> FreeBSD на AT91RM9200
jack_avenger
сообщение Feb 17 2008, 17:19
Из: Киев
Пользователь №: 6 426
Доброго времени суток всем!
Поискал по форуму о запуске FreeBSD на AT91RM9200 и ничего не нашел, поэтому решил открыть ветку.
С недавних пор вожусь з запуском FreeBSD на RM9200.
KB9202(www.kwikbyte.com)
Auto boot..
0x0 : m 42 53 44 0 0 1[E]
0x1 : ip 206 168 13 194[E]
0x2 : server_ip 206 168 13 207[E]
0x3 : tftp 0x20000000 kernel.bin[E]
0x4 : e 0x20000000[E]
0x5 : [E]
0x6 : [E]
0x7 : [E]
0x8 : [E]
0x9 : |?[E]
>m 42 53 44 0 0 1
>ip 206 168 13 194
tftp: 2497948 byte
>e 0x20000000
KDB: debugger backends: ddb
KDB: current backend: ddb
Copyright (c) 1992-2008 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
        The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 7.0-RC2 #2: Fri Feb 15 10:14:59 EET 2008 root@:/usr/obj/arm/usr/src/sys/KB920X
CPU: ARM920T rev 0 (ARM9TDMI core)
  DC enabled IC enabled WB enabled LABT
  16KB/32B 64-way Instruction cache
  16KB/32B 64-way write-back-locking-A Data cache
real memory  = 33554432 (32 MB)
avail memory = 29450240 (28 MB)
atmelarm0: <AT91 device bus> on motherboard
at91_st0: <ST> mem 0xdffffd00-0xdffffdff irq 1 on atmelarm0
at91_st0: watchdog registered, timeout intervall max. 64 sec
at91_pio0: <PIOA> mem 0xdffff400-0xdffff5ff irq 1 on atmelarm0
at91_pio0: ABSR: 0x60 OSR: 0 PSR:0x138001f ODSR: 0
at91_pio0: [FILTER]
at91_pio1: <PIOB> mem 0xdffff600-0xdffff7ff irq 1 on atmelarm0
at91_pio1: ABSR: 0xff300 OSR: 0 PSR:0x3fc00cff ODSR: 0
at91_pio1: [FILTER]
at91_pio2: <PIOC> mem 0xdffff800-0xdffff9ff irq 1 on atmelarm0
at91_pio2: ABSR: 0 OSR: 0x1c0000 PSR:0xffffc07f ODSR: 0x180000
at91_pio2: [FILTER]
at91_pio3: <PIOD> mem 0xdffffa00-0xdffffbff irq 1 on atmelarm: 0 PSR:0xfffffff ODSR: 0
at91_pio3: [FILTER]
at91_pmc0: <PMC> mem 0xdffffc00-0xdffffcff irq 1 on atmelarm0
at91_pmc0: Primary: 10000000 Hz PLLA: 180 MHz CPU: 180 MHz MCK: 60 MHz
at91_mci0: <MCI mmc/sd host bridge> mem 0xdffb4000-0xdffb7fff irq 10 on atmelarm0
at91_mci0: [ITHREAD]
mmc0: <mmc/sd bus> on at91_mci0
at91_twi0: <TWI> mem 0xdffb8000-0xdffbbfff irq 12 on atmelarm0
at91_twi0: [ITHREAD]
iicbus0: <Philips I2C bus> on at91_twi0
setting cwgr to 0x1a4a4
iicbus0: <unknown card> at addr 0
iic0: <I2C generic I/O> on iicbus0
icee0: <I2C EEPROM> at addr 0xa0 on iicbus0
ate0: <EMAC> mem 0xdffbc000-0xdffbffff irq 24 on atmelarm0
miibus0: <MII bus> on ate0
ukphy0: <Generic IEEE 802.3u media interface> PHY 0 on miibus0
ukphy0:  10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, auto
ate0: Ethernet address: 42:53:44:00:00:01
ate0: [ITHREAD]
uart0: <DBGU> mem 0xdffff200-0xdffff3ff irq 1 on atmelarm0
uart0: console (115200,n,8,1)
uart1: <USART0> mem 0xdffc0000-0xdffc3fff irq 6 on auart2: <USART1> mem 0xdffc
4000-0xdffc7fff irq 7 on atmelarm0
uart2: [FILTER]
uart3: <USART2> mem 0xdffc8000-0xdffcbfff irq 8 on atmelarm0
uart3: [FILTER]
uart4: <USART3> mem 0xdffcc000-0xdffcffff irq 9 on atmelarm0
uart4: [FILTER]
at91_spi0: <SPI> mem 0xdffe0000-0xdffe3fff irq 13 on atmelarm0
at91_spi0: [ITHREAD]
spibus0: <spibus bus> on at91_spi0
ohci0: <AT91 integrated ohci controller> mem 0xdfe00000-0xdfefffff irq 23 on atmelarm0
ohci0: [GIANT-LOCKED]
ohci0: [ITHREAD]
usb0: OHCI version 1.0
usb0 on ohci0
usb0: USB revision 1.0
uhub0: <Atmel OHCI root hub, class 9/0, rev 1.00/1.00, addr 1> on usb0
uhub0: 2 ports with 2 removable, self powered
uhub0: device problem (IOERROR), disabling port 2
Cannot get 100 Hz clock; using 100Hz
at91_st0: [FILTER]
Timecounter "AT91RM9200 timer" frequency 32768 Hz quality 1000
Timecounters tick every 10.000 msec
SD CARD: 998768640 bytes
mmcsd0: <mmc or sd flash card> on mmc0
mmc0: setting transfer rate to 30.000MHz
Trying to mount root from ufs:/dev/mmcsd0s1a
warning: no time-of-day clock registered, system time will not be set accurately
Loading configuration files.
