(SP2) и SPARE3(SP3), но при выходе и из менеджера библиотек, в окне дизайна эти слои не доступны, вопрос: можно ли подключить эти слои, и если можно то как?
Еще интересует назначение этих слоев. Облазил весь хелп, но на эту тему ничего не нашел (кроме упоминания о том, что существуют такие Layer library names)...
arttab
сообщение Dec 1 2006, 07:10
Из: Новосибирск
Пользователь №: 1 371
I have footprints that loose obstacles and/or text from my footprints on one of the following layers: COMMENT, SPARE2, SPARE3. Why?
PROBLEM:
This problem occurrs when you save a footprint to an exiting (older) library. These libraries do not have COMMENT, SPARE2, and SPARE3 layers, and therefore there are unable to store any information placed on those layers. To solve this problem, you can add layers to your existing library, or save the footprint to a new library.
SOLUTION:
To add layers to an existing library:
1. Open the main (Lsession) window of Layout.
2. From the File menu, select Open. The Open Board dialog box appears.
3. In the Files of type: text box, select All Files (*.*).
4. Navigate to your .LLB library file and click Open.
5. In the board editor, open the Layers spreadsheet.
6. Click to highlight the NOTES layer.
7. Press the Insert key to make a copy of the NOTES layer. The new layer, NOTES2, appears at the bottom of the Layers spreadsheet.
Note: If the NOTES layer does not exist in your library, you may copy any of the other documentation layers.
8. Repeat step 6 and 7 to make as many layers as are needed.
Note: Once a layer has been added, it cannot be removed after you have saved the library.
9. Double click on a new layer name. The Edit Layer dialog box appears.
10. Change the following information accordingly.
Layer Name Layer NickName Layer LibName
COMMENT COM COMMENT
SPARE2 SP2 SPARE2
SPARE3 SP3 SPARE3
Warning: We recommend that you never change layer nicknames. This is one instance where it is ok.
11. From the File menu, select Save As. The Save As dialog box appears.
12. In the Save as type: text box, select Library (*.llb).
13. Give the library a name and click Save.
If you view the library in the library manager, you will now see that the information may be saved on the new layers. You must remove and re-add the library to the list to view available to view your changes.
Unfortunately, you will need to add the colors for these layers each time you load the library since color information is not retained.
COMMENT, SPARE2, SPARE3, missing layer, add new layer, library Document number: LAY03035
Applies to: Layout ver. All
Created on: 4/6/2001
Last modified: 05/03/01
Copyright © 2005, Cadence Design Systems, Inc.
All rights reserved.
если я правильно понял, то в этих слоях можно делать свои коментарии и не более того.
OrCAD, Altium,IAR, AVR....
Old1
сообщение Dec 1 2006, 13:25
Из: Могилев
Спасибо за цитату.
Я для этого эти слои и собираюсь использовать.
Включил слои в проекте. Теперь другая проблема: этих слоев не видно в окне Post Process. Вопрос можно ли их туда добавить?
KiV
сообщение Dec 1 2006, 18:34
Пользователь №: 56
Добавить точно так-же, как было описано выше для таблички Layers.
Т.е. в таблице Post Process становитесь на какой-либо похожий слой (для Вас подойдет Fab), нажимаете Insert и получаете копию слоя для Post Process. Потом переименовываете его как надо в Properties, ставите там-же нужные параметры.
Потом надо назначить новому Post Process слои из проекта. Для этого по правой кнопке вызываем Preview и потом при активном окне предпросмотра вызываем Color Settings (кнопка с цветными квадратиками). Там уже можно включить/выключить нужные слои проекта (там-же можно добавлять удалять отображаемые слои).
Old1
сообщение Dec 1 2006, 21:56
Из: Могилев
2KiV Спасибо! Вот это:
кардинально помогло!
Old1
сообщение Dec 2 2006, 18:08
Из: Могилев
В догонку еще вопрос по слоям. Как я понял (изучая help) в менеджере библиотек представлены и доступны только библиотечные слои (слои шаблоны) их 17:
TOP
BOTTOM
PLANE
INNER
SMTOP
SMBOT
SPTOP
SPBOT
SSTOP
SSBOT
ASYTOP
ASYBOT
DRLDWG
DRILL
COMMENT
SPARE2
SPARE3
и добавить новые, например дополнительный Documentation layer, у меня возможности нет. Это так? Или все таки есть возможность добавить слой? ... Попытка добавить дополнительные слои (кроме SP2, SP3) в библиотеку, способом предложенным arttab, к желаемому успеху не привела. Для полного счастья хотелось бы иметь еще один Documentation layer.
KiV
сообщение Dec 4 2006, 13:40
Пользователь №: 56
Слой добавить можно, но только во всех менюшках Library Manager отображаются только указанные выше слои, а новые болтаются неприкаянными в библиотеке и никак их отобразить в Library Manager у меня не получилось. А если открыть библиотеку в Layout - там новые слои есть sad.gif.
arttab
сообщение Dec 5 2006, 06:13
Из: Новосибирск
Опять же если я понял правильно из цитаты - эти слои для совместимости со старыми версиями оркада. Насколько старыми это вопрос. Лучше другими слоями обходиться
Vinnetu
сообщение Dec 5 2006, 11:24
Из: Sunny Israel
Пользователь №: 7 269
100%
KiV
сообщение Dec 5 2006, 12:13
Пользователь №: 56
Как раз наоборот, в старых библиотеках нет этих слоев, и их советуют добавить.
RSS Текстовая версия Сейчас: 20th July 2025 - 15:22
Страница сгенерированна за 0.01431 секунд с 7
