> No valid license found
Foreigner
сообщение Jan 24 2007, 15:13
Пользователь №: 24 721
i registered myself at IAR-systems and received a key + license number to install their software.
But always when Im trying to compile something, I get the following error message:
error: copy protection check, no valid license found[20]
So I started google and finally I reached your forum, where I found a similar thread with a link to a rar-file with a crack(?):
http://slil.ru/23289938
The problem is, that the instr.txt file looks to me like the following:
Óíèâåðñàëüíîå ëåêàðñòâî äëÿ êîìïèëÿòîðîâ îò ÈÀÐ.
Ïðîâåðåíî ìíîé íà åâîëþøí âåðñèÿõ ÈÀÐ_ÀÐÌ_4.11à, ÈÀÐ_ÀÐÌ_4.20à è ÈÀÐ_430_3.21à.
Îáà ïðîäóêòà ïîñëå ïðîöåäóðû èçëå÷åíèÿ êîìïèëèðóþò íîðìàëüíî.
Ñèìóëÿòîðû íå ïðîâåðÿë, íå èñïîëüçóþ.
Àâòîð äàííîé ïðîãðàììû ïðîâåðÿë åå ewavr 8051 è h8.
Ïðîâåðåíî ïîëüçîâàòåëÿìè íà ÈÀÐ_ÀÂÐ_4.10à
VAI
Çàïóñòèòü ïðîãðàììó â äèðåêòîðèè bin.
Ïîäîæäàòü çàâåðøåíèÿ ïðîãðàììû.
Ïðîöåññ ðàáîòû ïðîãðàììû ìîæåò çàíÿòü íåêîòîðîå âðåìÿ, òàê êàê
ïðîãðàììà ïðîâåðÿåò âñå ôàéëû â äèðåêòîðèè íà ïðåäìåò ëå÷åíèÿ,
à íåîáõîäèìûå ôàéëû ñêàíèðóåò â 2 ïðîõîäà.
Òàê ÷òî äîæäèòåñü åå çàâåðøåíèÿ.
Ïðîãðàììà ðåçåðâíûå êîïèè íå ñîçäàåò è ñàìîëèêâèäèðóåòñÿ ïîñëå îêîí÷àíèÿ ðàáîòû!
Òàê ÷òî åñëè õîòèòå, òî ñíà÷àëî ñîõðàíèòå êîïèþ äèðåêòîðèè bin, òàê êàê îáðàòíóþ ïðîöåäóðó
ïðîãðàììà íå äåëàåò, òî åñòü ôàéëû â ïåðâîíà÷àëüíîå ñîñòîÿíèå íå âîçâðàùàåò!
Òàê æå íå áóäåò ðàáîòàòü åñëè ôàéëû äî ýòîãî óæå ïûòàëèñü ëå÷èòü!
Ðàáîòàåò òîëüêî ñ íîâûìè íå èñïðàâëåííûìè ôàéëàìè èç èíñòàëëÿöèè!
 read.me ÿ áû ïîñîâåòîâàë äîïèñàòü ñëåäóùåå:
"Ïðèìåíåíèå ëåêàðñòâà íå óäàëÿåò ïðåäóïðåæäåíèÿ, à ðàçðåøàåò ðàáîòàòü áåç
ëèöåíçèè, ïîýòîìó êîãäà ïðîéäåò ñðîê â 30 äíåé, ïðåäóïðåæäåíèå èñ÷åçíåò.
Åñëè óäàëèòü ïàïêó "C:\Program Files\Common Files\IAR Systems", òî ñîîáùåíèå
"Time Limited licese...." èñ÷åçíåò ñðàçó."
VAI
I cannot speak russian and so I tried to put the iarunicrk.exe in the two available /bin folders, but this always destroys the "IAR Embedded Workbench", some executables become invalid.
It would be really really nice if somebody would translate me the textfile in the archive or tell me what I have to do with the iarunicrk.exe unsure.gif
Ответов (1 - 4)
Lucky:)
сообщение Jan 24 2007, 21:30
Пользователь №: 21 031
I don't know what does "error: copy protection check, no valid license found[20]" mean, but why don't you ask the question to the IAR support?
"but this always destroys the "IAR Embedded Workbench""
possible because your version is different from 3.21а
Foreigner
сообщение Jan 24 2007, 21:52
The support does not answer!
I am using the correct version (I took the one for which the key generator within the zip file was created).
Would somebody be so nice and could tell me what is described in the textfile:
Lucky:)
сообщение Jan 24 2007, 22:12
Roughly speaking - extract "drug" into dir. bin and execute it. It can takes some time.
If the Workbench was attempted to heal the program can be destroyed.
el34
сообщение Jan 24 2007, 22:36
инженер
Пользователь №: 3 064
the simplest way for you will be try to use
http://translate.google.com/
select russian->english .....text translate
........поужинали вяленой рыбой, кот лежал рядом, молчали.......
RSS Текстовая версия Сейчас: 28th July 2025 - 06:44
Страница сгенерированна за 0.01352 секунд с 7
