3 страниц V   1 2 3 >
> TWI в sam7s
Goofy
сообщение Jan 29 2008, 17:11
Из: Красноярск
Пользователь №: 30 600
Впервые для себя запускаю TWI на sam7s.
Использована атмеловская lib_twi
Запись
int AT91F_TWI_WriteSingle(const AT91PS_TWI pTwi,
                        int SlaveAddr,
                        char *data)
    unsigned int end = 0, status, err=0;
    /* Enable Master Mode */
  //  AT91C_BASE_TWI->TWI_CR = AT91C_TWI_MSEN;
    /* Set the TWI Master Mode Register */
    AT91C_BASE_TWI->TWI_MMR =  (SlaveAddr<<16 ) & ~AT91C_TWI_MREAD;
    /* Write the data to send into THR. Start conditionn DADDR and R/W bit
       are sent automatically */
    AT91C_BASE_TWI->TWI_THR = *data;
    AT91C_BASE_TWI->TWI_CR = AT91C_TWI_START;
    /* NACK errata handling */
    /* Do not poll the TWI_SR */
    /* Wait 3 x 9 TWCK pulse (max) 2 if IADRR not used, before reading TWI_SR */
    /* From 400Khz down to 1Khz, the time to wait will be in µs range.*/
    /* In this example the TWI period is 1/400KHz */
   AT91F_TWI_WaitMicroSecond (40);
    while (!end)
      status = AT91C_BASE_TWI->TWI_SR;
      if ((status & AT91C_TWI_NACK) == AT91C_TWI_NACK)
        err++;
        end=1;
    /*  Wait for the Transmit ready is set */
      if ((status & AT91C_TWI_TXRDY) == AT91C_TWI_TXRDY)
        end=1;
    AT91C_BASE_TWI->TWI_CR = AT91C_TWI_STOP;
    /* Wait for the Transmit complete is set */
    while (!(status & AT91C_TWI_TXCOMP))
    return err;
Инициализация (вызывается для 100кГц)
void AT91F_TWI_Open(int TwiClock)
    /* Configure TWI PIOs */
    AT91F_TWI_CfgPIO ();
    /* Configure PMC by enabling TWI clock */
    AT91F_TWI_CfgPMC ();
    /* Reset the TWI */
    AT91C_BASE_TWI->TWI_CR = AT91C_TWI_SWRST;
    /* Configure TWI in master mode */
    AT91F_TWI_Configure (AT91C_BASE_TWI);
    /* Set TWI Clock Waveform Generator Register */
  //AT91C_BASE_TWI->TWI_CWGR=0x047575;
    AT91F_SetTwiClock(TwiClock);
Расчёт делителей
void AT91F_SetTwiClock(int TwiClock)
  unsigned int cldiv,ckdiv=1;
  /* CLDIV = ((Tlow x 2^CKDIV) -3) x Tmck */
  /* CHDIV = ((THigh x 2^CKDIV) -3) x Tmck */
  /* Only CLDIV is computed since CLDIV = CHDIV (50% duty cycle) */
          cldiv = ( (MCK/(2*TwiClock))-3 ) / pow(2,ckdiv);
  while (  cldiv> 255 )
   ckdiv++;
  AT91C_BASE_TWI->TWI_CWGR =(ckdiv<<16)|((unsigned int)cldiv << 8)|(unsigned int)cldiv;
Проблема в том, что процедура передачи просто виснит, очевидно не получая из статус регистра TXRDY. TWI инициализирован приведённой выше процедурой.
Я не ошибаюсь, считая, что "железные" проблемы никак не влияют на работу модуля внутри?
Пока не идёт речи о корректности передачи, лишь о факте того, что статус регистр не ведёт себя должным образом.
Есть ли вероятность что модуль битый напрочь?
Хомяк
сообщение Jan 30 2008, 04:06
Из: Свердловск
Пользователь №: 25 269
Запускал TWI на AT91SAM7A3 проблем не было.
Но у меня функция AT91F_SetTwiClock() маленько по другому была.
И еще что цепляется на шину?
Резисторы подтягивающие стоят?
Сообщение отредактировал Хомяк - Jan 30 2008, 04:08
Goofy
сообщение Jan 30 2008, 05:27
Из: Красноярск
Эту функцию я правил чуть чуть, думал, мало ли...
