> Инициализация члена структуры А, типа структуры В ?, В чем проблема?
alux
сообщение Apr 25 2007, 11:46
Пользователь №: 4 447
Компилятор выдает ошибку:
Error[Pe1049]: initializer cannot be specified for a flexible array member .
Использую IAR v.4.12A .
typedef struct menu_entry_s {
unsigned char flags; // see flag definitions above
void (*select)(void *arg, char *name); // routine to call when selected
char name[MENU_ENTRY_NAMELEN]; // name to display for this entry
void *value; // value to pass to select function
} menu_entry_t;
/* Information on a specific menu. Previous is for the menu
that this is a submenu of, or NULL if this is the main menu */
typedef struct menu_s {
unsigned char top_entry; // top displayed entry
unsigned char current_entry; // currently highlighted entry
unsigned char num_entries; // total # of entries in menu
struct menu_s *previous; // previous menu (for backtracking)
menu_entry_t entry[];
} menu_t;
menu_t sub1_menu = {
.top_entry = 0,
.current_entry = 0,
> .entry = { //!!!!!Error[Pe1049]: initializer cannot be specified for a flexible array member .
{.flags = 0,
.select = my_select,
.name = "s2",
.value = 0,
{.flags = 0,
.name = "s3",
.value = 0,
{.flags = 0,
.name = "s4",
.value = 0,
.num_entries = 3,
.previous = NULL,
Что я делаю не так?
RSS Текстовая версия Сейчас: 21st July 2025 - 18:55
Страница сгенерированна за 0.01361 секунд с 7
