> новый XC866 от Infineon, Flash, -40..+140°C
exSSerge
сообщение Feb 18 2007, 03:01
Из: Novosibirsk
Пользователь №: 19 655
http://www.infineon.com/cgi-bin/ifx/portal...newsChannel.jsp
The XC866 HOT 8-bit microcontrollers with embedded flash memory feature up to 100,000 read/write cycles at +140°C. This feature makes them currently the only MCUs in the market able to perform such data flash cycling at high temperatures.
The XC866 HOT family members are based on the standard 8051 architecture with on-chip flash memory of 4 kBytes, 8 kBytes or 16 kBytes. Performance and cost-saving features of the XC866 include a 26.67 MHz system frequency, an on-chip oscillator and PLL for clock generation and an embedded voltage regulator supporting single voltage supply of 3.3 V or 5.0 V. The MCUs feature a set of powerful peripherals, including a high-performance capture compare unit enabling flexible PWM signal generation with special modes for motor control; a fast 8-channel 10-bit AD converter allowing for a conversion time of less than 1.5 microseconds (µs) compared to the customary 6 to 10 µs; three 16-bit timers; UART; SSC (Synchronous Serial Channel); and on-chip debugging support (JTAG). An XC866 family of compatible 8 kBytes or 16 kBytes ROM versions with +140°C capability will also be available to offer even further cost saving potential.
In quantities of 10,000, the XC866 HOT is priced at approximately Euros 1.80 (US-$ 2.30) per piece.
RSS Текстовая версия Сейчас: 28th July 2025 - 17:34
Страница сгенерированна за 0.01332 секунд с 7