Подтяжка стоит. Только влияет ли это на процесс обновления регистров самого TWI ?
gladov
сообщение Jan 30 2008, 10:49
Из: Воронеж
Пользователь №: 10 687
Сразу бросается в глаза, что Вы делаете при передаче принудительно START|STOP. По DS на at91Sam7X от октября 2007г., этого делать не надо. А может быть и нельзя. Я тоже долго мучил TWI и столкнулся с проблемой - если при передаче принудительно дернуть START, то последующая операция чтения глючит. Ни старт, ни стоп при передаче не надо включать.
Влияет. Встречал реализацию (не помню в каком камне), когда аппаратный i2c сильно глючил без подтяжки.
Goofy
сообщение Jan 30 2008, 11:20
Из: Красноярск
Принудительный старт выставил ради эксперимента. Убрал обратно. Дело в том, что SCL SDA линии красоты ради были подключены через MAX3002 чтобы синхронизировать уровни с 5В, что собственно не диктуется необходимостью (выводы sam7s к 5в терпимы, подтяжка внешняя, 100К припаял для начала). Ради уменьшения глючности отрезал дорожки от MAX3002, соеденил с 5В частью шины напрямую. При инициализации выходит что ключи на ножках sam7s256 открыты, на шине нулевой уровень. Цикл так же виснит. crying.gif
Сообщение отредактировал Goofy - Jan 30 2008, 11:23
gladov
сообщение Jan 30 2008, 12:44
Из: Воронеж
А 100К не много? Рекомендуют от 5 до 10 ставить. А почему бы не попробовать остановить цикл во время висяка и не посмотреть что лежит в TWI_SR?
Goofy
сообщение Jan 30 2008, 12:52
Из: Красноярск
Обстановка изменилась.
Для sam7s обязательным судя по всему является
AT91C_BASE_PIOA->PIO_MDER=AT91C_PA4_TWCK|AT91C_PA3_TWD;
Резисторы переставил на 10к. Однако верхний уровень сигнала явно не 5 вольт. Зависание прекратилось когда на шину подцепил приёмное устройство. Попытка заглянуть в сигнал осцилографом (25рF, TWI инициализируется под частоту 50гц) снова вешает цикл и ничего не наблюдается. Будем разбираться ...
Сообщение отредактировал Goofy - Jan 30 2008, 12:54
Хомяк
сообщение Jan 30 2008, 13:16
Из: Свердловск
Я на TWI вешал 24LC256
подтягивал 2к
Привожу свой код
Кварц 16МГц работал на частоте квалца , без ФАПЧ
//  Функция             : AT91F_SetTwiClock
//  Описание            :
//  входные параметры   :
//  выходные параметры  :
void AT91F_SetTwiClock(void)
  int sclock;
  /* Here, CKDIV = 1 and CHDIV=CLDIV  ==> CLDIV = CHDIV = 1/4*((Fmclk/FTWI) -6)*/
  sclock = (10*MCK /AT91C_TWI_CLOCK);
  if (sclock % 10 >= 5)
      sclock = (sclock /10) - 5;
  else
      sclock = (sclock /10)- 6;
  sclock = (sclock + (4 - sclock %4)) >> 2;    // div 4
  AT91C_BASE_TWI->TWI_CWGR    = ( 1<<16 ) | (sclock << 8) | sclock;
//  Функция             : AT91F_TWI_Open
//  Описание            :
void AT91F_TWI_Open(void)
  AT91F_TWI_CfgPIO();                     // configure TWI PIOs
  AT91F_TWI_CfgPMC();                     // enable clock TWI
  AT91F_TWI_Configure (AT91C_BASE_TWI);   // configure in MASTER mode
  AT91F_SetTwiClock();
//  Функция             : AT91F_TWI_WriteByte
//  Описание            :
int AT91F_TWI_WriteByte(const AT91PS_TWI pTwi ,int mode, int int_address, char *data2send, int nb)
  unsigned int status,counter=0,error=0;
  // Set TWI Internal Address Register
  if ((mode & AT91C_TWI_IADRSZ) != 0) pTwi->TWI_IADR = int_address;
  // Set the TWI Master Mode Register
  pTwi->TWI_MMR = mode & ~AT91C_TWI_MREAD;
  if(nb <2)
    pTwi->TWI_CR = AT91C_TWI_START | AT91C_TWI_MSEN | AT91C_TWI_STOP;
    pTwi->TWI_THR = *data2send;
  else
    for(counter=0;counter<nb;counter++)
      pTwi->TWI_CR = AT91C_TWI_START | AT91C_TWI_MSEN;
      if (counter == (nb - 1)) pTwi->TWI_CR = AT91C_TWI_STOP;
      status = pTwi->TWI_SR;
      if ((status & ERROR) == ERROR) error++;
      while (!(status & AT91C_TWI_TXRDY))
      pTwi->TWI_THR = *(data2send+counter);
  return error;
//  Функция             : AT91F_TWI_ReadByte
//  Описание            :
int AT91F_TWI_ReadByte(const AT91PS_TWI pTwi ,int mode, int int_address, char *data, int nb)
  pTwi->TWI_MMR = mode | AT91C_TWI_MREAD;
  // Start transfer
  if (nb == 1)
    pTwi->TWI_CR = AT91C_TWI_START | AT91C_TWI_STOP;
    *(data) = pTwi->TWI_RHR;
   else
     // Wait transfer is finished
       if ((status & ERROR )== ERROR) error++;
        if(status & AT91C_TWI_RXRDY)
      *(data+counter++) = pTwi->TWI_RHR;
   return 0;
//  Функция             :
//  Описание            :
void TWI_ReadByte(const AT91PS_TWI pTwi ,int mode, char *data, int nb)
  unsigned int status,counter=0;
  // without internal address ??????
