> Проблема с компилятором MPLAB-C30, Функции Putchar и Printf
Froze
сообщение Sep 12 2007, 11:44
Пользователь №: 30 303
Пытаюсь скомпилировать программу для PIC24, в которой описана функция putchar,
void putchar(unsigned char q)
i2c_start(); i2c_write(LCD_ADDR);
i2c_write(CON1); i2c_write(0x01);
i2c_write(CON1); i2c_write(0x40 + f1);
i2c_write(CON1); i2c_write(0x80 + f);
i2c_write(CON2);
for(ii=0; ii<6; ii++) {i2c_write(symgen[q][ii]);}
i2c_write(0);
i2c_stop();
f += 6;
if (f >= 120) {f = 0; f1++;}
в ответ компилятор начинает выдавать кучу варнингов и ошибок касательно этой функции
вот:
P24.c:391: error: syntax error before '->' token
P24.c:393: error: syntax error before '(' token
P24.c:394: error: syntax error before '(' token
P24.c:394: error: syntax error before numeric constant
P24.c:394: warning: type defaults to 'int' in declaration of 'i2c_write'
P24.c:394: error: conflicting types for 'i2c_write'
P24.c:287: error: previous definition of 'i2c_write' was here
P24.c:394: warning: data definition has no type or storage class
P24.c:395: error: syntax error before '(' token
P24.c:395: error: syntax error before numeric constant
P24.c:395: warning: type defaults to 'int' in declaration of 'i2c_write'
P24.c:395: error: conflicting types for 'i2c_write'
P24.c:395: warning: data definition has no type or storage class
P24.c:396: error: syntax error before '(' token
P24.c:396: error: syntax error before numeric constant
P24.c:396: warning: type defaults to 'int' in declaration of 'i2c_write'
P24.c:396: error: conflicting types for 'i2c_write'
P24.c:396: warning: data definition has no type or storage class
P24.c:397: error: syntax error before '(' token
P24.c:399: error: syntax error before numeric constant
P24.c:399: warning: type defaults to 'int' in declaration of 'i2c_write'
P24.c:399: error: conflicting types for 'i2c_write'
P24.c:399: warning: data definition has no type or storage class
P24.c:400: warning: type defaults to 'int' in declaration of 'i2c_stop'
P24.c:400: error: conflicting types for 'i2c_stop'
P24.c:285: error: previous definition of 'i2c_stop' was here
P24.c:400: warning: data definition has no type or storage class
P24.c:401: error: syntax error before '+=' token
Кто с этим знаком, обьясните пожалуйста в чем тут дело.
з.ы. такая проблема появилась только когда я начал работать с С30, а в С18 такого не было
Dog Pawlowa
сообщение Sep 13 2007, 11:15
Пользователь №: 18 823
Я конечно не специалист в PIC, но основная ругань на тип аргумента в функции write.
В новой библиотеке это должен быть int, а вы взяли старый проект, где это char.
Уходя, оставьте свет...
Alex B._
сообщение Sep 13 2007, 20:49
Из: Санкт-Петербург
Пользователь №: 274
Ну во-первых нужно для начала пролистать документацию на компилер. Смотрите в папке /doc файл 16-Bit_Language_Tools_Libraries_51456d.pdf, глава 3.18 - там описано переопределение функций вызываемых функциями ввода-вывода.
Во-вторых у вас видимо h-файл не заинклюден
Froze
сообщение Sep 14 2007, 04:33
#include "stdio.h"
#include "p24FJ128GA010.h"
вот это есть
А в описании нет этого (16-Bit_Language_Tools_Libraries_51456d.pdf, глава 3.18)
Дело в том что мне нужно через I2C сообщаться с ЖК индикатором TIC32 и для этого я написал свою Putchar, чтобы через нее Printf выводил на индикатор строки (работало с С18 и PIC18) а тут компилятор почему-то ругается
может быть в С30 используется вместо Putchar что то другое ?
в документации я ничего не нашел, там есть только описание самих функций, а механизма работы Printf я там не нашел
Сообщение отредактировал Froze - Sep 14 2007, 04:36
RSS Текстовая версия Сейчас: 6th September 2025 - 17:07
Страница сгенерированна за 0.1531 секунд с 7
