> MEMMAP = 2; на LPC2146
meister
сообщение Jan 15 2008, 11:38
Пользователь №: 32 484
Здравствуйте,
код ниже работает с MEMMAP = 1 и не работает с MEMMAP = 2 (переключается препроцессором). Может, я какую мелочь упустил?
#include <iolpc2146.h>
#include <intrinsics.h>
#define BIT_(x) (1 << (x))
namespace
    unsigned const DBG_PIN = 24;
enum vec_id_t
    VEC_RESET = 0,
    VEC_UNDEF = 1,
    VEC_SWI = 2,
    VEC_PREFETCH = 3,
    VEC_DATA_ABORT = 4,
    VEC_RESERVED__ = 5,
    VEC_IRQ = 6,
    VEC_FIQ = 7,
    VEC_TOTAL_NUM = 8
#define MEMMAP_OPTION (1)
#if 1 == MEMMAP_OPTION
    #define VIC_ISR __irq __arm
#else
    #pragma location=0x40000000
    __no_init unsigned intvec[VEC_TOTAL_NUM * 2];
    #define VIC_ISR
#endif
VIC_ISR void irq_timer(void);
VIC_ISR void non_vectored_handler(void);
extern "C" __irq __arm void reset_handler(void) {}
extern "C" __irq __arm void undef_handler(void) {}
extern "C" __irq __arm void swi_handler(void) {}
extern "C" __irq __arm void prefetch_handler(void) {}
extern "C" __irq __arm void data_handler(void) {}
extern "C" __irq __arm void fiq_handler(void) {}
#if 2 == MEMMAP_OPTION
    __irq __arm void irq_handler(void)
        typedef void (VIC_ISR * handler_t)(void);
        handler_t h = reinterpret_cast<handler_t>(VICVectAddr);
        (*h)();
#endif
void hw_init(void)
    PCON = 0;
    PCONP = BIT_(1);
    VPBDIV = 1;
    MAMCR = 0;
    MAMTIM = 2;
    MAMCR = 2;
    MEMMAP = MEMMAP_OPTION;
    for (unsigned i = 0; i < VEC_TOTAL_NUM; ++i)
        intvec[i] = 0x18F09FE5; // ldr pc, [pc, #24];
    intvec[VEC_TOTAL_NUM + VEC_RESET] = reinterpret_cast<unsigned>(&reset_handler);
    intvec[VEC_TOTAL_NUM + VEC_UNDEF] = reinterpret_cast<unsigned>(&undef_handler);
    intvec[VEC_TOTAL_NUM + VEC_SWI] = reinterpret_cast<unsigned>(&swi_handler);
    intvec[VEC_TOTAL_NUM + VEC_PREFETCH] = reinterpret_cast<unsigned>(&prefetch_handler);
    intvec[VEC_TOTAL_NUM + VEC_DATA_ABORT] = reinterpret_cast<unsigned>(&data_handler);
    intvec[VEC_TOTAL_NUM + VEC_IRQ] = reinterpret_cast<unsigned>(&irq_handler);
    intvec[VEC_TOTAL_NUM + VEC_FIQ] = reinterpret_cast<unsigned>(&fiq_handler);
#endif
    VICSoftIntClear = ~0;
    VICIntEnClear = ~0;
    VICIntSelect = 0;
    VICVectAddr0 = reinterpret_cast<unsigned long>(&irq_timer);
    VICVectCntl0 = 4 + BIT_(5);
    VICIntSelect &= ~BIT_(4);
    VICDefVectAddr = reinterpret_cast<unsigned long>(&non_vectored_handler);
    VICIntEnable = BIT_(4);
    VICProtection = 1;
    VICVectAddr = 0;
    T0IR = 0xFF;
    T0TCR = BIT_(0) + BIT_(1);
    T0CTCR = 0;
    T0PR = 0;
    T0PC = 0;
    T0MCR = 0;
    T0CCR = 0;
    T0EMR = 0;
    T0TCR = BIT_(0);
    SCS = BIT_(1);
    PINSEL2 &= ~BIT_(3);
    FIO1DIR |= BIT_(DBG_PIN);
namespace
    unsigned const TIMER_TICK = 20000000 / 1000;
void start(void)
    T0MR0 = T0TC + TIMER_TICK;
    T0MCR_bit.MR0INT = 1;
    __enable_interrupt();
int main(void)
    hw_init();
    start();
    while (true) {}
    T0MR0 += TIMER_TICK;
    FIO1PIN ^= BIT_(DBG_PIN);
    T0IR = T0IR;
    VICVectAddr = 0;
    VICVectAddr = 0;
RSS Текстовая версия Сейчас: 20th August 2025 - 10:38
Страница сгенерированна за 0.01373 секунд с 7