  //if ((mode & AT91C_TWI_IADRSZ) != 0) pTwi->TWI_IADR = int_address;
  // Use MS 7 bits as mode ??????
  // Start transfer
  if (nb == 1)
    //if ((status & ERROR) == ERROR) error++;
    while (!(status & AT91C_TWI_TXCOMP));
  else
      AT91F_DBGU_Printk("\n\rTEST_AT91F_TWI_ReadByte_1");
         AT91F_DBGU_Printk("\n\rTEST_AT91F_TWI_ReadByte_2");
         //AT91F_DBGU_Printk("\n\rTEST_AT91F_TWI_ReadByte_3");
Сообщение отредактировал Хомяк - Jan 30 2008, 13:18
Goofy
сообщение Feb 1 2008, 05:03
Из: Красноярск
Проблема решилась.
При отсутствии устройства на шине по запрашиваемому адресу, цикл виснит. Буду вводить таймауты.
Ruslan1
сообщение Feb 4 2008, 18:30
Из: Кишинев
Пользователь №: 15 025
Цитата(Goofy @ Feb 1 2008, 07:03) *
Проблема решилась.
Какое-то время назад тут уже подымалась тема TWI. Тема для меня больная, но повторяться не буду, только выводы:
Хотите иметь надежное устройство- делайте софтовый TWI. Чтобы Ваше устройство работало так, как хотите Вы и не зависало от каждой иголки на шине.
Подчеркну, это мой личный выстраданный опыт, никому свое мнение навязывать не буду.
Причем это я на других АРМах грыз (AT91RM9200). Но "чуйствую", что уши у проблемы те же.
Terrabyte
сообщение Feb 7 2008, 11:09
Из: Russia
Пользователь №: 24 042
всё будет хорошо господа! читайте документ:
http://electronix.ru/forum/index.php?act=A...st&id=16553
cebotor
сообщение Feb 7 2008, 11:58
Из: Бронницы
Пользователь №: 26 809
а не в процессорах ли ST ?
в подтверждение могу сказать что на STM32 при инициализации TWI в случае неправильной подтяжки
мастер встает в такое кривое состояние что потом никогда не может сгенерировать start condition
если еррата пуста - это не хорошо а плохо
pan_oleg
сообщение Apr 4 2008, 11:40
Пользователь №: 32 387
вот у меня такая ситуация, на STM32 не может сгенерировать start,
подтяжка 5 к, на шине еепромка, виснет только при чтении из еепромки,
что поменять с подтяжкой?
singlskv
сообщение Apr 6 2008, 21:27
дятел
Из: Питер
Пользователь №: 17 065
Terrabyte а может быть Вы сможете подитожить инфу по работе i2c ?
и выложить ее на всеобщее обозрение в виде FAQ ?
Готов выдать Вам еще несколько мыслей, но хотелось бы на выходе получить готовую
апликайшен про то как нужно пользоваться i2c на samxxxxx....
aaarrr
сообщение Apr 7 2008, 05:02
Сообщение #15
Пользователь №: 1 448
ИМХО, TWI на SAM7 все же неработоспособен. У меня есть несколько "почти работающих" вариантов, но все они благополучно сыпятся на попытке общения с SAA7113. Софтверный во сто крат лучше, поверьте smile.gif
3 страниц V   1 2 3 >
RSS Текстовая версия Сейчас: 27th July 2025 - 03:05
Страница сгенерированна за 0.02894 секунд с 7
