> AT91SAM9M10 - новый камень от Атмел, Даташит на AT91SAM9M10
lvitaly
сообщение Apr 22 2008, 11:10
Из: Moscow
Пользователь №: 554
Промелькнул даташит на новый, еще не объявленный камень от Атмел - AT91SAM9M10.
Камень монстрообразный, таких у Атмел что-то не припомню.
Залил на ftp
/upload/MCs/ARM/Doc/AT91SAM9M10_ds.rar
продублировал на рапиде
http://rapidshare.com/files/109488653/AT91SAM9M10_ds.rar
Features
• Incorporates the ARM926EJ-S™ ARM® Thumb® Processor
– DSP Instruction Extensions
– ARM Jazelle® Technology for Java® Acceleration
– 32-Kbyte Data Cache, 32-Kbyte Instruction Cache, Write Buffer
– CPU Clock Frequency: 400 MHz @ 1.0V +/- 5%
– Memory Management Unit
– EmbeddedICE™ In-circuit Emulation, Debug Communication Channel Support
• Multi Layer AHB Bus Matrix for Large Bandwidth Transfers
– Twelve 32-bit Layer Matrix
– Boot Mode Select Option, Remap Command
• One 64-Kbyte internal ROM, Single-cycle Access at Maximum speed
• One 64-Kbyte internal SRAM
– Single-cycle Access at System Speed
– ITCM and DTCM accesses
• DDR2/LPDDR Memory Interface: 4-port DDR2/LP-DDR Controller
– 16Bit LP-DDR
– 16Bit DDR2
• Video Decoder (VDEV) Supported Standards
– MPEG-4 Simple and Advanced Profile, Levels 0-5
– H.264 Baseline Profile, Levels 1-3.1
– H.263 Profile 0,Levels 10-70
– VC-1
• Simple Profile, Low and Medium Levels
• Main Profile, Low, Medium and High Levels
• Advanced Profile, Low, Medium and High Levels
– MPEG-2 Main Profile, Low, Medium and High Levels
– DivX Profile Handheld, Portable, Home Theatre and High Definition Profiles
– JPEG Profile Baseline DCT (Sequential) and JFIF 1.02 file form
• External Bus Interface (EBI)
– Sixteen 32-bit Wide Interface, Supporting:
– 16-bit DDR2/LPDDR, Sixteen 32-bit SDRAM/LPSDR
– Static Memories
– NAND Flash (SLC Devices, DMA Channel for Automatic Multiple Block Transfer)
– ECC (SLC NandFlash ECC)
– CompactFlash Logic
• Four High Speed Memory Card Hosts, Supporting (MCI)
– MMC/MMCPlus v4.1
– SDcard/SDIO v2.0
– CE ATA Interface
• 8-channel DMA Controller
– Two Matrix Masters
– Memory to Memory Transfer
– Linked List Management
• 480 Mbps USB Device High Speed Controller with On-Chip UTMI Transceiver
• 480 Mbps USB Host Controller with On-chip UTMI Transceiver (1 Dedicated Port + 1
Port Shared with UDP HS)
– High Speed EHCI
– Full speed OHCI
• 10/100 Mbps Ethernet Mac Controller
– Media Independent Interface or Reduced Media Independent Interface
– 128 Bytes FIFOs and Dedicated DMA Channels for Receive and Transmit
– Wake On LAN Capability
• LCD Controller Supports
– Passive or Active Displays,
– Up to 24 bits per Pixel in TFT Mode
– Up to 16 bits per Pixel in STN Color Mode
– Resolution up to 2048 x 2048, Supports Virtual Screen Buffers
• One 8-channel 10-bit Analog-to-Digital Converter
– Touch Screen Interface Compatible with Industry Standard 4-wire Sensitive Touch Panels
• Universal Video Decoder Provides Decoding of MPEG-2/MPEG-4/H.263/H.264/VC1(WMV9)/JPEG
– up to 30 fps @D1 resolution
– Image Scaling
– Color Conversion
– Picture in Picture
– Rotation
• ITU-R BT. 601/656 Image Sensor Interface
– with Programmable Frame Capture Rate
– DMA on Preview and Codec Paths
– SAV and EAV Synchronization
– Preview Path with Scaler
• One AC97 Controller (AC97C)
– 6-channel Single AC97 Analog Frontend Interface, Slot Assigner
• RNG Random Number Generator
– Compliant with NIST Special Publication 800-22
– Provides a 32-bit Random Number Each 84 Clock Cycles
• Fully-featured System Controller, Including
– Reset Controller, Shut Down Controller
– Four 32-bit Battery Backup Registers for A Total Of 16 Bytes
– Clock Generator and Power Management Controller
– Advanced Interrupt Controller and Debug Unit
– Periodic Interval Timer, Watchdog Timer and Real-Time Timer and Real Time Clock