No suitable dump device was found.
Entropy harvesting: interrupts ethernet point_to_point kickstart.
swapon: adding /dev/mmcsd0s1b as swap device
Starting file system checks:
/dev/mmcsd0s1a: FILE SYSTEM CLEAN; SKIPPING CHECKS
/dev/mmcsd0s1a: clean, 146347 free (1171 frags, 18147 blocks, 0.5% fragmentation)
Setting hostuuid: 2db3ec31-dbc8-11dc-bc4d-425344000001.
Setting hostid: 0x8098ae24.
Mounting local file systems:.
Setting hostname: borda.nik.net.ua.
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384
        inet 127.0.0.1 netmask 0xff000000
Additional routing options:.
Starting devd.
ate0: link state changed to UP
Additional IP options:.
Mounting NFS file systems:.
ELF ldconfig path: /lib /usr/lib /usr/lib/compat /usr/local/lib
Creating and/or trimming log files:.
Starting syslogd.
/etc/rc: WARNING: Dump device does not exist.  Savecore not run.
Initial arm initialization:.
Additional ABI support:.
NFS access cache time=60
Clearing /tmp (X related).
Starting lighttpd.
Starting local daemons:.
Updating motd.
Mounting late file systems:.
Starting sshd.
Starting cron.
Local package initialization: msql3.
Starting inetd.
Starting background file system checks in 60 seconds.
Sat Feb 16 19:38:36 UTC 2008
FreeBSD/arm (borda.nik.net.ua) (ttyu0)
login: root
Password:
Feb 16 19:39:03 borda login: ROOT LOGIN (root) ON ttyu0
Last login: Sat Feb 16 19:22:59 on ttyu0
FreeBSD 7.0-RC2 (KB920X) #2: Fri Feb 15 10:14:59 EET 2008
You have new mail.
borda# pkg_info
libtool-1.5.24      Generic shared library support script
lighttpd-1.4.18_1   A secure, fast, compliant, and very flexible Web Server
msql-3.8            Version 3 of the Mini SQL relational database system
pcre-7.6            Perl Compatible Regular Expressions library
rdb-2.6d            A fast, portable, relational database management syste Лm
borda# uname -a
FreeBSD borda.nik.net.ua 7.0-RC2 FreeBSD 7.0-RC2 #2: Fri Feb 15 10:14:59 EET 2
008     root@:/usr/obj/arm/usr/src/sys/KB920X  arm
borda#
Запускал на плате KwikiByte KB9202C. Загрузка длится около 2 мин и причиной тому медленная работа с SD-карточкой.
В запуске очень помогла рассылка freebsd-arm на http://lists.freebsd.org/mailman/listinfo/freebsd-arm
В данный момент ищу облегченную бесплатную базу данных с поддержкой SQL
- jack_avenger   FreeBSD на AT91RM9200   Feb 17 2008, 17:19
- - doomer#gp   Trying to mount root from ufs:/dev/mmcsd0s1a UFS ...   Feb 17 2008, 22:01
|- - jack_avenger   Цитата(doomer#gp @ Feb 18 2008, 01:01) Tr...   Feb 18 2008, 07:45
- - PrSt   Цитата(jack_avenger @ Feb 17 2008, 19:19)...   Feb 20 2008, 07:49
- - Stanislav Sedov   Собственно, на Черкашинской плате она тоже нормаль...   Feb 21 2008, 12:09
|- - jack_avenger   Цитата(Stanislav Sedov @ Feb 21 2008, 16...   Feb 21 2008, 13:39
|- - Stanislav Sedov   Цитата(jack_avenger @ Feb 21 2008, 16:39)...   Feb 21 2008, 14:01
|- - jack_avenger   Цитата(Stanislav Sedov @ Feb 21 2008, 18...   Feb 21 2008, 15:02
|- - Stanislav Sedov   Цитата(jack_avenger @ Feb 21 2008, 18:02)...   Feb 21 2008, 15:09
|- - jack_avenger   Цитата(Stanislav Sedov @ Feb 21 2008, 19...   Feb 21 2008, 15:21
|- - Stanislav Sedov   Цитата(jack_avenger @ Feb 21 2008, 18:21)...   Feb 21 2008, 23:39
- - Stanislav Sedov   Тофарищи, а если у кого-нибудь ещё осталась рабоча...   Feb 25 2008, 21:53
- - jack_avenger   Цитата(Stanislav Sedov @ Feb 26 2008, 01...   Feb 26 2008, 11:48
- - Stanislav Sedov   Цитата(jack_avenger @ Feb 26 2008, 14:48)...   Feb 26 2008, 23:51
- - dch   Цитата(Stanislav Sedov @ Feb 27 2008, 02...   Feb 29 2008, 14:49
- - Stanislav Sedov   Цитата(dch @ Feb 29 2008, 17:49) Не должн...   Mar 1 2008, 10:05
- - dch   Письмо получил, еще не попробовал. Сейчас попробу...   Mar 4 2008, 11:16
RSS Текстовая версия Сейчас: 24th July 2025 - 02:12
Страница сгенерированна за 0.02247 секунд с 7
