> Вышел новый Keil для 51 семейства, Вер. 8.05f
GPP
сообщение Jan 10 2007, 12:18
Из: г.Киев
Пользователь №: 101
C51 Version 8.06 Release
[Device Support]
Infineon XC800 Devices: added debugging and flash programming support for new Infineon XC800 devices (XC866-1FR, XC856) with ULINK and Infineon DAS server.
Enhanced: Infineon XC800 startup code START_XC.A51 V1.02 that supports pdata addressing (C51: USING PDATA VARIABLES ON INFINEON XC800).
SST SmartCards:
[Device Simulation]
Corrected: interrupt vector for 2nd UART on Philips P89LPC952 was incorrectly configured in simulator and target dialog.
Enhanced: VTREG PPAGE is initialized to 0 on all Philips LPC900 devices to allow simulation of MOVX @Ri without configuration.
Corrected: a problem with AT89S8252 EEPROM simulation.
Corrected: a problem with the baudrate generation on Atmel devices with X2 feature (the baudrate was displayed incorrect).
Corrected: a problem with code banking on Mentor M8051EW core.
[Cx51 Compiler]
Corrected: code that is not used (i.e. with macros) is removed, even when it creates other side effects.
Corrected: unexpected error message for syntactical correct statement.
struct st2 { unsigned char uc1; unsigned char uc2; };
struct st1 { struct st2 st2; unsigned char u1; unsigned char u2; };
struct st1 st;
void main (void) {
(&st.st2)->uc1 = 0; // gives error, but should be Ok.
[ULINK and ULINK2 Support]
Added: support for ULINK2 for the Infineon XC800 and ST uPSD series.
Added: device support for Infineon XC886, XC888, and XC856.
- GPP   Вышел новый Keil для 51 семейства   Jan 10 2007, 12:18
- - Sasok   Цитата(GPP @ Jan 10 2007, 12:18) C51 Vers...   Jan 10 2007, 12:36
|- - GPP   Отправил в личку.   Jan 10 2007, 12:53
- - VAHOO   мне тоже дай пожалуйста newhdd@yandex.ru , и откуд...   Jan 10 2007, 20:04
- - Pretorianec   Ссылочку, если можно... И Если есть у кого лекарст...   Jan 15 2007, 11:22
- - K_AV   у кого нет доступа на местный FTP - такое же лекар...   Jan 18 2007, 15:32
- - vladnick   Если можно, дайте ссылочку.   Jan 19 2007, 11:52
|- - K_AV   Цитата(vladnick @ Jan 19 2007, 10:52) Есл...   Jan 19 2007, 16:12
|- - vladnick   Цитата(K_AV @ Jan 19 2007, 16:12) Цитата(...   Jan 20 2007, 20:00
- - ivstech   На сахаре как называется? Посмотрел, вроде нет там...   Jan 19 2007, 20:36
|- - K_AV   Цитата(ivstech @ Jan 19 2007, 19:36) На с...   Jan 20 2007, 10:11
- - Bovolk   Триал на 51 скачал с сайта Keil, где-то 20 Мег. Эт...   Jan 22 2007, 21:13
|- - Bovolk   Цитата(Bovolk @ Jan 22 2007, 20:13) Триал...   Jan 23 2007, 17:44
- - Arsenal_PC   на ихнем сайте-нужна не майлбоксовая почта. такой ...   Feb 27 2007, 09:22
- - LMT   Arsenal_PC Я на майл.ру бота заводил и выкачивал, ...   Feb 28 2007, 20:37
- - NoS85   Добрый день! Необходимо накодить для ат89с5131...   Mar 3 2007, 15:04
|- - evg123   Цитата(NoS85 @ Mar 3 2007, 16:04) Добрый ...   Mar 23 2007, 17:56
|- - Asb   Люди! А нет ли среди нас официальных пользоват...   Mar 26 2007, 15:47
- - Kolia   Почему uVision3.05 не дружит с кириллицей?   Mar 27 2007, 18:01
|- - Asb   Если Вы про 3.50 - то он не то чтобы совсем не дру...   Mar 27 2007, 18:40
- - LMT   Почему бы не задать этот вопрос, будучи пользовате...   Mar 30 2007, 09:56
- - Asb   Версия 3.51(8.08a) - без перемен. Или я просто не ...   Mar 30 2007, 14:53
RSS Текстовая версия Сейчас: 27th July 2025 - 18:24
Страница сгенерированна за 0.0134 секунд с 7