• Reset Controller (RSTC)
– Based on Two Power-on Reset Cells
– Reset Source Identification and Reset Output Control
• Shut Down Controller (SHDC)
– Programmable Shut Down Pin Control and Wake-up Circuitry
• Clock Generator (CKGR)
– Selectable 32768 Hz Low-power Oscillator or Internal Low-power RC Oscillator on Battery Backup Power Supply,
providing a permanent Slow Clock
– 12 MHz On-chip Oscillator for Main System Clock and USB Clock
– One PLL up to 800MHz
– One PLL 480MHz optimized for USB HS
• Power Management Controller (PMC)
– Very Slow Clock Operating Mode, Software Programmable Power Optimization Capabilities
– Two Programmable External Clock Signals
• Advanced Interrupt Controller (AIC)
– Individually Maskable, Eight-level Priority, Vectored Interrupt Sources
– One External Interrupt Sources and One Fast Interrupt Source, Spurious Interrupt Protected
• Debug Unit (DBGU)
– 2-wire UART and Support for Debug Communication Channel
• Periodic Interval Timer (PIT)
– 20-bit Interval Timer Plus 12-bit Interval Counter
• Watchdog Timer (WDT)
– Key-protected, Programmable Only Once, Windowed 16-bit Counter Running at Slow Clock
• Real-Time Timer (RTT)
– 32-bit Free-running Backup Counter Running at Slow Clock with 16-bit Prescaler
• Real-Time Clock (RTC)
– Time, Date and Alarm 32-bit Parallel Load
– Low Power Consumption
– Programmable Periodic Interrupt
• Five 32-bit Parallel Input/Output Controllers (PIOA, PIOB, PIOC, PIOD and PIOE)
– 160 Programmable I/O Lines Multiplexed with up to Two Peripheral I/Os
– Input Change Interrupt Capability on Each I/O Line, Schmitt Trigger input
– Individually Programmable Open-drain, Pull-up Resistor and Synchronous Output
– Schmitt Trigger on all inputs.
• Peripheral DMA Controller Channels (PDC)
• Two Synchronous Serial Controllers (SSC)
– Independent Clock and Frame Sync Signals for Each Receiver and Transmitter
– I²S Analog Interface Support, Time Division Multiplex Support
– High-speed Continuous Data Stream Capabilities with 32-bit Data Transfer
• Four Universal Synchronous/Asynchronous Receiver Transmitters (USART)
– Individual Baud Rate Generator, IrDA Infrared Modulation/Demodulation, Manchester Encoding/Decoding
– Support for ISO7816 T0/T1 Smart Card, Hardware Handshaking, RS485 Support
• Two Master/Slave Serial Peripheral Interface (SPI)
– 8- to 16-bit Programmable Data Length, Four External Peripheral Chip Selects
– High speed Synchronous Communications
• Two Three-channel 16-bit Timer/Counters (TC)
– Three External Clock Inputs, Two multi-purpose I/O Pins per Channel
– Double PWM Generation, Capture/Waveform Mode, Up/Down Capability
• One Four-channel 16-bit PWM Controller (PWMC)
• Two Two-wire Interface (TWI)
– Compatible with Standard Two-wire Serial Memories
– One, Two or Three Bytes for Slave Address
– Sequential Read/Write Operations
– Master, Multi-master and Slave Mode Operation
– Bit Rate: Up to 400 Kbits
– General Call Supported in Slave mode
– Connection to Peripheral DMA Controller (PDC) Channel Capabilities Optimizes Data Transfers in Master Mode Only
• SAM-BA® Boot Assistant
– Default Boot Program
– Boot on NandFlash, SDCARD or serial dataflash
– Interface with SAM-BA Graphic User Interface
• Required Power Supplies:
– 0.9V to 1.1V for VDDCORE, VDDPLLA, VDDPLLUTMI, VDDUTMIC
– 3.0V to 3.6V for VDDUTMII
– 1.8V to 3.6V for VDDBU
– 1.65V to 3.6V for VDDOSC
– 1.65V to 3.6V for VDDIOP0, VDDIOP1 and VDDIOP2 (Peripheral I/Os)
– 1.65V to 1.95V for VDDIOM0
– Programmable 1.65V to 1.95V or 3.0V to 3.6V for VDDIOM1 (Memory I/Os)
– 3.0V to 3.6V VDDANA (Analog to Digital Converter)
• Available in a 324-ball TFBGA Green Package (pitch 0.8 mm)
RSS Текстовая версия Сейчас: 20th July 2025 - 18:28
Страница сгенерированна за 0.01369 секунд с 7
